樓主: eagler8
【Arduino】108種傳感器模塊系列實驗(資料+代碼+圖形+仿真)
ID:513258 發(fā)表于 2019-7-5 17:01 | 只看該作者
ID:513258 發(fā)表于 2019-7-5 17:04 | 只看該作者
ID:513258 發(fā)表于 2019-7-5 17:06 | 只看該作者
ID:513258 發(fā)表于 2019-7-5 17:08 | 只看該作者
ID:513258 發(fā)表于 2019-7-5 18:08 | 只看該作者
ID:513258 發(fā)表于 2019-7-5 18:10 | 只看該作者
ID:513258 發(fā)表于 2019-7-5 18:38 | 只看該作者
  1. /*
  2. 【Arduino】66種傳感器模塊系列實驗(48)
  3. 實驗四十八:GY-291 數(shù)字三軸重力加速度傾斜度模塊 (IIC/SPI傳輸)
  4. 實驗代碼之三
  5. */
  6. #include <Wire.h>
  7. #define Register_ID 0
  8. #define Register_2D 0x2D
  9. #define Register_X0 0x32
  10. #define Register_X1 0x33
  11. #define Register_Y0 0x34
  12. #define Register_Y1 0x35
  13. #define Register_Z0 0x36
  14. #define Register_Z1 0x37
  15. int ADXAddress = 0xA7 >> 1;
  16. int reading = 0;
  17. int val=0;
  18. int X0,X1,X_out;
  19. int Y0,Y1,Y_out;
  20. int Z1,Z0,Z_out;
  21. double Xg,Yg,Zg;
  22. void setup()
  23. {
  24.    Wire.begin();
  25.    Serial.begin(9600);
  26.    delay(100);
  27.
  28.    Wire.beginTransmission(ADXAddress);
  29.    Wire.write(Register_2D);
  30.    Wire.write(8);
  31.    Wire.endTransmission();
  32. }
  33. void loop()
  34. {
  35.
  36.    Wire.beginTransmission(ADXAddress);
  37.    Wire.write(Register_X0);
  38.    Wire.write(Register_X1);
  39.    Wire.endTransmission();
  40.    Wire.requestFrom(ADXAddress,2);
  41.    if(Wire.available()<=2)
  42.    {
  43.      X0 = Wire.read();
  44.      X1 = Wire.read();
  45.      X1=X1<<8;
  46.      X_out=X0+X1;
  47.    }
  48.
  49.    Wire.beginTransmission(ADXAddress);
  50.    Wire.write(Register_Y0);
  51.    Wire.write(Register_Y1);
  52.    Wire.endTransmission();
  53.    Wire.requestFrom(ADXAddress,2);
  54.    if(Wire.available()<=2)
  55.    {
  56.      Y0 = Wire.read();
  57.      Y1 = Wire.read();
  58.      Y1=Y1<<8;
  59.      Y_out=Y0+Y1;
  60.    }
  61.
  62.    Wire.beginTransmission(ADXAddress);
  63.    Wire.write(Register_Z0);
  64.    Wire.write(Register_Z1);
  65.    Wire.endTransmission();
  66.    Wire.requestFrom(ADXAddress,2);
  67.    if(Wire.available()<=2)
  68.    {
  69.      Z0 = Wire.read();
  70.      Z1 = Wire.read();
  71.      Z1=Z1<<8;
  72.      Z_out=Z0+Z1;
  73.    }
  74.
