下面是源代碼:
程序名: MUSIC 電子琴程序
編寫人: droomfly
硬件支持: STC12c5a60s2 外部12MHZ晶振 電源5V
void INIT(void);
#include <STC12C5A60S2.h>
#include <intrins.h>
sbit SPEAKER = P1^0;//揚(yáng)聲器,低使能
sbit LED = P1 ^ 4; //液晶屏背光定義(PWM控制,不能更改)
sbit SID = P3 ^ 3; //數(shù)據(jù) //LCD接口定義
sbit SCLK = P3 ^ 2; //時鐘 //LCD接口定義
//鍵盤引腳定義
sbit KEY_1 = P0^0; //A
sbit KEY_1_GND = P0^2; //地
sbit KEY_2 = P0^5; //B
sbit KEY_2_GND = P0^7; //地
sbit KEY_3 = P2^7; //C
sbit KEY_3_GND = P2^5; //地
sbit KEY_4 = P2^2; //D
sbit KEY_4_GND = P2^0; //地
unsigned char MUSIC;
unsigned char STH0,STL0;
unsigned int code tab[]={ //音階表
63628,63835,64021,64103,64260,64400,64524, //低音1-7
64580,64684,64777,64820,64898,64968,65030, //中音1-7
65058,65110,65157,65178,65217,65252,65283 //高音1-7
數(shù)組圖片字模
寬度x高度=128x64 魔音開機(jī)圖
unsigned char code tab1[]={
/*-- 調(diào)入了一幅圖像:C:\Users\Administrator\Desktop\MUSIC\logo-music-0.bmp --*/
/*-- 寬度x高度=128x64 --*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xC0,0x0F,0xFF,0xFC,0x00,0x7F,0xFF,0xE0,0x07,0xFF,0xFE,0x00,0x1F,0xFF,0xC0,0x03,
0xC0,0x00,0xFF,0xE0,0x00,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x00,0x07,0xFF,0x00,0x03,
0xC0,0x00,0xFF,0xE0,0x00,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x00,0x00,0x00,0x00,0x03,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0xCC,0xD8,0x63,0xE0,0xD9,0xD9,0x9C,0xC3,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x0A,0x44,0x6C,0x91,0x00,0x66,0x48,0x94,0x44,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x0C,0x44,0x44,0xF1,0x00,0x44,0x48,0x98,0x44,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x02,0x44,0x44,0x81,0x00,0x44,0x48,0x84,0x44,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x0A,0x44,0x44,0x91,0x00,0x44,0x48,0x94,0x44,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x0E,0x7E,0x78,0x63,0x80,0xEE,0xEF,0xDC,0xE3,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
數(shù)組圖片字模
寬度x高度=128x64 魔音按鍵1
unsigned char code tab2[]={
/*-- 調(diào)入了一幅圖像:C:\Users\Administrator\Desktop\MUSIC\logo-music-1.bmp --*/
0xC0,0x03,0xFF,0xF8,0x00,0x7F,0xFF,0xE0,0x07,0xFF,0xFE,0x00,0x3F,0xFF,0xF0,0x03,
0xC0,0x00,0x00,0x00,0x00,0x0F,0xFE,0x00,0x00,0x7F,0xF0,0x00,0x07,0xFF,0x00,0x03,
數(shù)組圖片字模
寬度x高度=128x64 魔音按鍵2
unsigned char code tab3[]={
/*-- 調(diào)入了一幅圖像:C:\Users\Administrator\Desktop\MUSIC\logo-music-2.bmp --*/
0xC0,0x0F,0xFF,0xFC,0x00,0x3F,0xFF,0x80,0x07,0xFF,0xFE,0x00,0x3F,0xFF,0xF0,0x03,
0xC0,0x00,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x7F,0xF0,0x00,0x07,0xFF,0x00,0x03,
數(shù)組圖片字模
寬度x高度=128x64 魔音按鍵3
unsigned char code tab4[]={
/*-- 調(diào)入了一幅圖像:C:\Users\Administrator\Desktop\MUSIC\logo-music-3.bmp --*/
0xC0,0x0F,0xFF,0xFC,0x00,0x7F,0xFF,0xE0,0x01,0xFF,0xFC,0x00,0x3F,0xFF,0xF0,0x03,
0xC0,0x00,0xFF,0xE0,0x00,0x0F,0xFE,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0x00,0x03,
數(shù)組圖片字模
寬度x高度=128x64 魔音按鍵4
unsigned char code tab5[]={
/*-- 調(diào)入了一幅圖像:C:\Users\Administrator\Desktop\MUSIC\logo-music-4.bmp --*/
數(shù)組圖片字模
寬度x高度=128x64 魔音按鍵歸位
unsigned char code tab6[]={
