說明:第二部分為驅(qū)動程序核心部分,需要第二部分:http://www.torrancerestoration.com/bbs/dpj-31563-1.html
第二部分LCD.h文件:
LCD.h文件
#ifndef __LCD_H__
#define __LCD_H__
#define TESTBIT(a,b) ((a)&(1<<(b)))
#define LCD_RS_Low() LPC_GPIO2->DATA &=~(1<<8) //給P2.8位寫0
#define LCD_RS_High() LPC_GPIO2->DATA |=(1<<8) //給P2.8位寫1
#define LCD_RW_Low() LPC_GPIO2->DATA &=~(1<<9) //給P2.9位寫0
#define LCD_RW_High() LPC_GPIO2->DATA |=(1<<9) //給P2.9位寫1
#define LCD_EN_Low() LPC_GPIO2->DATA &=~(1<<10) //給P2.10位寫0
#define LCD_EN_High() LPC_GPIO2->DATA |=(1<<10) //給P2.10位寫1
void Set_GPIO_Output(void);
void Set_GPIO_Input(void);
void LCD_GPIO_Init(void);
void Write_Data_Port(unsigned char Data);
unsigned char Read_Data_Port(void);
unsigned char Chk_LCD_busy(void);
void Write_LCD_command(unsigned char gcmd,unsigned char gvalue);
void Write_LCD_data(unsigned char gdata);
void INIT_LCD(void);
void Display_LCD_string(unsigned char gadd_start,unsigned char gline,unsigned char glength,const unsigned char *pdata);
void DispChar_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void DispNum_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void Clear_Display(void);
#endif
system_LPX11xx.c(時鐘配置程序)
#include <stdint.h>
#include "LPC11xx.h"
#define CLOCK_SETUP 0
#define MAIN_PLL_SETUP 0
#define MAIN_CLKSRCSEL_Val 0x00000001
#define MAIN_PLL_M_Val 0x00000003
#define MAIN_PLL_P_Val 0x00000001
#define SYS_AHB_DIV_Val 4/* 1 through 255, typical is 1 or 2 or 4 */
//-------- <<< end of configuration section >>> ------------------------------
DEFINES
Define clocks
#define XTAL (12000000UL) /* Oscillator frequency */
#define OSC_CLK ( XTAL) /* Main oscillator frequency */
#define IRC_OSC (12000000UL) /* Internal RC oscillator frequency */
#define WDT_OSC ( 250000UL) /* WDT oscillator frequency */
Clock Variable definitions
uint32_t ClockSource = IRC_OSC;
uint32_t SystemFrequency = IRC_OSC; /*!< System Clock Frequency (Core Clock) */
uint32_t SystemAHBFrequency = IRC_OSC;
* Misc. clock generation modules
* @param none
* @return none
* @brief Setup the microcontroller system.
* Initialize the System and update the SystemFrequency variable.
void Main_PLL_Setup ( void )
uint32_t regVal;
ClockSource = OSC_CLK;
LPC_SYSCON->SYSPLLCLKSEL = MAIN_CLKSRCSEL_Val; /* Select system OSC--PLL時鐘源選中系統(tǒng)振蕩器 */
LPC_SYSCON->SYSPLLCLKUEN = 0x01; /* Update clock source */
LPC_SYSCON->SYSPLLCLKUEN = 0x00; /* toggle Update register once */
while ( !(LPC_SYSCON->SYSPLLCLKUEN & 0x01) ); /* Wait until updated 等待系統(tǒng)振蕩器鎖定*/
regVal = LPC_SYSCON->SYSPLLCTRL;
regVal &= ~0x1FF;
LPC_SYSCON->SYSPLLCTRL = (regVal | (MAIN_PLL_P_Val<<5) | MAIN_PLL_M_Val);/* P=1, M=4 */
/* Enable main system PLL, main system PLL bit 7 in PDRUNCFG. */
LPC_SYSCON->PDRUNCFG &= ~(0x1<<7); /* PDRUNCFG第七位寫0,即系統(tǒng)PLL上電 */
while ( !(LPC_SYSCON->SYSPLLSTAT & 0x01) ); /* Wait until it's locked */
LPC_SYSCON->MAINCLKSEL = 0x01; /* Select PLL clock output--選擇PLL輸出作為主時鐘 */
LPC_SYSCON->MAINCLKUEN = 0x01; /* Update MCLK clock source --允許更新主時鐘*/
LPC_SYSCON->MAINCLKUEN = 0x00; /* Toggle update register once */
while ( !(LPC_SYSCON->MAINCLKUEN & 0x01) ); /* Wait until updated 等待主時鐘鎖定*/
LPC_SYSCON->SYSAHBCLKDIV = SYS_AHB_DIV_Val; /* SYS AHB clock, typical is 1 or 2 or 4 --SYSAHBCLKDIV的值為1,即不分頻 AHB時鐘為12*4=48MHz*/
#if MAIN_PLL_SETUP
SystemFrequency = ClockSource * (MAIN_PLL_M_Val+1); /*系統(tǒng)時鐘=時鐘源*4MHz*/
