查看: 2642|回復(fù): 0
FPGA數(shù)碼管交換顯示 報(bào)錯(cuò)
ID:262 發(fā)表于 2016-3-11 21:11 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
跪求大神幫忙。出租車(chē)顯示計(jì)費(fèi),公里數(shù),還有時(shí)間。一直找不到報(bào)錯(cuò)原因。LIBRARY IEEE;USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
ENTITY lucheng IS
        PORT( CLK: IN STD_LOGIC;
                k0, k1, k2, k3: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
                k4, k5, k6, k7: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
                k8,k9: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
                s1,s2,s3:  IN STD_LOGIC;
                WEI: OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
                LED: OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
        END ENTITY;
ARCHITECTURE behave OF lucheng IS
        SIGNAL CNT4 : INTEGER RANGE 0 TO 3 :=0;
        SIGNAL SHUJU: STD_LOGIC_VECTOR(3 DOWNTO 0);
    --SIGNAL S:  STD_LOGIC_VECTOR(2 DOWNTO 0);
        --S<= (s1 & s2 & s3);
BEGIN
PRO1:  PROCESS(CLK ,s1,s2,s3)
BEGIN
IF((s1 & s2 & s3) = "011") then
        IF (CLK'EVENT AND CLK = '1') THEN
                        CNT4 <= CNT4 + 1;
                        CASE CNT4 IS
                                WHEN 0 => WEI <= "0001"; SHUJU <= k4;
                                WHEN 1 => WEI <= "0010"; SHUJU <= k5;
                                WHEN 2 => WEI <= "0100"; SHUJU <= k6;
                                WHEN 3 => WEI <= "1000"; SHUJU <= k7;
                                WHEN OTHERS => NULL;
                        END CASE;
                END IF;
ELSIF (s1 & s2 & s3="101") then
                        CNT4 <= CNT4 + 1;
                        CASE CNT4 IS
                                WHEN 0 => WEI <= "0001"; SHUJU <= k0;
                                WHEN 1 => WEI <= "0010"; SHUJU <= k1;
                                WHEN 2 => WEI <= "0100"; SHUJU <= k2;
                                WHEN 3 => WEI <= "1000"; SHUJU <= k3;
                        END CASE;
                END IF;
ELSIF (s1 & s2 & s3="110")  THEN
  CNT4 <= (CNT4 + 1);
                        CASE CNT4 IS
                        END CASE;
                END IF;
        END IF;
        END PROCESS;
PRO2: PROCESS(SHUJU)
        BEGIN
                CASE SHUJU IS
                        WHEN "0000" => LED<= "01111110" ; --- 0
                        WHEN "0001" => LED<= "00110000" ; --- 1
                        WHEN "0010" => LED<= "01101101" ; --- 2
                        WHEN "0011" => LED<= "01111001" ; --- 3
                        WHEN "0100" => LED<= "00110011" ; --- 4
                        WHEN "0101" => LED<= "01011011" ; --- 5
                        WHEN "0110" => LED<= "01011111" ; --- 6
                        WHEN "0111" => LED<= "01110000" ; --- 7
                        WHEN "1000" => LED<= "01111111" ; --- 8
                        WHEN "1001" => LED<= "01111011" ; --- 9
                        WHEN others=>  LED<= "00000000" ;
                END CASE;
        END PROCESS;
END behave;
相關(guān)帖子
