查看: 2362|回復(fù): 2
52 程序改51
ID:116352 發(fā)表于 2016-4-26 16:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
各位大神 本人新手菜鳥(niǎo)一枚  網(wǎng)上找了52的程序不會(huì)改51的 求幫助
#include <reg52.h>
sbit     PINA    = P1^0;
sbit     PINB    = P1^1;
sbit     PIND    = P1^2;
unsigned char  display[3];
unsigned char  code  LEDData[ ] =
{ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00
char code reserve[3]_at_ 0x3b; //保留0x3b開(kāi)始的3個(gè)字節(jié)
unsigned char  counter = 0;     //編碼器脈沖計(jì)數(shù)
unsigned char  n,shift;
ms延時(shí)子函數(shù)
void delayms(unsigned int ms)
  unsigned char k;
  while (ms--)
    for (k = 0; k < 114; k++)
掃描編碼器子函數(shù)
在編碼器引腳A為低電平期間:
編碼器引腳B從0到1為正轉(zhuǎn),編碼器引腳B從1到0為反轉(zhuǎn)。
void scan_encoder(void)
   static  bit  Curr_encoder_b;  //定義一個(gè)變量來(lái)儲(chǔ)存當(dāng)前B信號(hào)
   static  bit  Last_encoder_b;  //定義一個(gè)變量來(lái)儲(chǔ)存上次B腳信號(hào)
   static  bit  updata= 0;
   if( PINA && PINB)           //編碼器無(wú)轉(zhuǎn)動(dòng)退出
     updata = 0;
     return;
   Last_encoder_b = PINB;       //記錄B信號(hào)
   while(!PINA)                //等待A由低變高
     Curr_encoder_b = PINB;     //記錄等待期間的B信號(hào)(指當(dāng)前B信號(hào))
     updata = 1; }
   if(updata)
   updata = 0 ;
     if( (Last_encoder_b == 0)&&(Curr_encoder_b== 1) ) //B從0到1為正轉(zhuǎn)
   if(counter == 255)
       return;
       counter++;          //正轉(zhuǎn)計(jì)數(shù)加
     else if( (Last_encoder_b == 1)&&(Curr_encoder_b == 0) ) //B從1到0為反轉(zhuǎn)
       if(counter == 0)
       return;
       counter--;         //反轉(zhuǎn)計(jì)數(shù)減
主函數(shù)
void  main(void)
   P0 = 0xff;
   P1 = 0xff;
   P2 = 0xff;
   T2CON = 0x00;               //設(shè)置T2CON寄存器
   TH2 = 0xfc;                 //1ms定時(shí)
   TL2 = 0x66;
   ET2 = 1;                    //啟用Timer2中斷
   EA = 1;                     //總中斷允許
   TR2 = 1;                    //啟動(dòng)定時(shí)器2
   counter = 0;                //計(jì)數(shù)單元清零
   scan_encoder();
  if(! PIND)                //當(dāng)按下旋鈕時(shí)
       counter = 0;            //計(jì)數(shù)單元清零(歸位)
       delayms(10);
Timer2中斷函數(shù)
void  timer2() interrupt 5
   TR2 = 0;
   TF2 = 0;                         //手工清中斷標(biāo)志
   TH2 = 0xfc;                      //1ms定時(shí)常數(shù)
   TL2 = 0x66;
   if(n >= 3)                       //3位數(shù)碼管顯示
     n = 0;
     shift = 0xfe;                  //送位碼初值
     P2 = 0xff;                     //關(guān)閉顯示
     display[0] = counter%10;       //個(gè)位數(shù)據(jù)
     display[1] = (counter%100)/10; //十位數(shù)據(jù)
     display[2] = counter/100;      //百位數(shù)據(jù)
     if(display[2] == 0)
       display[2] = 0x0a;           //百位為0,不顯示
       if(display[1] == 0)
       display[1]  =0x0a;           //十位為0,不顯示
     P0 = LEDData[display[n++]];    //送段碼
     P2 = shift;                    //送位碼
     shift = (shift<<1)|0x01;       //調(diào)整位碼
   TR2 = 1;
ID:7485 發(fā)表于 2016-4-26 21:31 | 只看該作者
把程序里面的time2改為time1或time0即可。
ID:116352 發(fā)表于 2016-4-26 22:04 | 只看該作者
ahshmj 發(fā)表于 2016-4-26 21:31
謝謝  這是我改變后的程序  就是我說(shuō)的那樣
#include <reg51.h>
sbit     PINA    = P1^0;
sbit     PINB    = P1^1;
sbit     PIND    = P1^2;
  unsigned char  counter;  //編碼器脈沖計(jì)數(shù)
ms延時(shí)子函數(shù)
  unsigned char k;
  while (ms--)
掃描編碼器子函數(shù)
在編碼器引腳A為低電平期間:
     updata = 0;
     return;
     updata = 1; }
   if(updata)
   updata = 0 ;
   if(counter == 255)
       return;
       if(counter == 0)
       return;
主函數(shù)
void  main(void)
   P0 = 0xff;
   P1 = 0xff;
   P2 = 0xff;
           TMOD &= 0xf1;        //設(shè)置定時(shí)器模式
        TMOD |= 0x01;        //設(shè)置定時(shí)器模式
        TL0 = (65636-50000)/256;                //設(shè)置定時(shí)初值
        TH0 = (65636-50000)%256;                //設(shè)置定時(shí)初值
        TF0 = 0;                //清除TF0標(biāo)志
        ET0 = 1;
        TR0 = 1;                //定時(shí)器0開(kāi)始計(jì)時(shí);
        EA = 1;
                        //啟動(dòng)定時(shí)器2
  scan_encoder() ;
       delayms(10);
Timer0中斷函數(shù)
void  timer0() interrupt 1
{                 TR0 = 0;
              TF0 = 0;
     n = 0;
     if(display[2] == 0)
           if(display[1] == 0)
       {display[1]  =0x0a;           //十位為0,不顯示
     P2 = shift;                    //送位碼
          TR0 = 1;
