#include <REG52.H>
#include <intrins.h>
uchar display[8][8];
/*rank:A,1,2,3,4,I,心,U*/
uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
/*the "ideasoft"*/
uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
/*railway*/
uchar code dat[128]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
/*railway 2*/
uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
/*railway 3*/
uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
/*3p char*/
uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
/*initializtion
That is to initialize the program .
It is write to set the timer in c52 mcu.
So the program can renovate the led_3d_cube in fixed time use the interrupt function.*/
void sinter()
IE=0x82;
TCON=0x01;
TH0=0xc0;
TL0=0;
TR0=1;
void delay5us(void) //誤差 -0.026765046296us STC 1T 22.1184Mhz
unsigned char a,b;
for(b=7;b>0;b--)
for(a=2;a>0;a--);
void delay(uint i)
while (i--){
delay5us();}//12t的mcu 注釋這個延時即可
/*To judge the num bit*/
uchar judgebit(uchar num,uchar b)
char n;
num=num&(1<<b);
if (num)
n=1;
n=0;
return n;
/*To figure out the round number*/
uchar abs(uchar a)
uchar b;
b=a/10;
a=a-b*10;
if (a>=5)
b++;
return b;
/*To figure out the absolute value*/
uchar abss(char a)
if (a<0)
a=-a;
return a;
/*The function can comparat the character.
And remove the big one to the back.*/
void max(uchar *a,uchar *b)
uchar t;
if ((*a)>(*b))
t=(*a);
(*a)=(*b);
(*b)=t;
/*The function is to figure out the max number and return it.*/
uchar maxt(uchar a,uchar b,uchar c)
if (a<b)
a=b;
if (a<c)
a=c;
return a;
void clear(char le)
uchar i,j;
for (j=0;j<8;j++)
for (i=0;i<8;i++)
display[j][i]=le;
void trailler(uint speed)
char i,j;
for (i=6;i>=-3;i--)
if (i>=0)
for (j=0;j<8;j++)
display[j][i]=display[j][i+1];
if (i<4)
for (j=0;j<8;j++)
display[j][i+4]=0;
delay(speed);
void point(uchar x,uchar y,uchar z,uchar le)
uchar ch1,ch0;
ch1=1<<x;
ch0=~ch1;
if (le)
display[z][y]=display[z][y]|ch1;
display[z][y]=display[z][y]&ch0;
void type(uchar cha,uchar y)
uchar xx;
for (xx=0;xx<8;xx++)
display[xx][y]=table_cha[cha][xx];
/*The first variable is the distance from the midpoint.
The second is the layer.
the third is the flash speed of the time between each two point.
The forth is the enable io,it controls weather draw or claen.*/
void cirp(char cpp,uchar dir,uchar le)
uchar a,b,c,cp;
if ((cpp<128)&(cpp>=0))
if (dir)
cp=127-cpp;
cp=cpp;
a=(dat[cp]>>5)&0x07;
b=(dat[cp]>>2)&0x07;
c=dat[cp]&0x03;
if (cpp>63)
c=7-c;
point (a,b,c,le);
void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
char t,a,b,c,a1,b1,c1,i;
a1=x2-x1;
b1=y2-y1;
c1=z2-z1;