  75.     Xg=X_out;
  76.     Yg=Y_out;
  77.     Zg=Z_out;
  78.    Serial.print("X= ");
  79.    Serial.print(Xg);
  80.    Serial.print("       ");
  81.    Serial.print("Y= ");
  82.    Serial.print(Yg);
  83.    Serial.print("       ");
  84.    Serial.print("Z= ");
  85.    Serial.print(Zg);
  86.    Serial.println("  ");
  87.    delay(200);
  88. }
ID:513258 發(fā)表于 2019-7-5 18:41 | 只看該作者
ID:513258 發(fā)表于 2019-7-5 18:43 | 只看該作者
ID:513258 發(fā)表于 2019-7-7 15:51 | 只看該作者
實驗四十九:有源蜂鳴器報警器發(fā)聲模塊 (低電平觸發(fā))
壓電陶瓷片
壓電陶瓷片,俗稱蜂鳴片。壓電陶瓷片是一種電子發(fā)音元件,在兩片銅制圓形電極中間放入壓電陶瓷介質(zhì)材料,當(dāng)在兩片電極上面接通交流音頻信號時,壓電片會根據(jù)信號的大小頻率發(fā)生震動而產(chǎn)生相應(yīng)的聲音來。壓電陶瓷片由于結(jié)構(gòu)簡單造價低廉,被廣泛的應(yīng)用于電子電器方面如:玩具,發(fā)音電子表,電子儀器,電子鐘表,定時器等方面。超聲波電機就是利用相關(guān)的性質(zhì)制成的。
ID:513258 發(fā)表于 2019-7-7 16:13 | 只看該作者
工作原理
當(dāng)電壓作用于壓電陶瓷時,就會隨電壓和頻率的變化產(chǎn)生機械變形。另一方面,當(dāng)振動壓電陶瓷時,則會產(chǎn)生一個電荷。利用這一原理,當(dāng)給由兩片壓電陶瓷或一片壓電陶瓷和一個金屬片構(gòu)成的振動器,所謂叫雙壓電晶片元件,施加一個電信號時,就會因彎曲振動發(fā)射出超聲波。相反,當(dāng)向雙壓電晶片元件施加超聲振動時,就會產(chǎn)生一個電信號。基于以上作用,便可以將壓電陶瓷用作超聲波傳感器。
ID:513258 發(fā)表于 2019-7-7 16:32 | 只看該作者
壓電蜂鳴器
是一種電聲轉(zhuǎn)換器件。將壓電材料粘貼在金屬片上,當(dāng)壓電材料和金屬片兩端施加上一個電壓后,因為逆壓電效應(yīng),蜂鳴片就會產(chǎn)生機械變形而發(fā)出聲響。壓電材料有多種,用在蜂鳴片上的壓電材料通常是高壓極化后的壓電陶瓷片。壓電式蜂鳴器通常呈圓形,由壓電陶瓷片、引線和共鳴腔組成。而中間的壓電陶瓷片又由金屬鍍層、陶瓷片、膠水、金屬片構(gòu)成。從電學(xué)角度來看,壓電陶瓷可以簡化為一個電感和一個電容的串聯(lián)模型。壓電式蜂鳴器具有體積小、靈敏度高、耗電省、可靠性好,造價低廉的特點和良好的頻率特性。因此它廣泛應(yīng)用于各種電器產(chǎn)品的報警、發(fā)聲用途。最常見的莫過于音樂賀卡、電子手表、袖珍計算器、電子門鈴和電子玩具等小型電子用品上作發(fā)聲器件。
ID:513258 發(fā)表于 2019-7-7 16:42 | 只看該作者
主要優(yōu)點
  1、因無可動觸點部分,因此壽命長、可靠性高,連續(xù)使用可達10000小時以上,是半永久性的器件
  2、不產(chǎn)生飛弧或者射頻噪聲,對其他線路無干擾
  3、不會因松動而引起大的振動
  4、用電子線路控制,所以能發(fā)出多種悅耳的聲音及模擬聲、斷續(xù)聲。音色純正,不易被噪聲所覆蓋
  5、用電壓激勵,所以消耗電流小,一般在20mA以下,不會超過100mA
  6、小型大音量。音量可達到70分貝/20cm,而元件厚度僅為1mm以下
  7、工作溫度范圍寬
  8、便于安裝,而且無電磁線圈和動圈,不必?fù)?dān)心絕緣惡化,并無漏電的可能
ID:513258 發(fā)表于 2019-7-7 17:07 | 只看該作者
有源壓電蜂鳴器
是一種一體化結(jié)構(gòu)的電子訊響器,采用直流電壓供電,廣泛應(yīng)用于計算機、打印機、復(fù)印機、報警器、電子玩具、汽車電子設(shè)備、電話機、定時器等電子產(chǎn)品中作發(fā)聲器件。蜂鳴器在電路中用字母“H”或“HA”(舊標(biāo)準(zhǔn)用“FM”、“LB”、“JD”等)表示。主要由多諧振蕩器、壓電蜂鳴片、阻抗匹配器及共鳴箱、外殼等組成。有的壓電式蜂鳴器外殼上還裝有發(fā)光二極管。多諧振蕩器由晶體管或集成電路構(gòu)成。當(dāng)接通電源后(1.5~15V直流工作電壓),多諧振蕩器起振,輸出1.5~2.5kHZ的音頻信號,阻抗匹配器推動壓電蜂鳴片發(fā)聲。有源蜂鳴器的優(yōu)點是,程序控制方便。
