前面用一片arduino控制一個步進(jìn)電機,但是控制多路步進(jìn)電機容易互相干擾,主要是每個脈沖延時用了delay函數(shù)。
一路兩相的步進(jìn)電機需要占用4個i/o口,因此一片arduino最多控制3個步進(jìn)電機(不算模擬i/o)。
一個l298模塊只能接一個步進(jìn)電機。下面實驗接2路電機的情況,3路時情況差不多。
(1)實驗了一下arduino自帶的stepper庫,發(fā)現(xiàn)連接兩個電機只能一個一個按順序動,不能同時動。但是電機都能動,工作沒有問題。這顯然不是我們想要的
(2)改了一下自己編的步進(jìn)電機程序,可以同時動了,但是兩個電機的速度不好設(shè)置,變量太多。
最后做了個艱難的決定,自己編庫文件。好久沒動c語言了,忘得差不多了,只好在原有庫函數(shù)的基礎(chǔ)上改。改了一個晚上,終于沒問題了,并且把原來庫函數(shù)中的四拍的方法改成八拍,控制更準(zhǔn)確,運動更平穩(wěn)了。庫函數(shù)在我的網(wǎng)盤下載,這幾天沒空了,等有空再改一下傳到官網(wǎng)上去:
例子程序:
#include
const int stepsPerRevolution = 400; // 對于兩相四線的電機,一般步距角是1.8度,這里如果是四拍就寫200,八拍就寫400
// initialize the stepper library on pins 8 through 11:
Stepper myStepper1(stepsPerRevolution, 4,5,6,7); //兩個電機分別占四個腳
Stepper myStepper2(stepsPerRevolution, 8,9,10,11);
void setup() {
// set the speed at 60 rpm:
myStepper1.setSpeed(60);
myStepper2.setSpeed(60);
// initialize the serial port:
Serial.begin(9600);
void loop() {
int r;
for(int i=0; i<400;)
r= myStepper1.stepOneStep(0);
myStepper2.stepOneStep(1);//括號中的參數(shù)是方向,0和1代表不同轉(zhuǎn)動方向
if(r==2) i++;
delay(500);
StepperM.h:
Stepper.h - - Stepper library for Wiring/Arduino - Version 0.4
Original library (0.1) by Tom Igoe.
Two-wire modifications (0.2) by Sebastian Gassner
Combination version (0.3) by Tom Igoe and David Mellis
Bug fix for four-wire (0.4) by Tom Igoe, bug fix from Noah Shibley
Muliti-motor modifications (0.5) by Xu Pei.
Drives a unipolar or bipolar stepper motor using 2 wires or 4 wires
When wiring multiple stepper motors to a microcontroller,
you quickly run out of output pins, with each motor requiring 4 connections.
By making use of the fact that at any time two of the four motor
coils are the inverse of the other two, the number of
control connections can be reduced from 4 to 2.
A slightly modified circuit around a Darlington transistor array or an L293 H-bridge
connects to only 2 microcontroler pins, inverts the signals received,
and delivers the 4 (2 plus 2 inverted ones) output signals required
for driving a stepper motor.
The sequence of control signals for 4 control wires is as follows:
Step C0 C1 C2 C3
1 1 0 1 0
2 0 1 1 0
3 0 1 0 1
4 1 0 0 1
The sequence of controls signals for 2 control wires is as follows
(columns C1 and C2 from above):
Step C0 C1
1 0 1
2 1 1
3 1 0
4 0 0
The circuits can be found at
http://www.arduino.cc/en/Tutorial/Stepper
// ensure this library description is only included once
#ifndef Stepper_h
#define Stepper_h
// library interface description
class Stepper {
public:
// constructors:
Stepper(int number_of_steps, int motor_pin_1, int motor_pin_2);
Stepper(int number_of_steps, int motor_pin_1, int motor_pin_2, int motor_pin_3, int motor_pin_4);
// speed setter method:
void setSpeed(long whatSpeed);
// mover method:
void step(int number_of_steps);
// mover 1 step:
// dir:direction, 0 negtive; else positive.
//if return 0, the motor start move; else if return 1, waiting; return 2, move complete;
int stepOneStep(int dir);
int version(void);
private:
void stepMotor(int this_step);
int direction; // Direction of rotation
int speed; // Speed in RPMs
unsigned long step_delay; // delay between steps, in us, based on speed
int number_of_steps; // total number of steps this motor can take
int pin_count; // whether you're driving the motor with 2 or 4 pins
int step_number; // which step the motor is on
// motor pin numbers:
int motor_pin_1;
int motor_pin_2;
int motor_pin_3;
int motor_pin_4;
unsigned long last_step_time; // time stamp in ms of when the last step was taken
int isWaiting; //signal of waiting
int isEightShot; //Eight-shot two-phase stepper motor
#endif
