查看: 4713|回復(fù): 16
大家晚上好,這個(gè)是我寫的紅外接收程序,調(diào)了很久都沒調(diào)出來,幫忙看看
ID:89646 發(fā)表于 2015-9-12 20:33 | 顯示全部樓層 |閱讀模式
/*說明:使用的是HS0038紅外接收頭                                                          */
/*功能:實(shí)現(xiàn)紅外接收,接收到的鍵值碼于數(shù)碼管顯示                  */
/*思路:檢測外部中斷下降沿的時(shí)間,來翻譯紅外信號(hào)                        */
#include<reg52.h>
#define DataProt P0
sbit IR = P3^2;
sbit du = P2^6;
sbit we = P2^7;
uchar IRtime;                //存儲(chǔ)低電平到下一個(gè)低電平持續(xù)的時(shí)間
bit IR_ok;                        //標(biāo)志著已經(jīng)存好了全部IRtime
bit IR_receive_ok;        //標(biāo)志著接收好了鍵值碼
uchar IRcord[4];        //存儲(chǔ)鍵值碼
uchar IRdata[33];        //存儲(chǔ)數(shù)據(jù)碼和用戶碼
uchar code leddata[]={
//0                1         2     3     4     5     6     7     8
0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
//9     A     B           C         D           E         F                -         .          關(guān)顯示
0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x40, 0x80, 0x00
void IR_init()
        TMOD = 0x02;        //8位可自動(dòng)裝載定時(shí)器
        TH0 = 0x00;
        TL0 = 0x00;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
/*        EX0 = 1;
        IT0 = 1;                //下降沿觸發(fā)式中斷                */
        IT0 = 1;
        EX0 = 1;
void IRcordpro()        //【鍵值碼獲取】將IRdata[k]里的時(shí)間數(shù)據(jù) 翻譯為 用戶碼和用戶碼
        uchar i,j,k,dat,value;
        k = 1;                //IRdata[0]是起始位。所以k = 1:33 共32個(gè)數(shù)
        for(i = 0;i < 4;i++)
                for(j = 0 ;j < 8;j++)
                        dat = IRdata[k];
                        value >>= 1;
                        if(dat > 5)
                                value |= 0x80;        //先接收低位
                        k++;
                IRcord[i] = value;                //將用戶碼和數(shù)據(jù)碼保存于數(shù)組中去
                value = 0;                                //置0,以便下次用
        IR_receive_ok = 1;                        //表示已經(jīng)把鍵值碼取完了
void IRwork()
        switch(IRcord[2])
                case 0x45:        DataProt = leddata[10];        break;
                case 0x46:        DataProt = leddata[11];        break;
                case 0x47:        DataProt = leddata[12];        break;
                case 0x44:        DataProt = leddata[13];        break;
                case 0x40:        DataProt = leddata[14];        break;
                case 0x43:        DataProt = leddata[15];        break;
                case 0x07:        DataProt = leddata[16];        break;
                case 0x15:        DataProt = leddata[17];        break;
                case 0x09:        DataProt = 0x70;                break;
                case 0x16:        DataProt = leddata[0];        break;
                case 0x19:        DataProt = 0x49;                break;
                case 0x0d:        DataProt = 0x38;                break;
                case 0x0c:        DataProt = leddata[1];        break;
                case 0x18:        DataProt = leddata[2];        break;
                case 0x5e:        DataProt = leddata[3];        break;
                case 0x08:        DataProt = leddata[4];        break;
                case 0x1c:        DataProt = leddata[5];        break;
                case 0x5a:        DataProt = leddata[6];        break;
                case 0x42:        DataProt = leddata[7];        break;
                case 0x52:        DataProt = leddata[8];        break;
                case 0x4a:        DataProt = leddata[9];        break;
                default: break;
        IR_receive_ok = 0;                        //表示已經(jīng)把鍵值碼轉(zhuǎn)換完了
        IR_init();
        DataProt = 0xff;
        we = 1;
        DataProt = 0xfe;
        we = 0;
        du = 1;
/*                if(IR_ok)
                        IRcordpro();
                        IR_ok = 0;
                        if(IR_receive_ok)
                                IRwork();
                if(IR_ok)
                        IRcordpro();
                        IR_ok = 0;
                if(IR_receive_ok)
                        IRwork();
void timer0()interrupt 1
        IRtime++;                //277us加一次
void int0()interrupt 0
        static uchar i = 0;
//        static bit start_flag = 0;
        static start_flag = 0;
        if(start_flag)
                if((IRtime > 47) && (IRtime < 50))                //如果IRtime處于(13053us:13053us),表示接收到起始信號(hào)