ID:513258 發(fā)表于 2019-7-7 17:12 | 只看該作者
如何區(qū)分有源和無源蜂鳴器
大家要了解有源和無源這里的“源”不是指電源,而是指震蕩源。也就是說,有源蜂鳴器內(nèi)部帶震蕩源,所以只要一通電就會叫。而無源內(nèi)部不帶震蕩源,所以如果用直流信號無法令其鳴叫。必須用2K~5K的方波去驅(qū)動它。有源蜂鳴器往往比無源的貴,就是因為里面多個震蕩電路。實際是指驅(qū)動方式分類,有源驅(qū)動和無源驅(qū)動,有源蜂鳴器又稱為直流蜂鳴器,其內(nèi)部已經(jīng)包含了一個多諧振蕩器,只要在兩端施加額定直流電壓即可發(fā)聲,具有驅(qū)動、控制簡單的特點,但價格略高。無源蜂鳴器又稱為交流蜂鳴器,內(nèi)部沒有振蕩器,需要在其兩端施加特定頻率的方波電壓(注意并不是交流,即沒有負(fù)極性電壓)才能發(fā)聲,具有可靠、成本低、發(fā)聲頻率可調(diào)整等特點。
外觀上看
兩種蜂鳴器好像一樣,但仔細(xì)看,兩者的高度略有區(qū)別,有源蜂鳴器a,高度為9mm,而無源蜂鳴器b的高度為8mm。如將兩種蜂鳴器的引腳郡朝上放置時,可以看出有綠色電路板的一種是無源蜂鳴器,沒有電路板而用黑膠封閉的一種是有源蜂鳴器。
萬用表測電阻區(qū)別
用萬用表電阻檔Rxl檔測試:用黑表筆接蜂鳴器 "+"引腳,紅表筆在另一引腳上來回碰觸,如果觸發(fā)出咔、咔聲的且電阻只有8Ω(或16Ω)的是無源蜂鳴器;如果能發(fā)出持續(xù)聲音的,且電阻在幾百歐以上的,是有源蜂鳴器。同時有源蜂鳴器直接接上額定電源(新的蜂鳴器在標(biāo)簽上都有注明)就可連續(xù)發(fā)聲;而無源蜂鳴器則和電磁揚聲器一樣,需要接在音頻輸出電路中才能發(fā)聲。
ID:513258 發(fā)表于 2019-7-7 17:22 | 只看該作者
有源蜂鳴器模塊(低電平觸發(fā))
ID:513258 發(fā)表于 2019-7-7 17:40 | 只看該作者
模塊電原理圖
ID:513258 發(fā)表于 2019-7-7 17:43 | 只看該作者
模塊描述
1 模塊采用S8050三極管驅(qū)動
2 工作電壓3.3V-5V
3 設(shè)有固定螺栓孔,方便安裝
4 小板PCB尺寸:3.2cm * 1.3cm
5 當(dāng)I/O口輸入低電平時,蜂鳴器發(fā)聲
ID:513258 發(fā)表于 2019-7-7 17:47 | 只看該作者
模塊接口說明(3線制)
1 VCC 外接3.3V-5V電壓(可以直接與5v單片機和3.3v單片機相連)
2 GND 外接GND
3 I/O (out)外接Arduino數(shù)字端口
ID:513258 發(fā)表于 2019-7-7 17:50 | 只看該作者
ID:513258 發(fā)表于 2019-7-7 18:51 | 只看該作者
  1. /*
  2. 【Arduino】66種傳感器模塊系列實驗(49)
  3. 實驗四十九:有源蜂鳴器報警器發(fā)聲模塊 (低電平觸發(fā))
  4. 按鍵按下發(fā)聲,LED亮暗反轉(zhuǎn)
  5. */
  6. #define LED 13
  7. #define KEY 2
  8. #define BUZZER 3
  9. int KEY_NUM = 0;
  10. void setup() {
  11.   pinMode(LED,OUTPUT);
  12.   pinMode(KEY,INPUT_PULLUP);
  13.   pinMode(BUZZER,OUTPUT);
  14.   digitalWrite(BUZZER,HIGH);
  15. }
  16. void loop() {
  17.   ScanKey();
  18.   if(KEY_NUM==1)
  19.   {
  20.     digitalWrite(LED,!digitalRead(LED));
  21.   }
  22. }
  23. void ScanKey()
  24. {
  25.    KEY_NUM = 0;
  26.     if(digitalRead(KEY)==LOW)
  27.     {
  28.       delay(20);
  29.       if(digitalRead(KEY)==LOW)
  30.       {
  31.         KEY_NUM=1;
  32.         buzzer_Di();
  33.         while(digitalRead(KEY)==LOW);
  34.       }
  35.     }
  36.   }
  37.
