查看: 2849|回復(fù): 0
倒計(jì)時(shí)99s(創(chuàng)新版)程序
ID:72519 發(fā)表于 2015-1-22 02:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
//--定義使用的IO口--//
#define GPIO_DIG   P0
sbit shi=P1^1;
sbit ge=P1^0;
//--定義全局變量--//
unsigned char code DIG_CODE[17] = {
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
//0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F的顯示碼
unsigned char DisplayData[8];
//用來存放要顯示的8位數(shù)的值
unsigned char Time, Second;                  //用來存放定時(shí)時(shí)間
//--聲明全局函數(shù)--//
void DigDisplay(); //動(dòng)態(tài)顯示函數(shù)
void Timer0Cofig(void);
void main(void)
        Second = 1;
        Timer0Cofig();
                if(Second == 101)
                        Second = 1;
                if(Second < 101)
                        DisplayData[0] = DIG_CODE[(100-Second) % 100 / 10];
                        DisplayData[1] = DIG_CODE[(100-Second) %10];
                        DigDisplay();
void DigDisplay()
        unsigned char i;
        unsigned int j;
        for(i=0; i<2; i++)
           if(i==0)
           shi=0;
           ge=1; //如果這里不改動(dòng),那么顯示會(huì)重復(fù),覆蓋
                else if(i==1)
           {shi=1;//現(xiàn)在改為了單刀雙擲開關(guān)就好了
           ge=0;
                GPIO_DIG = DisplayData;     //發(fā)送段碼
                j = 10;                                                   //掃描間隔時(shí)間設(shè)定
                while(j--);
                GPIO_DIG = 0x00;               //消隱
        TMOD = 0x01;     //定時(shí)器0選擇工作方式1
    TH0  = 0x3C;        //設(shè)置初始值,定時(shí)50MS
    TL0  = 0xB0;
    EA   = 1;             //打開總中斷
    ET0  = 1;                //打開定時(shí)器0中斷
    TR0  = 1;                //啟動(dòng)定時(shí)器0
void Timer0() interrupt 1
        TL0 = 0xB0;
        Time++;
        if(Time == 4)
                Second ++;
                Time = 0;