                        i = 0;
                IRdata[i] = IRtime;
                i++;
                if(i == 33)                //已經(jīng)接收完了
                        IR_ok = 1;
                        i = 0;
                start_flag = 1;
                IRtime = 0;
ID:72947 發(fā)表于 2015-9-14 22:06 來自觸屏版 | 顯示全部樓層
可以參考我的貼……
學(xué)習(xí)型紅外遙控8路輸出端http://www.torrancerestoration.com/bbs/dpj-34267-1.html
ID:90614 發(fā)表于 2015-9-20 14:36 | 顯示全部樓層
看過了不懂
ID:89646 發(fā)表于 2015-9-20 15:28 | 顯示全部樓層
qq704661078 發(fā)表于 2015-9-14 22:06
可以參考我的貼……
不懂匯編呢親
ID:89646 發(fā)表于 2015-9-20 15:30 | 顯示全部樓層
原來的程序調(diào)試不出來,放棄了。我重新編了一個(gè)程序,完美運(yùn)行
ID:89646 發(fā)表于 2015-9-20 15:31 | 顯示全部樓層
#include <reg52.h>
sbit IR = P3^2;
sbit dula = P2^6;
sbit wela = P2^7;
uchar IRtime;
bit IR_ok;
bit IR_receive_ok;
uchar IRcord[4];
uchar IRdata[33];
unsigned char code table[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄滅
                0x00  //自定義
IR_init()
        TMOD = 0x02;
        TH0 = 0;
        TL0 = 0;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
        IT0 = 1;
        EX0 = 1;
void time0() interrupt 1
        IRtime++;        //277.7us
void ex0() interrupt 0
        static startflag;
        static uchar i;
        if(startflag)
                if(IRtime > 32 && IRtime < 52)
                        i = 0;
                IRdata[i] = IRtime;
                IRtime = 0;
                i++;
                if(i == 33)
                        IR_ok = 1;
                        i = 0;
                startflag = 1;
                IRtime = 0;
void IRcordpro()
        uchar i,j,k,time,value;
        k = 1;
                for(j = 0;j < 8;j++ )
                        time = IRdata[k];
                        value >>= 1;
                        if(time > 5)
                                value |= 0x80;
                        k++;
                IRcord[i] = value;
                value = 0;
        IR_receive_ok = 1;
void IRwork()
        switch (IRcord[2])
                case 0x45:        P0 = table[0];        break;
                case 0x46:        P0 = table[1];        break;
                case 0x47:        P0 = table[2];        break;
                case 0x44:        P0 = table[3];        break;
                case 0x40:        P0 = table[4];        break;
                case 0x43:        P0 = table[5];        break;
                case 0x07:        P0 = table[6];        break;
                case 0x15:        P0 = table[7];        break;
                case 0x09:        P0 = table[8];        break;
                case 0x16:        P0 = table[9];        break;
                case 0x19:        P0 = table[10];        break;
                case 0x0d:        P0 = table[11];        break;
                case 0x0c:        P0 = table[12];        break;
                case 0x18:        P0 = table[13];        break;
                case 0x5e:        P0 = table[14];        break;
                case 0x08:        P0 = table[15];        break;
                case 0x1c:        P0 = table[16];        break;
                case 0x5a:        P0 = table[17];        break;
                case 0x42:        P0 = table[18];        break;
                case 0x52:        P0 = table[19];        break;
                case 0x4a:        P0 = table[20];        break;
                default:        break;
        IR_receive_ok = 0;
        IR_init();
        wela = 1;
        P0 = 0xfe;
        wela = 0;
        P0 = 0xff;
        dula = 1;
        P0 = 0xff;
                if(IR_ok)
                        IRcordpro();
                        IR_ok = 0;
                if(IR_receive_ok)
                        IRwork();
ID:79544 發(fā)表于 2015-9-21 12:05 | 顯示全部樓層
定時(shí)的問題。 if(IRtime > 32 && IRtime < 52)
ID:84147 發(fā)表于 2015-9-21 12:19 | 顯示全部樓層
最近也正在學(xué)紅外解碼,不過還是弄不懂,有木有訣竅呀
ID:84147 發(fā)表于 2015-9-21 12:21 | 顯示全部樓層
最近也在研究紅外解碼,但是還是搞不懂,有沒有訣竅呀
ID:84147 發(fā)表于 2015-9-21 18:10 | 顯示全部樓層
你的程序我驗(yàn)證了一下,發(fā)現(xiàn)只能接收一次紅外碼,需要單片機(jī)復(fù)位以后才能從新接收下一次遙控發(fā)射的代碼,有待改進(jìn)
ID:90771 發(fā)表于 2015-9-22 13:08 | 顯示全部樓層
愛莫能助啊
ID:90780 發(fā)表于 2015-9-22 14:23 | 顯示全部樓層
很有用啊
ID:89646 發(fā)表于 2015-9-26 09:55 | 顯示全部樓層
血一 發(fā)表于 2015-9-21 18:10
你的程序我驗(yàn)證了一下,發(fā)現(xiàn)只能接收一次紅外碼,需要單片機(jī)復(fù)位以后才能從新接收下一次遙控發(fā)射的代碼,有 ...