  38.   void buzzer_Di()
  39.   {
  40.   digitalWrite(BUZZER,LOW);
  41.   delay(100);
  42.   digitalWrite(BUZZER,HIGH);
  43.   }
ID:513258 發(fā)表于 2019-7-7 18:56 | 只看該作者
ID:513258 發(fā)表于 2019-7-7 19:12 | 只看該作者
ID:513258 發(fā)表于 2019-7-7 19:20 | 只看該作者
ID:513258 發(fā)表于 2019-7-7 19:59 | 只看該作者
實驗五十:W25Q64 64Mbit FLASH外擴存儲模塊 (SPI接口 )
W25X64
該系列是華邦公司推出的大容量SPI FLASH 產(chǎn)品,W25X64 的容量為 64Mbit(8M),該系列還有 W25Q80/16/32 等W25X16、W25X32、W25X64分別有8192、16384、32768個可編程頁,每頁256字節(jié),用扇區(qū)擦除指令每次可以擦除16頁,用塊擦除指令每次可以擦除256頁,用整片擦除指令既可以擦除整個芯片,W25X16、W25X32、W25X64分別有512、1024、2048個可擦除扇區(qū),或者32、64、128個可擦除的塊。W25Q64 的擦寫周期多達 10W 次,具有 20 年的數(shù)據(jù)保存期限,支持電壓為 2.7~3.6V,W25Q64 支持標(biāo)準(zhǔn)的 SPI,還支持雙輸出/四輸出的 SPI,最大 SPI 時鐘可以到 80Mhz(雙輸出時相當(dāng)于 160Mhz,四輸出時相當(dāng)于 320M)。
ID:513258 發(fā)表于 2019-7-7 20:05 | 只看該作者
SPI總線
SPI,是英語Serial Peripheral Interface的縮寫,顧名思義就是串行外圍設(shè)備接口。SPI,是一種高速的,全雙工,同步的通信總線,并且在芯片的管腳上只占用四根線,節(jié)約了芯片的管腳,同時為PCB的布局上節(jié)省空間,提供方便,正是出于這種簡單易用的特性,現(xiàn)在越來越多的芯片集成了這種通信協(xié)議。SPI是一個環(huán)形總線結(jié)構(gòu),由ss(cs)、sck、sdi、sdo構(gòu)成,其時序其實很簡單,主要是在sck的控制下,兩個雙向移位寄存器進行數(shù)據(jù)交換。上升沿發(fā)送、下降沿接收、高位先發(fā)送。上升沿到來的時候,sdo上的電平將被發(fā)送到從設(shè)備的寄存器中。下降沿到來的時候,sdi上的電平將被接收到主設(shè)備的寄存器中。
SPI總線是Motorola公司推出的三線同步接口,同步串行3線方式進行通信:一條時鐘線SCK,一條數(shù)據(jù)輸入線MOSI,一條數(shù)據(jù)輸出線MISO;用于 CPU與各種外圍器件進行全雙工、同步串行通訊。SPI主要特點有:可以同時發(fā)出和接收串行數(shù)據(jù);可以當(dāng)作主機或從機工作;提供頻率可編程時鐘;發(fā)送結(jié)束中斷標(biāo)志;寫沖突保護;總線競爭保護等。
ID:513258 發(fā)表于 2019-7-7 20:23 | 只看該作者
SPI 數(shù)據(jù)速率一般在1到70MHz的范圍內(nèi),字長為從8位及12位到這兩個值的倍數(shù)。數(shù)據(jù)傳輸一般由數(shù)據(jù)交換構(gòu)成。在主控制器向從設(shè)備發(fā)送數(shù)據(jù)時,從設(shè)備也向主控制器發(fā)送數(shù)據(jù)。因此主控制器的內(nèi)部移位寄存器和從設(shè)備都采用環(huán)形設(shè)置。在數(shù)據(jù)交換之前,主控制器和從設(shè)備會將存儲器數(shù)據(jù)加載至它們的內(nèi)部移位寄存器。收到時鐘信號后,主控制器先通過MOSI線路時鐘輸出其移位寄存器的MSB。同時從設(shè)備會讀取位于SIMO的主控器第一位元,將其存儲在存儲器中,然后通過SOMI時鐘輸出其MSB。主控制器可讀取位于MISO的從設(shè)備第一位元,并將其存儲在存儲器中,以便后續(xù)處理。整個過程將一直持續(xù)到所有位元完成交換,而主控器則可讓時鐘空閑并通過/SS 禁用從設(shè)備。
