完整代碼下載:
sst25vf.rar
(6.84 KB, 下載次數(shù): 44)
2015-10-29 22:41 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
- void SPI_FLASH_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- SPI_InitTypeDef SPI_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- /* Enable the SPI periph */
- RCC_APB2PeriphClockCmd(FLASH_SPI_CLK, ENABLE);
- /* Enable SCK, MOSI and MISO GPIO clocks */
- RCC_AHB1PeriphClockCmd(FLASH_SPI_SCK_GPIO_CLK | FLASH_SPI_MOSI_GPIO_CLK | FLASH_SPI_MISO_GPIO_CLK, ENABLE);//FLASH_SPI_MISO_GPIO_CLK
- /* Enable CS GPIO clock */
- RCC_AHB1PeriphClockCmd(FLASH_SPI_CS_GPIO_CLK, ENABLE);
- /* Enable 157 GPIO clock */
- RCC_AHB1PeriphClockCmd(FLASH_SPI_157_GPIO_CLK, ENABLE);
- GPIO_PinAFConfig(FLASH_SPI_SCK_GPIO_PORT, FLASH_SPI_SCK_SOURCE, FLASH_SPI_SCK_AF);
- GPIO_PinAFConfig(FLASH_SPI_MISO_GPIO_PORT, FLASH_SPI_MISO_SOURCE, FLASH_SPI_MISO_AF);
- GPIO_PinAFConfig(FLASH_SPI_MOSI_GPIO_PORT, FLASH_SPI_MOSI_SOURCE, FLASH_SPI_MOSI_AF);
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- /* SPI SCK pin configuration */
- GPIO_InitStructure.GPIO_Pin = FLASH_SPI_SCK_PIN;
- GPIO_Init(FLASH_SPI_SCK_GPIO_PORT, &GPIO_InitStructure);
- /* SPI MOSI pin configuration */
- GPIO_InitStructure.GPIO_Pin = FLASH_SPI_MOSI_PIN;
- GPIO_Init(FLASH_SPI_MOSI_GPIO_PORT, &GPIO_InitStructure);
- /* SPI MISO pin configuration */
- GPIO_InitStructure.GPIO_Pin = FLASH_SPI_MISO_PIN;
- GPIO_Init(FLASH_SPI_MISO_GPIO_PORT, &GPIO_InitStructure);
- /* Configure GPIO PIN for Lis Chip select */
- GPIO_InitStructure.GPIO_Pin = FLASH_SPI_CS_PIN;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- GPIO_Init(FLASH_SPI_CS_GPIO_PORT, &GPIO_InitStructure);
- SPI_FLASH_CS_HIGH();
- /* Configure GPIO PIN for 157 */
- GPIO_InitStructure.GPIO_Pin = FLASH_SPI_157_PIN;
- GPIO_Init(FLASH_SPI_157_GPIO_PORT, &GPIO_InitStructure);
- /* SPI1 configuration */
- SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
- SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
- SPI_InitStructure.SPI_CRCPolynomial = 7;
- SPI_Init(FLASH_SPI, &SPI_InitStructure);
- /* Enable SPI1 */
- SPI_Cmd(FLASH_SPI, ENABLE);
- SPI_FLASH_157_DIS();
- //SPI_DMAInit();
- /* I2S DMA IRQ Channel configuration */
- /* NVIC_InitStructure.NVIC_IRQChannel = SPI1_DMA_RX_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- NVIC_InitStructure.NVIC_IRQChannel = SPI1_DMA_TX_IRQn;
- Delay_Init(168);*/
- 函數(shù)名稱(chēng) : SPI_FLASH_Writebyte
- 函數(shù)功能 : 寫(xiě)一個(gè)字節(jié)數(shù)據(jù)
- 入口參數(shù) : address:地址 buffer:數(shù)據(jù)
- 出口參數(shù) : 無(wú)
- void SPI_FLASH_Writebyte(unsigned int Addr, unsigned char *buf)
- unsigned short i = 0, j = 0;
- SPI_FLASH_WriteEnable();
- SPI_FLASH_CS_LOW();
- SPI_FLASH_SendByte(0x02);
- SPI_FLASH_SendByte((Addr)>>16);
- SPI_FLASH_SendByte((Addr)>>8);
- SPI_FLASH_SendByte((Addr));
- SPI_FLASH_SendByte(*buf);
- SPI_FLASH_WaitForWriteEnd();
- SPI_FLASH_WriteDisable();
- delay_nus(20);
- 函數(shù)名稱(chēng) : SPI_FLASH_Writenbyte
- 入口參數(shù) : address:地址 buffer:數(shù)據(jù) num :數(shù)量
- 出口參數(shù) : 無(wú)
- void SPI_FLASH_Writenbyte(unsigned int Addr, unsigned char *buf,u16 num)
- u8 i;
- for(i=0;i<num;i++)
- SPI_FLASH_Writebyte(Addr++,&buf[i]);
- 函數(shù)名稱(chēng) : SPI_FLASH_Readnbyte
- 出口參數(shù) : 無(wú)
- void SPI_FLASH_Readnbyte(unsigned int Addr,unsigned char *buf,u16 num)
- unsigned short i = 0;
- SPI_FLASH_SendByte(0x0b);
- SPI_FLASH_SendByte(Addr>>16);
- SPI_FLASH_SendByte(Addr>>8);
- SPI_FLASH_SendByte(Addr);
- //dummy
- SPI_FLASH_SendByte(Dummy_Byte);
- buf[i]= SPI_FLASH_SendByte(Dummy_Byte);
- main()
- u8 bufda[25]="123456789abcdefghijkl";
- SPI_FLASH_Init();
- // Write_74HC595(HC595_OUT,3,&davalu);
- // Write_595_ENABLE();
- SPI_FLASH_157_EN();//kang 2014.07.10
- SPI_FLASH_ChipErase();
- SPI_FLASH_157_EN(); //kang 2014.07.10
- i= SPI_FLASH_ReadID();
- SPI_FLASH_Writenbyte(5,bufda,20);
- SPI_FLASH_Readnbyte(5,readbuf,20);