您印證的是我的哪一個(gè)程序,是新發(fā)的,還是一樓之前發(fā)的?
ID:89646 發(fā)表于 2015-9-26 09:59 | 顯示全部樓層
騰飛的龍 發(fā)表于 2015-9-21 12:05
定時(shí)沒有問題
ID:89646 發(fā)表于 2015-9-26 10:00 | 顯示全部樓層
血一 發(fā)表于 2015-9-21 12:21
我用的算法是:測試低電平與低電平的時(shí)間,來進(jìn)行解碼
ID:79544 發(fā)表于 2015-9-26 11:05 | 顯示全部樓層
正常的紅外解碼數(shù)碼管顯示并控制LED程序,絕對好用。
  1. /***********************************************
  2.         功能:萬能紅外遙控器解碼并用數(shù)碼管顯示。
  3.                         只顯示鍵值碼.根據(jù)鍵值控制LED
  4.                         加上三極管就可以控制繼電器
  5.         紅外接收頭的輸出接外部中斷1.  P3.3
  6.         晶振:11.0592M
  7.         單片機(jī):STC12C5A60S2
  8.         作者 :蘇義江改編自51黑論壇
  9. *************************************************/
  10. #include <stc12c5a60s2.h>
  11. //#include <reg52.h>
  12. #define uchar unsigned char
  13. #define uint unsigned int
  14. sbit dula=P0^7;
  15. sbit wela=P0^6;
  16. sbit fmq=P1^7;
  17. sbit  IR=P3^3;
  18. //共陽
  19. uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,
  20.                                 0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,
  21.                                 0xa1,0x86,0x8e,0x89};
  22. //共陰
  23. /*uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
  24.        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};  */
  25. uchar f;
  26. #define Imax 14000    //此處為晶振為11.0592時(shí)的取值,
  27. #define Imin 8000    //如用其它頻率的晶振時(shí),
  28. #define Inum1 1450    //要改變相應(yīng)的取值。
  29. #define Inum2 700
  30. #define Inum3 3000
  31. uchar Im[4]={0x00,0x00,0x00,0x00};
  32. uchar show[2]={0,0};
  33. unsigned long m,Tc;
  34. unsigned char IrOK;
  35. void delay(uchar i)//延時(shí)
  36. {
  37.   uchar j,k;
  38.   for(j=i;j>0;j--)
  39.     for(k=125;k>0;k--);
  40. }
  41. void display()//顯示函數(shù)
  42. {
  43.    P2=table[show[0]];
  44.    dula=1;
  45.    dula=0;
  46.         P2=0xff;
  47.
  48.    wela=0;
  49.    P2=0xfe;
  50.    wela=1;
  51.    wela=0;
  52.    delay(5);
  53.
  54.    P2=table[show[1]];
  55.    dula=1;
  56.    dula=0;
  57.         P2=0xff;
  58.
  59.    P2=0xfd;
  60.    wela=1;
  61.    wela=0;
  62.    delay(5);
  63. }
  64. //外部中斷1解碼程序
  65. void intersvr1(void) interrupt 2 using 1
  66. {
  67.         fmq=0;    //蜂鳴器響
  68.         Tc=TH0*256+TL0;   //提取中斷時(shí)間間隔時(shí)長
  69.         TH0=0;
  70.     TL0=0;         //定時(shí)中斷重新置零
  71.         if((Tc>Imin)&&(Tc<Imax))
  72.     {
  73.                   m=0;
  74.         f=1;
  75.                   return;
  76.      }       //找到啟始碼
  77.    if(f==1)
  78.    {
  79.        if(Tc>Inum1&&Tc<Inum3)
  80.                    {
  81.                            Im[m/8]=Im[m/8]>>1|0x80; m++;
  82.             }
  83.               if(Tc>Inum2&&Tc<Inum1)
  84.         {
  85.                  Im[m/8]=Im[m/8]>>1; m++; //取碼
  86.                   }
  87.                   if(m==32)
  88.                    {
  89.                  m=0;
  90.                  f=0;
  91.          if(Im[2]==~Im[3])//鍵值碼和反碼相同
  92.                {
  93.            IrOK=1; //正確至1
  94.                     }
  95.          else IrOK=0;   //取碼完成后判斷讀碼是否正確
  96.      }
  97.                //準(zhǔn)備讀下一碼
  98.    }
  99.         fmq=1; //蜂鳴器關(guān),如果嫌吵,可刪掉此行和上面對應(yīng)的開喇叭那一行
  100. }
  101. /*主程序*/
  102. void main(void)
  103. {
  104.     uint  a;
  105.          m=0;
  106.     f=0;
  107.         EA=1;
  108.         IT1=1;
  109.         EX1=1;
  110.     TMOD=0x11;
  111.     TH0=0;TL0=0;
  112.     TR0=1;
  113.          while(1)
  114.         {
  115.        if(IrOK==1)
  116.                   {
  117.                       show[1]=Im[2] & 0x0F;     //取鍵碼的低四位
  118.            show[0]=Im[2] >> 4;
  119.            IrOK=0;
  120.                   }
  121.            for(a=100;a>0;a--)
  122.           {