ID:513258 發(fā)表于 2019-7-7 20:27 | 只看該作者
在 SPI 中,主控制器可與單個或多個從設(shè)備通信。如果是一個單從設(shè)備,從設(shè)備選擇信號可連接至從設(shè)備的本地接地電位,實現(xiàn)永久接入。對使用多個從設(shè)備的應(yīng)用,可使用兩種配置:獨立從設(shè)備與菊花鏈從設(shè)備。要與從設(shè)備單獨通信,主控制器必須提供多重從設(shè)備選擇信號。該配置通常用于必須單獨訪問多個模數(shù)轉(zhuǎn)換器 (ADC) 及數(shù)模轉(zhuǎn)換器 (DAC) 的數(shù)據(jù)采集系統(tǒng)中。菊花鏈從設(shè)備只需要主控制器提供一個從設(shè)備選擇信號,因為這種配置要求所有從設(shè)備同時啟用,以確保數(shù)據(jù)不間斷地流經(jīng)該鏈路中的所有移位寄存器。典型應(yīng)用是工業(yè) I/O 模塊中的級聯(lián)多通道輸入串行器與輸出驅(qū)動器。注意,菊花鏈連接不一定適用于所有的SPI設(shè)備,特別是要求多字節(jié)傳輸?shù)模ū热绱鎯ζ餍酒┰O(shè)備。另外,要對外設(shè)芯片的數(shù)據(jù)表進行仔細(xì)分析,確定能對它做什么而不能做什么。如果芯片的數(shù)據(jù)表中沒有明確提到菊花鏈連接,那么該芯片不支持這種連接的幾率為50%。
ID:513258 發(fā)表于 2019-7-7 20:39 | 只看該作者
W25Q64FWSSIG參數(shù)
功能數(shù)量        1 端子數(shù)量        8
最大工作溫度        85 Cel
最小工作溫度        -40 Cel
最大供電/工作電壓        1.95 V
最小供電/工作電壓        1.65 V
額定供電電壓        1.8 V
最大時鐘頻率        104 MHz
加工封裝描述        0.208 INCH, GREEN, SOIC-8 狀態(tài)        ACTIVE 工藝        CMOS
包裝形狀 SQUARE
包裝尺寸        SMALL OUTLINE
表面貼裝        Yes
端子形式        GULL WING
端子間距        1.27 mm
端子位置        DUAL
包裝材料 PLASTIC/EPOXY
溫度等級        INDUSTRIAL
內(nèi)存寬度        1 組織        64M X 1
存儲密度        6.41E7 deg
操作模式        SYNCHRONOUS
位數(shù) 6.41E7 words
位數(shù)        64M
內(nèi)存IC類型        FLASH 1.8V PROM
串行并行        SERIAL
ID:513258 發(fā)表于 2019-7-7 20:44 | 只看該作者
ID:513258 發(fā)表于 2019-7-8 09:04 | 只看該作者
W25Q64引腳
CS:CS為片選管腳,低電平有效。上電之后,在執(zhí)行一條新的指令之前,必須讓/CS管腳先有一個下降沿。
DO(MISO):DO為串行數(shù)據(jù)輸出引腳,在CLK(串行時鐘)管腳的下降沿輸出數(shù)據(jù)。
WP:WP為寫保護管腳,有效電平為低電平。高電平可讀可寫,低電平僅僅可讀。
DI(MOSI):DI為串行數(shù)據(jù)輸入引腳,數(shù)據(jù)、地址和命令從DI引腳輸入到芯片內(nèi)部,在CLK(串行時鐘)管腳的上升沿捕獲捕獲數(shù)據(jù)。
CLK(SLCK):CLK為串行時鐘引腳。SPI時鐘引腳,為輸入輸出提供時鐘脈沖。
HOLD:HOLD為保持管腳,低電平有效。當(dāng)CS為低電平,并且把HOLD拉低時,數(shù)據(jù)輸出管腳將保持高阻態(tài),并且會忽略數(shù)據(jù)輸入管腳和時鐘管腳上的信號。把HOLD管腳拉高,器件恢復(fù)正常工作。
VCC:電源2.7V~3.6V。
GND:地。
W25Q64內(nèi)部框架圖
ID:513258 發(fā)表于 2019-7-8 09:11 | 只看該作者
W25Q64操作原理