#else
SystemFrequency = ClockSource;
#endif
SystemAHBFrequency = (uint32_t)(SystemFrequency/SYS_AHB_DIV_Val); /*AHB時鐘=系統(tǒng)時鐘/AHB分頻值*/
return;
* Initialize the system
* @param none
* @return none
void SystemInit (void)
//uint32_t i;
#ifdef __DEBUG_RAM
LPC_SYSCON->SYSMEMREMAP = 0x1;/* remap to internal RAM */
#else
#ifdef __DEBUG_FLASH
LPC_SYSCON->SYSMEMREMAP = 0x2;/* remap to internal flash */
#endif
#endif
#if (CLOCK_SETUP) /* Clock Setup */
/* bit 0 default is crystal bypass,
bit1 0=0~20Mhz crystal input, 1=15~50Mhz crystal input. */
LPC_SYSCON->SYSOSCCTRL = 0x01;
/* main system OSC run is cleared, bit 5 in PDRUNCFG register */
LPC_SYSCON->PDRUNCFG &= ~(0x1<<5); /* PDRUNCFG的第五位寫0,即系統(tǒng)系統(tǒng)振蕩器上電 */
/* Wait 200us for OSC to be stablized, no status
indication, dummy wait. */
for ( i = 0; i < 0x100; i++ );
#if (MAIN_PLL_SETUP)
Main_PLL_Setup();
#endif
#endif/* endif CLOCK_SETUP */
/* System clock to the IOCON needs to be enabled or
most of the I/O related peripherals won't work. */
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<16); //使能IO配置模塊的時鐘
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8); //開啟定時器Timer16_1時鐘
return;
main.c程序:
#include "LPC11XX.h"
#include "gpio.h"
#include "timer16.h"
#include "main.h"
#include "Delay.h"
#include "LCD.h"
#include "Key.h"
const unsigned char P[] = {"Bei-Jing"};
int main(void)
SystemInit(); //系統(tǒng)初始化--主要是設(shè)置主時鐘和開啟所需模塊時鐘
GPIOInit(); //GPIO初始化--主要是開啟GPIO時鐘
LPC_IOCON->PIO0_3 &= (~0x07); //設(shè)置P2.0為GPIO
LPC_GPIO0->DIR |= (0x1<<3); //設(shè)置P0.3為輸出
INIT_LCD();
DispChar_XY_LCD(15, 0, 'A'); //顯示A
DispChar_XY_LCD(15, 1, 'Y'); //顯示Y
Display_LCD_string(1, 0, 8, P);
Display_LCD_string(1, 1, 8, P);
GPIOSetValue( 0, 3, 0 ); //給P0.3位寫0
Delay_Ms(1000); //延時
GPIOSetValue( 0, 3, 1 ); //給P0.3位寫1
Delay.c程序:(延時程序使用Timer16_1實現(xiàn))
#include "gpio.h"
#include "Delay.h"
/*系統(tǒng)時鐘配置為48MHz,AHB不分頻,一次定時器時鐘為48Mhz,因此得出以下分頻值,匹配值*/
void Delay_Us(unsigned int DelayTimes) /** setup timer #1 for delay */
//LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8); /*開啟定時器Timer16_1時鐘--時鐘配置中開啟該時鐘*/
LPC_TMR16B1->TCR = 0x02; /* reset timer */
LPC_TMR16B1->PR = 3; /* set prescaler to zero 根據(jù)AHB時鐘確定分頻值*/
LPC_TMR16B1->MR0 = DelayTimes; /* 所需的延時時間 */
LPC_TMR16B1->IR = 0xff; /* reset all interrrupts 復位所有的中斷*/
LPC_TMR16B1->MCR = 0x04; /* stop timer on match --達到匹配停止*/
LPC_TMR16B1->TCR = 0x01; /* start timer 啟動定時器*/
while (LPC_TMR16B1->TCR & 0x01); /*等待直到時間到*/
LPC_TMR16B1->TCR = 0x00; /* Close timer --關(guān)閉定時器*/
void Delay_Ms(unsigned int DelayTimes) /** setup timer #1 for delay */
//LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8); //開啟定時器Timer16_1時鐘
LPC_TMR16B1->PR = 3000; /* set prescaler to zero */
LPC_TMR16B1->IR = 0xff; /* reset all interrrupts */
LPC_TMR16B1->MCR = 0x04; /* stop timer on match */
LPC_TMR16B1->TCR = 0x01; /* start timer */
LPC_TMR16B1->TCR = 0x00; /* Close timer */
void Delay_Sec(unsigned int DelayTimes) /* * setup timer #1 for delay */
LPC_TMR16B1->PR = 3000000; /* set prescaler to zero */
Delay.h程序:(延時程序使用Timer16_1實現(xiàn))
#ifndef __DELAY_H__
#define __DELAY_H__
void Delay_Us(unsigned int DelayTimes); /*微秒延時函數(shù)*/
void Delay_Ms(unsigned int DelayTimes); /*毫秒延時函數(shù)*/
void Delay_Sec(unsigned int DelayTimes); /*秒延時函數(shù)*/
#endif
