#include <reg51.h>
#include <intrins.h>
#include <stdlib.h>
/* 端口定義*/
#define LCD_data P0 //數(shù)據(jù)口
sbit LCD_RS = P1^0; //寄存器選擇輸入
sbit LCD_RW = P1^1; //液晶讀/寫控制
sbit LCD_EN = P1^5; //液晶使能控制
sbit LCD_PSB = P3^7; //串/并方式控制
sbit wela = P2^6;
sbit dula = P2^7;
uchar dis1[10];
uchar code dis2[] = {"www*txmcu*com"};
uchar code dis3[] = {"天祥電子"};
uchar code dis4[] = {"--------"};
void delay_1ms(uint x)
uint i,j;
for(j=0;j<x;j++)
for(i=0;i<110;i++);
/*寫指令數(shù)據(jù)到LCD */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
void write_cmd(uchar cmd)
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
P0 = cmd;
delay_1ms(5);
LCD_EN = 1;
delay_1ms(5);
LCD_EN = 0;
/*寫顯示數(shù)據(jù)到LCD */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。 */
void write_dat(uchar dat)
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delay_1ms(5);
LCD_EN = 1;
delay_1ms(5);
LCD_EN = 0;
/* 設(shè)定顯示位置 */
void lcd_pos(uchar X,uchar Y)
uchar pos;
if (X==0)
{X=0x80;}
else if (X==1)
{X=0x90;}
else if (X==2)
{X=0x88;}
else if (X==3)
{X=0x98;}
pos = X+Y ;
write_cmd(pos); //顯示地址
void makerand()
uint ran;
ran=rand();
dis1[0]=ran/10000+0x30;
dis1[1]=ran%10000/1000+0x30;
dis1[2]=ran%1000/100+0x30;
dis1[3]=ran%100/10+0x30;
dis1[4]=ran%10+0x30;
ran=rand();
dis1[5]=ran/10000+0x30;
dis1[6]=ran%10000/1000+0x30;
dis1[7]=ran%1000/100+0x30;
dis1[8]=ran%100/10+0x30;
dis1[9]=ran%10+0x30;
/* LCD初始化設(shè)定 */
void lcd_init()
LCD_PSB = 1; //并口方式
write_cmd(0x30); //基本指令操作
delay_1ms(5);
write_cmd(0x0C); //顯示開,關(guān)光標(biāo)
delay_1ms(5);
write_cmd(0x01); //清除LCD的顯示內(nèi)容
delay_1ms(5);
/* 主程序 */
main()
uchar i;
wela=0;
dula=0;
delay_1ms(10); //延時
lcd_init(); //初始化LCD
lcd_pos(1,0); //設(shè)置顯示位置為第二行的第1個字符
i = 0;
while(dis2[i] != '\0')
write_dat(dis2[i]); //顯示字符
i++;
lcd_pos(2,0); //設(shè)置顯示位置為第三行的第1個字符
i = 0;
while(dis3[i] != '\0')
write_dat(dis3[i]); //顯示字符
i++;
lcd_pos(3,0); //設(shè)置顯示位置為第四行的第1個字符
i = 0;
while(dis4[i] != '\0')
write_dat(dis4[i]); //顯示字符
i++;
lcd_pos(0,0); //設(shè)置顯示位置為第一行的第1個字符
makerand();
for(i=0;i<10;i++)
write_dat(dis1[i]);