通過SPI接口,用標(biāo)準(zhǔn)的SPI協(xié)議發(fā)送相應(yīng)指令給flash,然后flash根據(jù)命令進行各種相關(guān)操作。
W25Q64常用操作命令
ID:282095 發(fā)表于 2019-7-8 09:40 | 只看該作者
漲知識了
ID:513258 發(fā)表于 2019-7-8 09:56 | 只看該作者
ID:513258 發(fā)表于 2019-7-8 11:13 | 只看該作者
ID:513258 發(fā)表于 2019-7-8 11:26 | 只看該作者
ID:513258 發(fā)表于 2019-7-8 11:28 | 只看該作者
謝謝老師的鼓勵!
ID:513258 發(fā)表于 2019-7-8 14:26 | 只看該作者
模塊接口定義
CS:為片選信號腳---D10
DI(MOSI):為串行數(shù)據(jù)輸入引腳----D11
DO(MISO):為串行數(shù)據(jù)輸出引腳---D12
CLK(SLCK):SPI總線---D13
VCC:  電源3.3V
GND:接地
ID:513258 發(fā)表于 2019-7-8 14:32 | 只看該作者
奈何師傅的實驗代碼
  1. /*
  2. 【Arduino】66種傳感器模塊系列實驗(50)
  3. 實驗五十:W25Q64 64Mbit FLASH外擴存儲模塊 (SPI接口 )
  4. Arduino 的 uno 引腳
  5. CS----------10
  6. MOSI(DI)---11
  7. MISO(DO)---12
  8. CLK---------13
  9. VCC 3.3V
  10. */
  11. #include <SerialFlash.h>
  12. #include <SPI.h>
  13. // 文件大小
  14. #define FSIZE 256
  15. // 文件名
  16. const char *filename = "Eagler8.txt";
  17. // 文件內(nèi)容
  18. const char *contents = "The groundbreaking Intel Curie module expands the possibilities of what tech can do.";
  19. // 片選引腳
  20. const int FlashChipSelect = 10;
  21. void setup() {
  22.   Serial.begin(9600);
  23.   while (!Serial) ;
  24.   delay(500);
  25.   // 初始化SPI Flash芯片
  26.   SerialFlash.begin(FlashChipSelect);
  27.   // 如果文件已存在,則輸出提示
  28.   // 如果文件不存在,則創(chuàng)建文件并寫入
  29.   if(SerialFlash.exists(filename)) {
  30.       Serial.println("File " + String(filename) + " already exists");
  31.   }
  32.   else {
  33.       Serial.println("Creating file " + String(filename));
  34.       SerialFlash.create(filename, FSIZE);
  35.       // 新建SerialFlashFile對象用于文件操作
  36.       SerialFlashFile file;
  37.       file = SerialFlash.open(filename);
  38.       file.write(contents, strlen(contents) + 1);
  39.       Serial.println("String \"" + String(contents) + "\" written to file " + String(filename));
  40.   }
  41. }
  42. void loop() {
  43. }
ID:513258 發(fā)表于 2019-7-8 14:36 | 只看該作者
