查看: 6558|回復: 9
STM32示波器程序ILI9341_IO模擬源程序+Proteus仿真
ID:623452 發(fā)表于 2020-6-25 19:07 | 顯示全部樓層 |閱讀模式
設計要求:見圖片
uint8 x_1= 0,y_1 = 0;
        uint8 x_2= 0,y_2 = 0;
        uint8 x_3= 0,y_3 = 0;
        uint8 x_4= 0,y_4 = 0;
        uint8 x_5= 0,y_5 = 0;
        uint8 t4_PianYi_x = 0,t4_PianYi_y = 0;
        uint8 t5_PianYi_x = 0,t5_PianYi_y = 0;
        int i  = 0 ;
                for( i= 0;i<t1*3;i++)
                {                 x_1 = 10+ i;
                                y_1 = bmp_PianYi_y-x_1*1;
                        GUI_DrawPoint(x_1,y_1-10,BLUE);//AD
                        GUI_DrawPoint(x_1,y_1,BRRED);
                for( i=0;i<10;i++)
                                GUI_DrawPoint(x_1,200-i,BLACK);
                        Show_Str(x_1-(t1*3)/2,200,BLACK,GRAY,"t1",12,1);
                                x_2 = x_1;
                                y_2 = y_1;
                for( i = 0;i<t2*3;i++ )
                        x_2 ++;
                        GUI_DrawPoint(x_2,y_2-10,BLUE);//AD
                        GUI_DrawPoint(x_2,y_2,BRRED);
                                for( i=0;i<10;i++)
                                GUI_DrawPoint(x_2,200-i,BLACK);
                        Show_Str(x_2-(t2*3)/2,200,BLACK,GRAY,"t2",12,1);
                x_3=x_2;  y_3 =y_2;
                for( i= 0;i<t3*3;i++)
                        x_3 ++ ;
                        y_3 = y_3 - 1;   //1ÎaÏμêy
                        GUI_DrawPoint(x_3,y_3-10,BLUE);//AD
                        GUI_DrawPoint(x_3,y_3,BRRED);
                                for( i=0;i<10;i++)
                                GUI_DrawPoint(x_3,200-i,BLACK);
                        Show_Str(x_3-(t3*3)/2,200,BLACK,GRAY,"t3",12,1);
                t4_PianYi_x = x_3 + (t4*3)/2;
                                t4_PianYi_y = y_3 + (((t4/2)*3)*((t4/2)*3)*0.07);
                for( i = - (t4/2)*3;i< (t4/2)*3 ; i++ )
                        x_4 = t4_PianYi_x+i;
                        y_4 = t4_PianYi_y+(- i*i*0.07);//1ÎaÏμêy
                        GUI_DrawPoint(x_4,y_4-10,BLUE);//AD
                        GUI_DrawPoint(x_4,y_4,BRRED);
                for( i=0;i<10;i++)
                                GUI_DrawPoint(x_4,200-i,BLACK);
                        Show_Str(x_4-(t4*3)/2,200,BLACK,GRAY,"t4",12,1);                t5_PianYi_x = x_4 + (t5*3)/2;
                t5_PianYi_y = y_4 +  pow(0.92, -(t5*3)/2);
        //        LCD_DrawLine(100, 10, 100, 200);
                for( i = - (t5*3)/2;i< (t5*3)/2 ; i++ )
                        x_5= t5_PianYi_x + i;
                        y_5 = t5_PianYi_y - pow(0.92,i );
                        GUI_DrawPoint(x_5,y_5-10,BLUE);//AD
                        GUI_DrawPoint(x_5,y_5,BRRED);
                for( i=0;i<10;i++)
                                GUI_DrawPoint(x_5,200-i,BLACK);
                        Show_Str(x_5-(t5*3)/2,200,BLACK,GRAY,"t5",12,1);
                for(i = 0;i<10;i++ )
                        {GUI_DrawPoint(20+i,210,BLUE);  Show_Str(30,210,BLUE,YELLOW,"AD",12,0);        }
                        {GUI_DrawPoint(20+i,222,BRRED); Show_Str(30,222,BRRED,YELLOW,"DA",12,0);  }
             for(i= 0;i<10;i++)
                        {  GUI_DrawPoint(10+i,200-50,BLACK); Show_Str(0,200-50,BLACK,GRAY,"1",12,1);   }
                for(i= 0;i<10;i++)
                        {  GUI_DrawPoint(10+i,200-100,BLACK); Show_Str(0,200-100,BLACK,GRAY,"2",12,1);   }
                for(i= 0;i<10;i++)
                        {  GUI_DrawPoint(10+i,200-150,BLACK); Show_Str(0,200-150,BLACK,GRAY,"3",12,1);   }
Keil代碼與Proteus仿真下載(程序模擬示波器畫面,無AD采集等功能 如果需要請自行添加):
kese1.7z (367.91 KB, 下載次數: 215)
參與人數 1黑幣 +50 收起 理由
admin + 50 共享資料的黑幣獎勵!
ID:563242 發(fā)表于 2020-7-9 11:25 | 顯示全部樓層
請問,“++”和“--”這兩個按鍵是實現什么功能呢?我按沒有任何反應。
ID:623452 發(fā)表于 2020-7-30 11:44 | 顯示全部樓層
文件運行后,點擊  creat  按鈕→進入下一個界面→ select  按鈕 選擇參數
ID:89414 發(fā)表于 2020-7-31 07:41 | 顯示全部樓層
正在學習中,感謝樓主分享
ID:848028 發(fā)表于 2020-11-23 21:06 來自觸屏版 | 顯示全部樓層
你好,能發(fā)我一下這個proteus的仿真視頻嗎?大神
ID:623452 發(fā)表于 2020-12-28 16:58 | 顯示全部樓層
zylove 發(fā)表于 2020-7-9 11:25
按  select按鈕!
ID:880136 發(fā)表于 2022-4-11 12:51 | 顯示全部樓層
這個程序只是個畫圖的,功能還有待完善,程序里面連個AD采集都沒有,
ID:101305 發(fā)表于 2022-4-11 20:26 | 顯示全部樓層
仿真的和實際還是有區(qū)別的
ID:117977 發(fā)表于 2022-5-5 16:49 | 顯示全部樓層
值得研究。感謝。
Powered by 單片機教程網