  123.                             display();//顯示鍵值
  124.                      }
  125.                 switch(Im[2])//讀出的鍵值控制LED
  126.                 {
  127.                         case 0x1b:P0=0XFE;break;
  128.                         case 0x18:P0=0XFd;break;
  129.                         case 0x17:P0=0XFb;break;
  130.                         case 0x16:P0=0XF7;break;
  131.                         case 0x15:P0=0Xef;break;
  132.                         case 0x14:P0=0Xdf;break;
  133.                         default: break;
  134.                 //        return;
  135.                 }
  136.         }
  137. }
ID:88716 發(fā)表于 2015-9-26 12:22 | 顯示全部樓層
#include<reg52.h>
//typedef unsigned char uchar;
//typedef unsigned int uint;
sbit IR_INPUT=P3^2;
bit irflag=0;
unsigned char  ircode[4];
void InitInfrared()
        IR_INPUT=1;
        TMOD&=0xf0;
        TMOD|=0x01;
        TR0=0;
        ET0=0;
        IT0=1;
        EX0=1;
unsigned int GetLowTime()
        TH0=0;
        TL0=0;
        TR0=1;
        while(!IR_INPUT)
                if(TH0>0x40)
                        break;
        TR0=0;
        return(TH0*256+TL0);
unsigned int GetHighTime()
        TH0=0;
        TL0=0;
        TR0=1;
        while(IR_INPUT)
                if(TH0>0x40)
                        break;
        TR0=0;
void EX0_ISR() interrupt 0
        unsigned char i,j,byt;
        unsigned int time;
        time=GetLowTime();
        if((time<7833)||(time>8755))
                IE0=0;
                return;
        time=GetHighTime();
        if((time<3686)||(time>4608))
                IE0=0;
                return;
        for(i=0;i<4;i++)
                for(j=0;j<8;j++)
                        time=GetLowTime();
                        if((time<313)||(time>718))
                                IE0=0;
                                return;
                        time=GetHighTime();
                        if((time>313)&&(time<718))
                                byt>>=1;
                        else if((time>1345)&&(time<1751))
                                byt>>=1;
                                byt|=0x80;
                                IE0=0;
                                return;
                ircode[i]=byt;
        IE0=0;
        irflag=1;
/******************main******************************/
#include<reg52.h>
sbit du=P2^6;
sbit we=P2^7;
uchar T0RH=0;
uchar T0RL=0;
uchar jianma1=0,jianma2=0;
unsigned char code dofly_DuanMa[]={  0x3F,          //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄滅
                0x00  //自定義
                                };// 顯示段碼值0~9
extern bit irflag;
extern unsigned char ircode[4];
extern void InitInfrared();
void delay(uchar x)
        uchar y,z;
        for(y=x;y>0;y--)
        for(z=114;z>0;z--);
/*void ConfigTimer1(uint ms)
        unsigned long temp;
        temp=110592/12;
        temp=(temp*ms)/1000;
        temp=65536-temp;
        T0RH=(unsigned char)(temp>>8);
        T0RL=(unsigned char)temp;
        TMOD&=0x0f;
        TMOD|=0x10;
        TH1=T0RH;
        TL1=T0RL;
        ET1=1;
        TR1=1;
void LedScan()
        du=1;
        P0=jianma1;
        du=0;
        P0=0xff;
        we=1;
        P0=0xbf;
        we=0;
        delay(1);
        du=1;
        P0=jianma2;
        du=0;
        P0=0xff;
        we=1;
        P0=0x7f;
        we=0;
        delay(1);
        EA=1;
        InitInfrared();
//        ConfigTimer1(3);
//        PT1=0;
                if(irflag)
                        irflag=0;
                        jianma1=dofly_DuanMa[ircode[2]>>4];
                        jianma2=dofly_DuanMa[ircode[2]&0x0f];
                LedScan();
/*void time1_isr() interrupt 3
        TH0 = T0RH;  //重新加載重載值
    TL0 = T0RL;
    LedScan();   //數(shù)碼管掃描顯示