t=maxt(abss(a1),abss(b1),abss(c1));
a=x1*10;
b=y1*10;
c=z1*10;
a1=a1*10/t;
b1=b1*10/t;
c1=c1*10/t;
for (i=0;i<t;i++)
point(abs(a),abs(b),abs(c),le);
a+=a1;
b+=b1;
c+=c1;
point(x2,y2,z2,le);
void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
uchar i,j,t=0;
max(&x1,&x2);
max(&y1,&y2);
max(&z1,&z2);
for (i=x1;i<=x2;i++)
t|=1<<i;
if (!le)
t=~t;
if (fill)
if (le)
for (i=z1;i<=z2;i++)
for (j=y1;j<=y2;j++)
display[j][i]|=t;
display[j][i]&=t;
if (le)
display[y1][z1]|=t;
display[y2][z1]|=t;
display[y1][z2]|=t;
display[y2][z2]|=t;
display[y1][z1]&=t;
display[y2][z1]&=t;
display[y1][z2]&=t;
display[y2][z2]&=t;
t=(0x01<<x1)|(0x01<<x2);
if (!le)
t=~t;
if (le)
for (j=z1;j<=z2;j+=(z2-z1))
for (i=y1;i<=y2;i++)
display[i][j]|=t;
for (j=y1;j<=y2;j+=(y2-y1))
display[j][i]|=t;
display[i][j]&=t;
display[j][i]&=t;
void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
uchar i;
max(&z1,&z2);
if (fill)
line (x1,y1,i,x2,y2,i,le);
line (x1,y1,z1,x2,y2,z1,le);
line (x1,y1,z2,x2,y2,z2,le);
line (x2,y2,z1,x2,y2,z2,le);
line (x1,y1,z1,x1,y1,z2,le);
void poke(uchar n,uchar x,uchar y)
uchar i;
for (i=0;i<8;i++)
point(x,y,i,judgebit(n,i));
void boxtola(char i,uchar n)
if ((i>=0)&(i<8))
poke(n,0,7-i);
if ((i>=8)&(i<16))
poke(n,i-8,0);
if ((i>=16)&(i<24))
poke(n,7,i-16);
void rolldisplay(uint speed)
uchar j;
char i,a;
for (i=23;i>-40;i--)
for (j=0;j<40;j++)
a=i+j;
if ((a>=0)&(a<24))
boxtola(a,table_id[j]);
delay(speed);
void roll_apeak_yz(uchar n,uint speed)
uchar i;
switch(n)
case 1:
for (i=0;i<7;i++)
display[i][7]=0;
display[7][6-i]=255;
delay(speed);
break;
case 2:
for (i=0;i<7;i++)
display[7][7-i]=0;
display[6-i][0]=255;
delay(speed);
break;
case 3:
for (i=0;i<7;i++)
display[7-i][0]=0;
display[0][i+1]=255;
delay(speed);
break;
case 0:
for (i=0;i<7;i++)
display[0][i]=0;
display[i+1][7]=255;
delay(speed);
void roll_apeak_xy(uchar n,uint speed)
uchar i;
switch(n)
case 1:
for (i=0;i<7;i++)
line(0,i,0,0,i,7,0);
line(i+1,7,0,i+1,7,7,1);
delay(speed);
break;
case 2:
for (i=0;i<7;i++)
line(i,7,0,i,7,7,0);
line(7,6-i,0,7,6-i,7,1);
delay(speed);
break;
case 3:
for (i=0;i<7;i++)
line(7,7-i,0,7,7-i,7,0);
line(6-i,0,0,6-i,0,7,1);
delay(speed);
break;
case 0:
for (i=0;i<7;i++)
line(7-i,0,0,7-i,0,7,0);
line(0,i+1,0,0,i+1,7,1);
delay(speed);
void roll_3_xy(uchar n,uint speed)
uchar i;
switch(n)
case 1:
for (i=0;i<8;i++)
box_apeak_xy (0,i,0,7,7-i,7,1,1);
delay(speed);
if (i<7)
box_apeak_xy (3,3,0,0,i,7,1,0);
break;
case 2:
for (i=0;i<8;i++)
box_apeak_xy (7-i,0,0,i,7,7,1,1);
delay(speed);
if (i<7)
box_apeak_xy (3,4,0,i,7,7,1,0);
break;
case 3:
