//連線表: CPU=89C52 *
//RS=P3.0 RW=P3.1 E=P3.2 CS1=3.3 CS2=3.4 CS3=3.5 *
//FOSC=12MHz D0-D7=P1.0-P1.7 *
#include<reg52.h>
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
sbit CS1=P2^3;
sbit CS2=P2^4;
sbit CS3=P2^5;
sbit busy=P1^7;
sbit RST=P2^6;
#define DATA_BUS P1
void wr_lcd_1(unsigned char dat_com,unsigned char content);
void wr_lcd_2(unsigned char dat_com,unsigned char content);
void wr_lcd_3(unsigned char dat_com,unsigned char content);
void ck_busy(void);
void delay_us(unsigned int us_value);
void delay_ms(unsigned int ms_value);
void init_lcd (void);
void disp_dots(unsigned char data1,unsigned char data2);
void disp_img(unsigned char code *img);
void clr_ram(void);
void main(void);
unsigned char code img1[];
char code han[]={
/*-- 文字: 漢 --*/
/*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
0x10,0x60,0x01,0x86,0x60,0x04,0x1C,0xE4,0x04,0x04,0x04,0xE4,0x1C,0x04,0x00,0x00,
0x04,0x04,0x7E,0x01,0x40,0x20,0x20,0x10,0x0B,0x04,0x0B,0x10,0x30,0x60,0x20,0x00,
char code sheng[]={
/*-- 文字: 升 --*/
0x00,0x40,0x44,0x44,0x44,0xFE,0x42,0x42,0x40,0x40,0xFE,0x40,0x40,0x60,0x40,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00,
char code shi[]={
/*-- 文字: 實(shí) --*/
0x00,0x10,0x0C,0x04,0x4C,0xB4,0x94,0x05,0xF6,0x04,0x04,0x04,0x14,0x0C,0x04,0x00,
0x00,0x82,0x82,0x42,0x42,0x23,0x12,0x0A,0x07,0x0A,0x12,0xE2,0x42,0x02,0x02,0x00,
char code ye[]={
/*-- 文字: 業(yè) --*/
0x00,0x10,0x60,0x80,0x00,0xFF,0x00,0x00,0x00,0xFF,0x00,0x80,0x60,0x38,0x10,0x00,
0x20,0x20,0x20,0x23,0x21,0x3F,0x20,0x20,0x20,0x3F,0x22,0x21,0x20,0x30,0x20,0x00,
char code you[]={
/*-- 文字: 有 --*/
0x00,0x04,0x84,0x44,0xE4,0x34,0x2C,0x27,0x24,0x24,0x24,0xE4,0x04,0x04,0x04,0x00,
0x02,0x01,0x00,0x00,0xFF,0x09,0x09,0x09,0x29,0x49,0xC9,0x7F,0x00,0x00,0x00,0x00,
char code xian[]={
/*-- 文字: 限 --*/
0xFE,0x02,0x32,0x4E,0x82,0x00,0xFE,0x4A,0xCA,0x4A,0x4A,0x4A,0x7E,0x00,0x00,0x00,
0xFF,0x00,0x02,0x04,0x03,0x00,0xFF,0x40,0x20,0x03,0x0C,0x12,0x21,0x60,0x20,0x00,
char code gong[]={
/*-- 文字: 公 --*/
0x00,0x00,0x80,0x40,0x30,0x0E,0x84,0x00,0x00,0x0E,0x10,0x60,0xC0,0x80,0x80,0x00,
0x00,0x01,0x20,0x70,0x28,0x24,0x23,0x31,0x10,0x10,0x14,0x78,0x30,0x01,0x00,0x00,
char code si[]={
/*-- 文字: 司 --*/
0x00,0x10,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x12,0x02,0x02,0xFE,0x00,0x00,
0x00,0x00,0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x0F,0x00,0x20,0x40,0x3F,0x00,0x00,
char code huan[]={
/*-- 文字: 歡 --*/
0x14,0x24,0x44,0x84,0x64,0x1C,0x20,0x18,0x0F,0xE8,0x08,0x08,0x28,0x18,0x08,0x00,
0x20,0x10,0x4C,0x43,0x43,0x2C,0x20,0x10,0x0C,0x03,0x06,0x18,0x30,0x60,0x20,0x00
char code ying[]={
