本帖最后由 明遠智睿 于 2019-4-24 14:04 編輯
明遠智睿MY-IMX6-EK200 Linux-4.1.15 測試手冊
1 測試環(huán)境開發(fā)板型號:MY-IMX6-EK200-6Q-2G-16G 內核版本:Linux-4.1.15 文件系統(tǒng):L4115-fsl-image-qt5-myimx6a9.tar.bz2
2 網(wǎng)口測試
2.1 ETH0關閉 ETH1 # ifconfig eth1 down 配置 ETH0 # ifconfig eth0 192.168.137.81 使用 ping 進行測試 # ping 192.168.137.99 -c 2 -w 4
PING 192.168.137.99 (192.168.137.99) 56(84) bytes of data. 64 bytes from 192.168.137.99: icmp_seq=1 ttl=128 time=0.811 ms 64 bytes from 192.168.137.99: icmp_seq=2 ttl=128 time=0.324 ms
--- 192.168.137.99 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 999ms rtt min/avg/max/mdev = 0.324/0.567/0.811/0.244 ms
2.2 ETH1 測試關閉 ETH0 # ifconfig eth0 down 配置 ETH0 # ifconfig eth1 192.168.137.82 使用 ping 進行測試 # ping 192.168.137.99 -c 2 -w 4
PING 192.168.137.99 (192.168.137.99) 56(84) bytes of data. 64 bytes from 192.168.137.99: icmp_seq=1 ttl=128 time=1.54 ms 64 bytes from 192.168.137.99: icmp_seq=2 ttl=128 time=4.03 ms
--- 192.168.137.99 ping statistics --- 2 packets transmitted, 2 received, 0% packet loss, time 1001ms rtt min/avg/max/mdev = 1.546/2.792/4.039/1.247 ms
3 USB 測試插入U盤 usb 1-1.2: new high-speed USB device number 5 using ci_hdrc usb-storage 1-1.2:1.0: USB Mass Storage device detected scsi host1: usb-storage 1-1.2:1.0 scsi 1:0:0:0: Direct-Access TOSHIBA TransMemory 1.00 PQ: 0 ANSI: 4 sd 1:0:0:0: [sda] 15148608 512-byte logical blocks: (7.75 GB/7.22 GiB) sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA sda: sda4 sd 1:0:0:0: [sda] Attached SCSI removable disk 拔出U盤 usb 1-1.2: USB disconnect, device number 5
4 SD卡測試插入SD卡 mmcblk2: mmc2:1234 SA02G 1.83 GiB mmcblk2: 彈出SD卡 mmc2: card 1234 removed
5 標準 GPIO 測試EIM_A25__GPIO5_IO02 J7:4
EIM_D23__GPIO3_IO23 J1:12
EIM_D28__GPIO3_IO28 J1:8
EIM_D29__GPIO3_IO29 J1:10
EIM_D30__GPIO3_IO30 J21:12
SD1_CLK__GPIO1_IO20 J4:8
SD1_DAT0__GPIO1_IO16 J14:18
SD2_CMD__GPIO1_IO11 J4:13
SD2_CLK__GPIO1_IO10 J4:7
SD2_DAT0__GPIO1_IO15 J4:3
SD2_DAT1__GPIO1_IO14 J4:5
SD2_DAT2__GPIO1_IO13 J4:9
SD2_DAT3__GPIO1_IO12 J4:11
SD3_DAT5__GPIO7_IO00 J21:11
GPIO_19__GPIO4_IO05 J7:3
# OUT_IO_NUMBER=85 # echo ${OUT_IO_NUMBER} > /sys/class/gpio/export # echo out > /sys/class/gpio/gpio${OUT_IO_NUMBER}/direction # echo 0 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value # echo 1 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value
6 GPIO-LED 測試led-heartbeat 說明:led-heartbeat 連接到 D8,系統(tǒng)啟動后可以看到 D8 在有規(guī)律的閃爍。 led-timer 說明:led-timer 連接到 D9,系統(tǒng)啟動后可以看到 D9 在有規(guī)律的閃爍。 更改 led-timer (D9) 滅的時間 # echo 1000 > /sys/class/leds/led-timer/delay_off 更改 led-timer (D9) 亮的時間 # echo 2000 > /sys/class/leds/led-timer/delay_on led-default 使 led-default (D7) 滅 echo 0 > /sys/class/leds/default/brightness 使 led-default (D7) 常亮 echo 1 > /sys/class/leds/default/brightness led-gpio 使 led-gpio (D10) 滅 echo 0 > /sys/class/leds/gpio/brightness 使 led-gpio (D10) 常亮 echo 1 > /sys/class/leds/gpio/brightness
7 GPIO-KEY 測試運行 evtest 準備測試 # evtest No device specified, trying to scan all of /dev/input/event* Available devices: /dev/input/event0: WM8962 Beep Generator /dev/input/event1: gpio-keys Select the device event number [0-1]: 選擇 gpio-keys 所對應的序號 Select the device event number [0-1]: 1
Input driver version is 1.0.1 Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100 Input device name: "gpio-keys" Supported events: Event type 0 (EV_SYN) Event type 1 (EV_KEY) Event code 114 (KEY_VOLUMEDOWN) Event code 115 (KEY_VOLUMEUP) Event code 116 (KEY_POWER) Properties: Testing ... (interrupt to exit) 按動開發(fā)板上的按鍵 Event: time 1537921332.815219, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1 Event: time 1537921332.815219, -------------- SYN_REPORT ------------ Event: time 1537921332.985211, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0 Event: time 1537921332.985211, -------------- SYN_REPORT ------------ Event: time 1537921335.355204, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1 Event: time 1537921335.355204, -------------- SYN_REPORT ------------ Event: time 1537921335.535203, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0 Event: time 1537921335.535203, -------------- SYN_REPORT ------------ Event: time 1537921337.375207, type 1 (EV_KEY), code 116 (KEY_POWER), value 1 Event: time 1537921337.375207, -------------- SYN_REPORT ------------ Event: time 1537921337.535204, type 1 (EV_KEY), code 116 (KEY_POWER), value 0 Event: time 1537921337.535204, -------------- SYN_REPORT ------------
【下章節(jié)MY-IMX6-EK200 Linux-4.1.15 測試手冊(2)】