for (i=0;i<8;i++)
delay(speed);
if (i<7)
box_apeak_xy (4,4,0,7,7-i,7,1,0);
break;
case 0:
for (i=0;i<8;i++)
delay(speed);
if (i<7)
box_apeak_xy (4,3,0,7-i,0,7,1,0);
void trans(uchar z,uint speed)
uchar i,j;
for (j=0;j<8;j++)
for (i=0;i<8;i++)
display[z][i]>>=1;
delay(speed);
void tranoutchar(uchar c,uint speed)
uchar i,j,k,a,i2=0;
for (i=0;i<8;i++)
if (i<7)
box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
box_apeak_xy (i2,0,0,i2,7,7,1,0);
a=0;
i2=i+1;
for (j=0;j<=i;j++)
a=a|(1<<j);
for (k=0;k<8;k++)
display[k][3]|=table_cha[c][k]&a;
display[k][4]|=table_cha[c][k]&a;
delay(speed);
void transss()
uchar i,j;
for (i=0;i<8;i++)
for (j=0;j<8;j++)
display[i][j]<<=1;
/*From now on,the function below is to display the flash.*/
void flash_1()
clear(0);
type(1,0);
delay(60000);
type(2,0);
delay(60000);
type(3,0);
delay(60000);
type(4,0);
delay(60000);
delay(60000);
clear(0);
rolldisplay(30000);
type(0,7);
delay(60000);
trailler(6000);
delay(60000);
void flash_2()
uchar i;
for (i=129;i>0;i--)
cirp(i-2,0,1);
delay(8000);
cirp(i-1,0,0);
delay(8000);
for (i=0;i<136;i++)
cirp(i,1,1);
delay(8000);
cirp(i-8,1,0);
delay(8000);
for (i=129;i>0;i--)
cirp(i-2,0,1);
delay(8000);
delay(8000);
for (i=0;i<128;i++)
cirp(i-8,1,0);
delay(8000);
delay(60000);
void flash_3()
char i;
for (i=0;i<8;i++)
box_apeak_xy(0,i,0,7,i,7,1,1);
delay(20000);
if (i<7)
box_apeak_xy(0,i,0,7,i,7,1,0);
for (i=7;i>=0;i--)
delay(20000);
if (i>0)
for (i=0;i<8;i++)
delay(20000);
if (i<7)
void flash_4()
char i,j,an[8];
for (j=7;j<15;j++)
an[j-7]=j;
for (i=0;i<=16;i++)
for (j=0;j<8;j++)
if ((an[j]<8)&(an[j]>=0))
line(0,an[j],j,7,an[j],j,1);
for (j=0;j<8;j++)
if (((an[j]+1)<8)&(an[j]>=0))
line(0,an[j]+1,j,7,an[j]+1,j,0);
for (j=0;j<8;j++)
if (an[j]>0)
an[j]--;
delay(15000);
for (j=0;j<8;j++)
an[j]=1-j;
for (i=0;i<=16;i++)
for (j=0;j<8;j++)
for (j=0;j<8;j++)
if (((an[j]-1)<7)&(an[j]>0))
line(0,an[j]-1,j,7,an[j]-1,j,0);
for (j=0;j<8;j++)
if (an[j]<7)
an[j]++;
delay(15000);
void flash_5()
uint a=15000;//a=delay
char i=8,j,an[4];
//1
for (j=7;j<11;j++)
an[j-7]=j;
while(i--)
for (j=0;j<4;j++)
if (an[j]<8)
box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
if (an[j]<7)
box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
for (j=0;j<4;j++)
if (an[j]>3)
an[j]--;
delay(a);
//2
i=3;
for (j=0;j<4;j++)
an[j]=5-j;
while(i--)
for (j=1;j<4;j++)
if (an[j]<4)
if (an[j]<3)
for (j=0;j<4;j++)
if (an[j]>0)
an[j]--;
delay(a);
//3
i=3;
for (j=1;j<4;j++)
an[j]=4-j;
while(i--)
for (j=1;j<4;j++)
if (an[j]>=0)
if (an[j]>0)
box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
