- //藍(lán)牙控制小車 加舵機(jī) 加避障 可以調(diào)速 正確的程序
- 單片機(jī): STC12C5608AD
- // 晶振 : 11.0592M晶振
- 作者 :蘇義江
- 時(shí)間 :2016-1-8
- #include <reg52.h>
- #include<intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- //sfr T2MOD=0xc9;
- sbit in1 =P1^0; //電機(jī)1端口
- sbit in2 =P1^1;
- sbit ina =P1^2; //電機(jī)PWM-A
- sbit in3 =P1^3;//電機(jī)2端口
- sbit in4 =P1^4;
- sbit inb =P1^5;//電機(jī)PWM-B
- sbit bz_l =P2^0; //避障左
- sbit bz_r =P2^1; //避障右
- sbit moto_pwm =P3^4;//PWM輸出腳控制舵機(jī)
- sbit yan =P3^5;//頭燈光
- sbit landeng =P3^2;//藍(lán)前大燈
- sbit hondeng =P3^3;//紅前大燈
- sbit yinyue =P3^7;//音樂端口
- sbit wela =P1^6;//位碼
- sbit dula =P1^7;//段碼
- uchar code table[] ={ 0xC0,0xF9,0xA4,0xB0,0x99,0x92,
- 0x82,0xF8,0x80,0x90,0xBF,0xff};
- uchar code table1[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
- //uchar disbuff[4] ={ 0,0,0,0,};//數(shù)碼管全顯示 0
- uint tt = 0;//變量定義
- uint num=0;//變量定義
- uchar pwm_lefr=0;//定義 定時(shí)器自加1變量
- //uchar pwm_lefr1=0;//定義 定時(shí)器自加1變量
- uchar duojiguizhong=14;//舵機(jī)歸中1.5ms
- uchar duojiguizhong1=14;//舵機(jī)歸中1.5ms
- uchar tmp,w,sudu;
- void init() ;
- void delay1(uint z)//延時(shí)函數(shù)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=120;y>1;y--);
- void delay(uint z)
- uint x,y;
- for(x=0;x<z;x++)
- for(y=0;y<1000;y++);
- /*void xianshi(uchar num)//顯示
- uchar gw,sw,bw,qianw;
- qianw=num/1000%100;
- bw=num%1000/100;
- sw=num%100/10;
- gw=num%10;
- P2=0xfe;
- wela=1;
- _nop_();_nop_();
- wela=0;
- P2=table[qianw];
- dula=1;
- _nop_();_nop_();
- dula=0;
- delay1(2);
- P2=0xfd;
- wela=1;
- _nop_();
- _nop_();
- wela=0;
- P2=table[bw];
- dula=1;
- _nop_();
- _nop_();
- dula=0;
- delay1(2);
- P2=0xfb;
- wela=1;
- _nop_();_nop_();
- wela=0;
- P2=table[sw];
- dula=1;
- _nop_();_nop_();
- dula=0;
- delay1(2);
- P2=0xf7;
- wela=1;
- _nop_();_nop_();
- wela=0;
- P2=table[gw];
- dula=1;
- _nop_();_nop_();
- dula=0;
- delay1(2); //顯示個(gè) 十 百 千
- void pwmmaic()//產(chǎn)生PWM
- if(pwm_lefr<=duojiguizhong)
- moto_pwm=1;
- else
- moto_pwm=0;
- if(pwm_lefr>=200)
- pwm_lefr=0;
- void duoji_kz()//舵機(jī)控制
- yan=0;
- duojiguizhong=9;
- delay(800);
- yan=0;
- duojiguizhong=16;
- delay(800);
- yan=0;
- duojiguizhong=24;
- delay(800);
- yan=0;
- duojiguizhong=16;
- delay(800);
- yan=0;
- delay(1500);
- yan=1;
- void lankong() //藍(lán)色LED
- landeng=0;
- delay1(80);
- landeng=1;
- delay1(80);
- void hongkong() //紅色LED
- hondeng=0;
- delay1(80);
- hondeng=1;
- delay1(80);
- void qianjin()
- in1=1;in2=0;in3=0;in4=1;
- yan=0;landeng=0;hondeng=0;yinyue=0;
- void houtui()
- in1=0;in2=1;in3=1;in4=0;
- yan=1;hondeng=0;yinyue=0;
- void zuozhuan()
- in1=1;in2=0;in3=1;in4=0;
- lankong();yinyue=1;
- void youzhuan()
- in1=0;in2=1;in3=0;in4=1;
- hongkong();yinyue=1;
- void tingzhi()
- in1=0;in2=0;in3=0 ;in4=0;
- hongkong();lankong();yinyue=1;
- void bizhang() //避障
- if(bz_l==1&&bz_r==1)
- qianjin();
- if(bz_l==0&&bz_r==1)
- zuozhuan();
- if(bz_l==1&&bz_r==0)
- youzhuan();
- if(bz_l==0&&bz_r==0)
- tingzhi();
- delay(100);
- houtui();
- delay(500);
- zuozhuan();
- delay(200);
- qianjin();
- void init() //串口初始化
- { //關(guān)中斷
- SCON =0x50; //串口模式1,允許接收
- TMOD =0x20;//定時(shí)器1為模式2 8-bit自動(dòng)裝載方式用于產(chǎn)生波特率
- PCON=0x00;//波特率不倍增
- TH1=0xfd;//波特率9600 11.0592M
- TL1=0xfd;
- TH0=0xfd;
- TH0=0xae;
- EA=1;
- ES=1;
- ET0=1; // T0中斷允許
- TR0=1; // 啟動(dòng)T0定時(shí)器
- TR1=1; // 啟動(dòng)T1定時(shí)器
- duojiguizhong=16;
- duojiguizhong1=16;
- void ctrl() //接收處理函數(shù)
- switch(tmp)
- case 1:qianjin(); break;
- case 2: houtui();break;
- case 3:zuozhuan(); break;
- case 4:youzhuan();break;
- case 0:tingzhi(); break;
- case 7:duoji_kz();break; //舵機(jī) C
- case 8: bizhang(); break; //避障 D
- /*case 1:duoji_kz();qianjin(); break;
- case 2:duoji_kz(); houtui();break;
- case 0:tingzhi(); break; */
- void tiaosu () //調(diào)速
- switch(sudu)
- case 5: w=40; break; //A
- case 6: w=75; break; //B
- void main()
- init();
- while(1)
- // xianshi( num ); //顯示函數(shù)
- ctrl();
- tiaosu();
- void time0() interrupt 1
- TH0=0xfd;
- TL0=0xae;
- tt++;
- pwm_lefr++;
- // pwm_lefr1++;
- pwmmaic();
- if(tt<w)
- ina=1;
- inb=1;
- else
- ina=0;
- inb=0;
- if(tt==100)
- {tt=0;
- num++;
- if(num==9999)num=0;
- void ckzd() interrupt 4
- ES=0;
- RI=0;
- tmp=SBUF;
- sudu=SBUF;
- ES=1;
