查看: 5059|回復(fù): 0
STM32F103ZE學(xué)習之GPIO口的設(shè)置
ID:75926 發(fā)表于 2015-4-10 17:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
     void GPIO_Configuration()
GPIO_InitTypeDef      GPIO_InitStructure;//定義有關(guān)GPIO設(shè)置的結(jié)構(gòu)體 做GPIO_Init()的參數(shù);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//打開GPIOB的時鐘
       GPIO_InitStructure.GPIO_Pin=GPIO_Pin0;//選擇0管腳
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHZ;//選擇輸出速率為50MHZ
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
//選擇管腳的模式為推挽式輸出(GPIO_Mode_AIN 模擬輸入 .GPIO_Mode_IN_FLOATING 浮空輸入 .GPIO_Mode_IPD 下拉輸入. GPIO_Mode_IPU 上拉輸入.GPIO_Mode_Out_OD 開漏輸出. GPIO_Mode_Out_PP 推挽輸出.GPIO_Mode_AF_OD 復(fù)用開漏輸出 .GPIO_Mode_AF_PP 復(fù)用推挽輸出.)
       GPIO_Init(GPIOB,&GPIO_InitStructure);調(diào)用GPIO_Init函數(shù)設(shè)置管腳的參數(shù)