for (j=1;j<4;j++)
if (an[j]<3)
an[j]++;
delay(a);
//4
i=3;
for (j=0;j<4;j++)
an[j]=j+1;
while(i--)
for (j=1;j<4;j++)
if (an[j]>3)
if (an[j]>3)
for (j=0;j<4;j++)
an[j]++;
delay(a);
//5
i=3;
for (j=3;j<6;j++)
an[j-2]=j;
while(i--)
for (j=1;j<4;j++)
for (j=0;j<4;j++)
if (an[j]>3)
an[j]--;
delay(a);
//6
i=3;
for (j=0;j<4;j++)
an[j]=5-j;
while(i--)
for (j=1;j<4;j++)
if (an[j]<4)
if (an[j]<3)
for (j=0;j<4;j++)
if (an[j]>0)
an[j]--;
delay(a);
//7
i=3;
for (j=0;j<4;j++)
an[j]=3-j;
an[0]=2;
while(i--)
for (j=0;j<3;j++)
if (an[j]>=0)
if (an[j]>=0)
for (j=0;j<4;j++)
if (j<5-i)
an[j]--;
delay(a);
//8
i=10;
for (j=0;j<4;j++)
an[j]=j-2;
while(i--)
for (j=0;j<4;j++)
if (an[j]>=0)
if (an[j]>=0)
for (j=0;j<4;j++)
if (an[j]<7)
an[j]++;
delay(a);
void flash_6()
uchar i,j,k,z;
roll_apeak_yz(1,10000);
roll_apeak_yz(2,10000);
roll_apeak_yz(3,10000);
roll_apeak_yz(0,10000);
for (i=0;i<3;i++)
for (j=0;j<8;j++)
for (k=0;k<8;k++)
if ((table_3p[i][j]>>k)&1)
for (z=1;z<8;z++)
point (j,7-k,z,1);
if (z-1)
point (j,7-k,z-1,0);
delay(5000);
trans(7,15000);
void flash_7()
uchar i;
uint a=3000;
roll_apeak_xy(0,10000);
roll_apeak_xy(1,10000);
roll_apeak_xy(2,10000);
roll_apeak_xy(3,10000);
for (i=0;i<8;i++)
box_apeak_xy (0,i,0,7-i,i,7,1,1);
delay(a);
delay(30000);
roll_3_xy(0,a);
delay(30000);
roll_3_xy(1,a);
delay(30000);
roll_3_xy(2,a);
delay(30000);
roll_3_xy(3,a);
delay(30000);
roll_3_xy(0,a);
delay(30000);
roll_3_xy(1,a);
delay(30000);
roll_3_xy(2,a);
delay(30000);
roll_3_xy(3,a);
for (i=7;i>0;i--)
box_apeak_xy(i,0,0,i,7,7,1,0);
delay(a);
void flash_8()
uchar i;
for (i=5;i<8;i++)
tranoutchar(i,10000);
delay(60000);
delay(60000);
void flash_9()
char i;
uchar j,an[8],x,y,t,x1,y1;
for (i=0;i<8;i++)
box_apeak_xy (i,0,0,i,7,7,1,1);
if (i)
box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
delay(10000);
for (i=0;i<7;i++)
line(6-i,6-i,0,6-i,6-i,7,1);
delay(10000);
for (i=0;i<8;i++)
an[i]=14;
for (i=0;i<85;i++)
clear(0);
for (j=0;j<8;j++)
t=an[j]%28;
x=dat2[t]>>5;
y=(dat2[t]>>2)&0x07;
t=(an[j]-14)%28;
x1=dat2[t]>>5;
y1=(dat2[t]>>2)&0x07;
line(x,y,j,x1,y1,j,1);
for (j=0;j<8;j++)
if ((i>j)&(j>i-71))
an[j]++;
delay(5000);
for (i=0;i<85;i++)
clear(0);
for (j=0;j<8;j++)
t=an[j]%28;
x=dat2[t]>>5;
t=(an[j]-14)%28;
x1=dat2[t]>>5;
for (j=0;j<8;j++)
if ((i>j)&(j>i-71))
an[j]--;
delay(5000);
for (i=0;i<29;i++)
clear(0);
t=an[0]%28;
x=dat2[t]>>5;
t=(an[0]-14)%28;
x1=dat2[t]>>5;
box_apeak_xy(x,y,0,x1,y1,7,0,1);
box_apeak_xy(x,y,1,x1,y1,6,0,1);
an[0]++;
delay(5000);
for (i=0;i<16;i++)
clear(0);
t=an[0]%28;
x=dat2[t]>>5;
t=(an[0]-14)%28;