/*-- 文字: 迎 --*/
0x40,0x41,0xCE,0x04,0x00,0xFC,0x04,0x02,0x02,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
0x40,0x20,0x1F,0x20,0x40,0x47,0x42,0x41,0x40,0x5F,0x40,0x42,0x44,0x43,0x40,0x00
char code nin[]={
/*-- 文字: 您 --*/
0x80,0x40,0x30,0xFC,0x03,0x90,0x68,0x06,0x04,0xF4,0x04,0x24,0x44,0x8C,0x04,0x00,
0x00,0x20,0x38,0x03,0x38,0x40,0x40,0x49,0x52,0x41,0x40,0x70,0x00,0x09,0x30,0x00
*函數(shù)名稱(chēng): init_lcd
*功能描述: 初始化
wr_lcd_1(0,0xc0);
wr_lcd_1(0,0x3f);
wr_lcd_2(0,0xc0);
wr_lcd_2(0,0x3f);
wr_lcd_3(0,0xc0);
wr_lcd_3(0,0x3f);
*函數(shù)名稱(chēng):wr_lcd_1
*功能描述:左屏寫(xiě)入指令/數(shù)據(jù)子程序
CS1=0;
CS2=1;
CS3=1;
ck_busy();
if(dat_com)
RS = 1; //data
RW = 0; //write
RS = 0; //com
RW = 0; //write
P1=content; //iutput data or com
E = 1;
E = 0;
*函數(shù)名稱(chēng):wr_lcd_2
*功能描述:中屏寫(xiě)入指令/數(shù)據(jù)子程序
CS1=1;
CS2=0;
CS3=1;
ck_busy();
if(dat_com)
RS = 1; //data
RW = 0; //write
RS = 0; //com
RW = 0; //write
E = 1;
E = 0;
*函數(shù)名稱(chēng):wr_lcd_3
*功能描述:右屏寫(xiě)入指令/數(shù)據(jù)子程序
CS1=1;
CS2=1;
CS3=0;
ck_busy();
if(dat_com)
RS = 1; //data
RW = 0; //write
RS = 0; //com
RW = 0; //write
E = 1;
E = 0;
*函數(shù)名稱(chēng):ck_busy
*功能描述:查忙子程序
void ck_busy(void)
P1 = 0xff;
RS = 0;
RW = 1;
E = 1;
while(busy==1);
E = 0;
*函數(shù)名稱(chēng):delay_us
*功能描述:延時(shí)us
void delay_us(unsigned int us_value) //delay time
while(us_value--);
*函數(shù)名稱(chēng):delay_ms
*功能描述:延時(shí)ms
unsigned int i,j;
for(i=0;i<ms_value;i++)
for(j=0;j<15;j++)
delay_us(1);
*函數(shù)名稱(chēng):Disp_dots
*功能描述:顯示點(diǎn)、橫、豎
unsigned char i,j;
for(j=0;j<8;j++)
for(i=0;i<32;i++)
wr_lcd_1(0,0xb8+j);
wr_lcd_1(0,0x40+i*2);
wr_lcd_1(1,data1);
wr_lcd_1(0,0x40+i*2+1);
wr_lcd_1(1,data2);
wr_lcd_2(0,0xb8+j);
wr_lcd_2(0,0x40+i*2);
wr_lcd_2(1,data1);
wr_lcd_2(0,0x40+i*2+1);
wr_lcd_2(1,data2);
wr_lcd_3(0,0xb8+j);
wr_lcd_3(0,0x40+i*2);
wr_lcd_3(1,data1);
wr_lcd_3(0,0x40+i*2+1);
wr_lcd_3(1,data2);
*函數(shù)名稱(chēng):disp_img
*功能描述:顯示圖片
unsigned char j,k;
for(k=0;k<8;k++)
for(j=0;j<64;j++)
wr_lcd_1(0,0xb8+k);
wr_lcd_1(0,0x40+j);
wr_lcd_1(1,img[k*192+j]);
for(j=64;j<128;j++)
wr_lcd_2(0,0xb8+k);
wr_lcd_2(0,0x40+j-64);
wr_lcd_2(1,img[k*192+j]);
for(j=128;j<192;j++)
wr_lcd_3(0,0xb8+k);
wr_lcd_3(0,0x40+j-128);
wr_lcd_3(1,img[k*192+j]);
*函數(shù)名稱(chēng):clr_ram
*功能描述:清除內(nèi)存
void clr_ram()
unsigned char j,k;
for(k=0;k<8;k++)
for(j=0;j<64;j++)
wr_lcd_1(0,0xb8+k);
wr_lcd_1(0,0x40+j);
wr_lcd_1(1,0);
wr_lcd_2(0,0xb8+k);
wr_lcd_2(0,0x40+j);
wr_lcd_2(1,0);
wr_lcd_3(0,0xb8+k);
wr_lcd_3(0,0x40+j);
wr_lcd_3(1,0);
*函數(shù)名稱(chēng): disp_cn_1
*功能描述: 左屏顯示單個(gè)漢字
void disp_cn_1(unsigned char code *cn,unsigned char page,unsigned char col)
