查看: 2941|回復(fù): 2
STM32英文版ADC編程思路
ID:274548 發(fā)表于 2018-1-10 21:51 | 顯示全部樓層 |閱讀模式
STM32平臺(tái)完成一次ADC芯片的編程的過程對(duì)于一個(gè)菜鳥來說實(shí)在可怕
Power-up;
Delayto allow power supplies to settle and power-up reset to complete (minimum of 50µs);
Configurethe SPI interface of the stm32 to SPI mode 1 (CPOL = 0, CPHA = 1);
Ifthe CS pin is not tied low permanently, configure the stm32 GPIO connected toCS as an
output;
Configurethe stm32 GPIO connected to the DRDY pin as a falling edge triggered interrupt
input;
SetCS to the device low;
Delayfor a minimum of td(CSSC);
Sendthe RESET command (06h) to make sure the device is properly reset afterpower-up;
Delayfor a minimum of 50 µs + 32 · t(CLK);
Writethe respective register configuration with the WREG command (43h, 08h, 04h,10h, and 00h);
Asan optional sanity check, read back all configuration registers with the RREGcommand (23h);
Sendthe START/SYNC command (08h) to start converting in continuous conversion mode;
Delayfor a minimum of td(SCCS);
ClearCS to high (resets the serial interface);
Loop
Waitfor DRDY to transition low;
TakeCS low;
Send24 SCLK rising edges to read out conversion data on DOUT/DRDY;
ClearCS to high;
TakeCS low;
Sendthe POWERDOWN command (02h) to stop conversions and put the device in power-downmode;
ClearCS to high;
附錄一個(gè)菜鳥初次編程的ADC
ads1242.pdf
1.09 MB, 下載次數(shù): 16, 下載積分: 黑幣 -5
你大可一試的ADC芯片
參與人數(shù) 2黑幣 +55 收起 理由
DX3906 + 5 很給力!
ID:274730 發(fā)表于 2018-1-11 11:50 | 顯示全部樓層
謝謝分享謝謝分享aaaaaaaaaa
ID:274730 發(fā)表于 2018-1-11 11:51 | 顯示全部樓層
謝謝分享謝謝分享樓主