/*-- 調(diào)入了一幅圖像:C:\Users\Administrator\Desktop\MUSIC\logo-music1.bmp --*/
0xC0,0x0F,0xFF,0xFC,0x00,0x7F,0xFF,0xE0,0x07,0xFF,0xFE,0x00,0x3F,0xFF,0xF0,0x03,
void delay1ms (unsigned int a){ // 1ms延時程序(12MHz 10倍于51單片機(jī)速度時)
unsigned int i;
while( --a != 0){
for(i = 0; i < 600; i++);
函數(shù)名:LCD12864底層驅(qū)動程序(串行接口)
調(diào) 用:lcm_w_byte();
參 數(shù):要發(fā)送的字節(jié)數(shù)據(jù)
返回值:無
結(jié) 果:發(fā)送一個字節(jié)給LCM
備 注:
//發(fā)送一個字節(jié)(底層函數(shù))
void lcm_w_byte(unsigned char bbyte) {
unsigned char i;
for(i=0;i<8;i++){
SID=bbyte&0x80; //取出最高位
SCLK=1;
SCLK=0;
bbyte<<=1; //左移
函數(shù)名:寫指令或數(shù)據(jù)函數(shù)
調(diào) 用:lcm_w_test(?,?);
參 數(shù):(位,字節(jié));位:0指令,1數(shù)據(jù);
返回值:無
結(jié) 果:
備 注:
void lcm_w_test(bit start, unsigned char ddata) {
unsigned char start_data,Hdata,Ldata;
if(start==0){
start_data=0xf8; //0:寫指令
}else{
start_data=0xfa; //1:寫數(shù)據(jù)
Hdata=ddata&0xf0; //取高四位
Ldata=(ddata<<4)&0xf0; //取低四位
lcm_w_byte(start_data); //發(fā)送起始信號
delay1ms(1); //延時是必須的
lcm_w_byte(Hdata); //發(fā)送高四位
lcm_w_byte(Ldata); //發(fā)送低四位
//清屏函數(shù)
void lcm_clr(void){
lcm_w_test(0,0x01);
delay1ms(20); //啟動等待,等LCM講入工作狀態(tài)
//向LCM發(fā)送一個字符串,長度64字符之內(nèi)。
//應(yīng)用:lcm_w_word("您好!");
void lcm_w_word(unsigned char *str){
while(*str != '\0'){
lcm_w_test(1,*str++);
} *str = 0;
//全屏繪圖函數(shù) FT4增加函數(shù)
//應(yīng)用:定義tab[],,直接調(diào)用LCD_12864_P(tab);
void LCD_12864_P(unsigned char *a) //顯示圖片函數(shù) (a的長度一定要大于64*16)
unsigned char i,j,k,temp;
lcm_w_test(0,0x34);//擴(kuò)充指令
lcm_w_test(0,0x36);//繪圖顯示開
for(i=0;i<2;i++)
if(i==0) //畫上半屏
temp=0;
temp=8; //畫下半屏
for(j=0;j<32;j++)
lcm_w_test(0,(0x80+j)); //設(shè)置垂直地址(以位為單位,對應(yīng)的行號)
lcm_w_test(0,(0x80+temp));//設(shè)置水平地址(以字節(jié)單位,對應(yīng)的列號)指針可自增
for(k=0;k<16;k++)
lcm_w_test(1,*a++);
lcm_w_test(0,0x30);//基本指令
//初始化LCM
void lcm_init(void) {
delay1ms(200); //啟動等待,等LCM講入工作狀態(tài)
lcm_w_test(0,0x30); //8 位介面,基本指令集
lcm_w_test(0,0x0c); //顯示打開,光標(biāo)關(guān),反白關(guān)
lcm_w_test(0,0x01); //清屏,將DDRAM的地址計數(shù)器歸零
void INIT(void){//初始化程序
TMOD=0x11;
ET0=1;
ET1=1;
EA=1;
P3M0 = 0xFF;//強(qiáng)推
P3M1 = 0x00;//高阻
P1M0 = 0xF7;//強(qiáng)推
P1M1 = 0x00;//高阻
P1ASF= 0x00;
P4SW = 0XFF;
P4M1 = 0x00;//強(qiáng)推
P4M0 = 0x60;//高阻
KEY_1_GND = 0;
KEY_2_GND = 0;
KEY_3_GND = 0;
KEY_4_GND = 0;
SPEAKER = 1;
LED = 0;
void main(void){ //MUSIC值域0~20
INIT(); //初始化
lcm_init();//初始化液晶顯示器
lcm_clr();//清屏
LCD_12864_P(tab1);
delay1ms(1000);
while(1){
if(KEY_1 == 0){delay1ms(20);if(KEY_1 == 0){MUSIC = 15;LCD_12864_P(tab5);}} //高音B(37)
if(KEY_2 == 0){delay1ms(20);if(KEY_2 == 0){MUSIC = 13;LCD_12864_P(tab4);}}
if(KEY_3 == 0){delay1ms(20);if(KEY_3 == 0){MUSIC = 20;LCD_12864_P(tab3);}}
if(KEY_4 == 0){delay1ms(20);if(KEY_4 == 0){MUSIC = 19;LCD_12864_P(tab2);}}
if(MUSIC != 0xff){ //如果有音階數(shù)值(非0XFF時)
STH0=tab[MUSIC]/256; //將音階的頻率值裝入定時器T0
STL0=tab[MUSIC]%256;
TR0=1; //啟動定時器
MUSIC = 0xff; //清除寄存器
}else{ //否則
SPEAKER = 1; //關(guān)揚(yáng)聲器
TR0=0; //關(guān)定時器
LCD_12864_P(tab6);
void t0(void) interrupt 1 using 0{//定時器0產(chǎn)生音頻
TH0=STH0;
TL0=STL0;
SPEAKER=~SPEAKER; //取反頻率產(chǎn)生音調(diào)