unsigned char i,j;
for(j=0;j<2;j++)
for(i=0;i<16;i++)
wr_lcd_1(0,0xb8+page+j);
wr_lcd_1(0,0x40+col+i);
wr_lcd_1(1,cn[j*16+i]);
*函數(shù)名稱(chēng): disp_cn_2
*功能描述: 中屏顯示單個(gè)漢字
void disp_cn_2(unsigned char code *cn,unsigned char page,unsigned char col)
unsigned char i,j;
for(j=0;j<2;j++)
for(i=0;i<16;i++)
wr_lcd_2(0,0xb8+page+j);
wr_lcd_2(0,0x40+col+i);
wr_lcd_2(1,cn[j*16+i]);
*函數(shù)名稱(chēng): disp_cn_3
*功能描述: 右屏顯示單個(gè)漢字
void disp_cn_3(unsigned char code *cn,unsigned char page,unsigned char col)
unsigned char i,j;
for(j=0;j<2;j++)
for(i=0;i<16;i++)
wr_lcd_3(0,0xb8+page+j);
wr_lcd_3(0,0x40+col+i);
wr_lcd_3(1,cn[j*16+i]);
*函數(shù)名稱(chēng): main
*功能描述: 主程序
delay_ms(10);
RST=0;
delay_ms(5);
RST=1;
delay_ms(40);
init_lcd();
clr_ram();
disp_dots(0xff,0xff);
delay_ms(800);
disp_dots(0x55,0xaa);
delay_ms(800);
disp_dots(0xaa,0xaa);
delay_ms(800);
disp_dots(0x55,0x55);
delay_ms(800);
delay_ms(800);
disp_dots(0xff,0x00);
delay_ms(800);
disp_dots(0x00,0xff);
delay_ms(800);
clr_ram();
disp_cn_1(han,2,0);
disp_cn_1(sheng,2,16);
disp_cn_1(shi,2,32);
disp_cn_1(ye,2,48);
disp_cn_2(you,2,0);
disp_cn_2(xian,2,16);
disp_cn_2(gong,2,32);
disp_cn_2(si,2,48);
disp_cn_3(huan,2,0);
disp_cn_3(ying,2,16);
disp_cn_3(nin,2,32);
delay_ms(800);
clr_ram();
disp_img(img1);
delay_ms(800);
unsigned char code img1[]={
/*-- 調(diào)入了一幅圖像:E:\圖片\19264-1.bmp --*/
/*-- 寬度x高度=192x64 --*/
0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,
0xC0,0xE0,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0x20,0x60,0xE0,0xC0,0x80,0x00,0x00,
0xC0,0x60,0x60,0xE0,0xE0,0xC0,0x80,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,
0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0x40,0x60,0x20,0x20,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xE0,0x70,
0x3C,0x0C,0x1C,0x30,0x60,0xC0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFC,0xFC,0x84,0xE4,0x7C,0xFC,0xAC,0xA4,0xE4,0x64,0x24,0x04,0x04,0xFC,0xFC,0x00,
0x00,0x00,0x00,0x00,0x08,0x08,0xF8,0xF8,0x08,0x08,0xF8,0xF8,0x08,0x88,0xC8,0x60,
0x30,0x1C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,
0xFC,0xFC,0x20,0x20,0x20,0xA0,0xB0,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xF8,
0x88,0xE8,0x7C,0x3C,0x20,0xE0,0xF8,0x3C,0xAC,0xA0,0x20,0x20,0x30,0x10,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
0xFF,0xFF,0x00,0x00,0x00,0x00,0x07,0x0F,0x9F,0x98,0xF0,0x7F,0x3F,0x0F,0x00,0x00,
0x80,0xC0,0xA0,0x98,0x8F,0x87,0x83,0x40,0x00,0x00,0x40,0x21,0x12,0x0C,0x0C,0x12,
0x21,0x40,0x00,0x00,0x00,0x7C,0xFF,0xFF,0x83,0x06,0xFE,0xFC,0x78,0x00,0x00,0x38,