x1=dat2[t]>>5;
box_apeak_xy(x,y,0,x1,y1,7,1,1);
an[0]--;
delay(5000);
for (i=0;i<8;i++)
line(i,i,0,0,0,i,0);
delay(5000);
for (i=1;i<7;i++)
line(i,i,7,7,7,i,0);
delay(5000);
for (i=1;i<8;i++)
clear(0);
box(7,7,7,7-i,7-i,7-i,0,1);
delay(10000);
for (i=1;i<7;i++)
clear(0);
box(0,0,0,7-i,7-i,7-i,0,1);
delay(10000);
for (i=1;i<8;i++)
clear(0);
box(0,0,0,i,i,i,0,1);
delay(10000);
for (i=1;i<7;i++)
clear(0);
box(7,0,0,i,7-i,7-i,0,1);
delay(10000);
for (i=1;i<8;i++)
box(7,0,0,7-i,i,i,1,1);
delay(10000);
for (i=1;i<7;i++)
clear(0);
box(0,7,7,7-i,i,i,1,1);
delay(10000);
void flash_10()
uchar i,j,an[4],x,y,t;
for (i=1;i<7;i++)
clear(0);
box(0,6,6,1,7,7,1,1);
box(i,6,6-i,i+1,7,7-i,1,1);
box(i,6,6,i+1,7,7,1,1);
box(0,6,6-i,1,7,7-i,1,1);
box(0,6-i,6,1,7-i,7,1,1);
box(i,6-i,6-i,i+1,7-i,7-i,1,1);
box(i,6-i,6,i+1,7-i,7,1,1);
box(0,6-i,6-i,1,7-i,7-i,1,1);
delay(30000);
for (i=0;i<4;i++)
an[i]=6*i;
for (i=0;i<35;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
box(x,y,0,x+1,y+1,1,1,1);
box(x,y,6,x+1,y+1,7,1,1);
for (j=0;j<4;j++)
an[j]++;
delay(10000);
for (i=0;i<35;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
for (j=0;j<4;j++)
an[j]--;
delay(10000);
for (i=0;i<35;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
box(x,0,y,x+1,1,y+1,1,1);
box(x,6,y,x+1,7,y+1,1,1);
for (j=0;j<4;j++)
an[j]++;
delay(10000);
for (i=0;i<36;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
for (j=0;j<4;j++)
an[j]--;
delay(10000);
for (i=6;i>0;i--)
clear(0);
delay(30000);
void flash_11()
uchar i,j,t,x,y;
uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
for (j=0;j<5;j++)
for (i=0;i<13;i++)
if (daa[i]>>4)
t=daa[i]&0x0f;
line (0,0,t+1,0,7,t+1,1);
t=daa[i];
line (0,0,t,0,7,t,1);
transss();
delay(10000);
for (j=1;j<8;j++)
if (j>3)
t=4;
t=j;
for (i=0;i<24;i+=j)
x=dat3[i]>>4;
y=dat3[i]&0x0f;
box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
transss();
delay(10000);
for (j=1;j<8;j++)
if (j>3)
t=4;
t=j;
for (i=0;i<24;i+=j)
x=dat3[i]>>4;
y=dat3[i]&0x0f;
point (0,x,y,1);
transss();
delay(10000);
sinter();
while(1){
// clear(0);
/*play list*/
//flash_1();
clear(0);
flash_2();
flash_3();
flash_4();
flash_4();
flash_5();
flash_5();
flash_6();
flash_7();
flash_8();
flash_9();
flash_10();
clear (0);
flash_11();
flash_9();
flash_5();
flash_7();
flash_5();
flash_6();
flash_8();
flash_9();
flash_10();
//P0; //573 in
//P1; //uln2803
//P2; //573 LE
void print() interrupt 1
uchar i;
static uchar layer=0;
P1=0;
for (i=0;i<8;i++)
P2=1<<i;
delay(3);
P0=display[layer][i];
delay(3);
P1=1<<layer;
if (layer<7)
layer++;
layer=0;
TH0=0xc0;
TL0=0;