0x34,0x32,0x31,0xFF,0xFF,0xFF,0x30,0x00,0x00,0x04,0x06,0x03,0x01,0x23,0x22,0x22,
0x22,0xFE,0xFE,0x22,0x22,0x23,0x31,0x11,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0xFF,0x19,0x0C,0x44,0x4E,0x4B,0xDB,0xD6,0x84,0x0C,0x0C,0x00,0xFF,0xFF,0x00,
0x00,0x00,0x00,0x00,0x00,0xC2,0xFF,0x3F,0x02,0x02,0xFF,0xFF,0x13,0x11,0x19,0x0C,
0x86,0xC3,0x71,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0xA1,0xA1,
0x21,0x21,0xA1,0xA1,0x21,0x3F,0xBF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,
0x20,0x21,0x3F,0x7E,0x46,0x47,0x45,0x44,0xFF,0xFF,0x44,0x44,0x66,0x22,0x20,0x00,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,
0x01,0x01,0x01,0x01,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x02,0x02,0x02,0x02,0x02,0x02,
0x02,0x03,0x03,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,
0x03,0x03,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x03,0x03,0x00,
0x00,0x00,0x00,0x02,0x03,0x01,0x00,0x00,0x00,0x00,0x03,0x87,0x84,0x06,0x03,0x01,
0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x07,0x03,0x00,0x00,0x01,0x03,
0x02,0x00,0x01,0x03,0x02,0x00,0x00,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x07,0x07,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x60,0xC2,0x8E,0xEC,
0x60,0xC4,0xF4,0xBC,0x0C,0xE5,0xFF,0xDF,0x44,0xE4,0xE6,0x06,0x04,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x7F,0x7F,0x4A,0x4A,0x4A,0x4A,0x4A,0x7F,0x7F,0x01,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x92,0x92,0x92,0x92,0x92,0x92,
0x92,0x92,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x42,0x42,0x42,0x42,
0x42,0x42,0xC2,0xC2,0x42,0x42,0x42,0x42,0x42,0x62,0x20,0x00,0x00,0x00,0x00,0x00,
0x10,0xF0,0xFF,0xFF,0xDC,0x9C,0xF4,0xF4,0xAF,0xAF,0xA4,0xAF,0xAF,0xF4,0xF6,0x02,
0x00,0x00,0x00,0x00,0x20,0x20,0x20,0xFF,0xFF,0x30,0x30,0x30,0x10,0xFF,0xFF,0x11,
0x10,0x10,0xF8,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x90,0xFC,0xFF,0x07,
0x07,0xFF,0xFF,0x02,0x83,0xC7,0x7E,0x3B,0x7F,0xCF,0xC1,0x80,0x80,0x00,0x00,0x00,
0x00,0xFF,0xFF,0x92,0x92,0x92,0xFF,0xFF,0x01,0x00,0xFF,0xFF,0x92,0x92,0x92,0xFF,
0xFF,0x00,0x00,0x00,0x00,0x80,0x80,0x82,0x8E,0xBC,0xB0,0xFF,0xFF,0x81,0x80,0xFF,
0xFF,0xB0,0x98,0x8E,0xC6,0xC0,0x80,0x00,0x00,0x00,0x40,0x60,0x30,0x1C,0x0F,0x07,
0x81,0x80,0xFF,0xFF,0x00,0x01,0x03,0x06,0x1C,0x38,0x30,0x00,0x00,0x00,0x00,0x0C,
0x0F,0x03,0xFF,0xFF,0x01,0x11,0x97,0x97,0xF2,0x7E,0x1E,0x32,0x72,0xD3,0x9B,0x88,
0x88,0x00,0x00,0x00,0x20,0x30,0x30,0x1F,0x1F,0x9A,0xCA,0x6A,0x72,0x3F,0x0F,0x0E,
0x3A,0x72,0xE3,0xC3,0x82,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFF,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xFF
