查看: 2279|回復(fù): 1
12860驅(qū)動(dòng)程序
ID:119983 發(fā)表于 2016-5-11 10:38 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
12860驅(qū)動(dòng)程序
#include "stdio.h"
#include "regdefs.h"
#include "intrins.h"
#include "user.h"
#include "LCM6059B.h"
#define UINT8  unsigned char         // 0~255
#define UINT16 unsigned short int    // 0~65535
#define INT8   signed int
//////////// LCD Control Command ////////////
#define DISPLAY_ON               0xaf
#define DISPLAY_OFF              0xae
#define DISPLAY_ALL_POINT_ON     0xa4
#define DISPLAY_ALL_POINT_OFF    0xa5
#define DISPLAY_START_LINE_SET   0x40  //line (0~3f)
#define PAGE_ADDRESS_SET         0xb0  //page (0~8)
#define COLUMN_HIGH_SET          0x10  //high 4 bits
#define COLUMN_LOW_SET           0x0f  //low  4 bits
#define DISPLAY_RD_WR_MODIFY     0xe0
#define DISPLAY_RD_WR_MODIFY_END 0xee
#define DISPLAY_CONTTAST_LEVEL   0x81  //level (0~3f)
#define ADC_DIR_SELECT           0xa0
#define DISPLAY_NORMAL                 0xa6
#define DISPLAY__REVERSE         0xa7
#define LCD_BIAS_SET             0xa2  //1/9,0        1/7,1
#define LCD_RESET                0xe2
#define COM_OUTPUT_SET           0xC0  //mode 0x00, 0x08
#define POWER_CTRL_SET           0x20  //mode 0x08,0x2c,0x2e,0x2f
#define BOOST_RATIO_SET          0xf8  //0x00,0x01,0x02,0x3
#define VO_CTRL_SET              0x20  //Rb/Ra(0~7)
#define OP_NOP                   0xe3  //空操作
//////////// MCU IO configuration ////////////
#define LCD_PORT_CFG    sfr_GP_CONTROL1         &=(~0x01)  //bit0
#define        LCD_PORT_OUT    sfr_GPIOA_DIRECTION &=(~0xff);
#define LCD_PORT_IN     sfr_GPIOA_DIRECTION |=0xff;
#define LCD_PORT        sfr_GPIOA_DATA
// LCD_EN GPIOE_6
// LCD_WR GPIOE_5
#define LCD_WR_EN_OUT   sfr_GPIOE_DIRECTION &=(~0x60)
#define LCD_EN_SET(x)   x?(sfr_GPIOE_DATA|=0x40):(sfr_GPIOE_DATA&=(~0x40))
#define LCD_WR_SET(x)   x?(sfr_GPIOE_DATA|=0x20):(sfr_GPIOE_DATA&=(~0x20))
//LCD_A0  GPIOC_4           H->data ,L-> cmd
#define LCD_A0_OUT      sfr_GPIOC_DIRECTION &=(~0x10)
#define LCD_A0_SET(x)   x?(sfr_GPIOC_DATA|=0x10):(sfr_GPIOC_DATA&=(~0x10))
//LCD_RST GPIOC_3
//LCD_CS  GPIOC_2
//sfr_EXT_INT_xF6  bit7
#define LCD_RST_CS_CFG  sfr_EXT_INT_xF6 &=(~0x80)
#define LCD_RST_CS_OUT  sfr_GPIOC_DIRECTION &=(~0x0c)
#define LCD_RST_SET(x)  x?(sfr_GPIOC_DATA|=0x08):(sfr_GPIOC_DATA&=(~0x08))
#define LCD_CS_SET(x)   x?(sfr_GPIOC_DATA|=0x04):(sfr_GPIOC_DATA&=(~0x04))
UINT8   ContrastLevel;              // for contrast setting level
void DelayMs(UINT16 m)
{ //12MHZ
     UINT16 jj;
     UINT16 ii;
     for (ii=0; ii<m; ii++)
        for (jj=0; jj<109; jj++);
BOOL CheckBusy(void)
         LCD_RST_CS_CFG;
         LCD_RST_CS_OUT;
         LCD_PORT_CFG;
         LCD_PORT_OUT;
         LCD_A0_OUT;
         LCD_WR_EN_OUT;
         LCD_A0_SET(0);               //命令通道選通
         LCD_WR_SET(1);               //設(shè)置讀狀態(tài)
         LCD_CS_SET(0);
         LCD_PORT=0x80;
         LCD_EN_SET(1);
         LCD_PORT_IN;
         _nop_();
         if (LCD_PORT&0x80) return(0);
         else return(1);
void SendCmd(UINT8 Cmd)
     Hal_DisableAllInts();        //為了時(shí)序完整性,禁止中斷
     LCD_RST_CS_CFG;                //根據(jù)MCU的不同,有可能要配置GPIO
         LCD_PORT_CFG;
         LCD_RST_CS_OUT;
         LCD_PORT_OUT;
     LCD_A0_OUT;
         LCD_WR_EN_OUT;
         LCD_A0_SET(0);                    // 設(shè)置指令通道
         LCD_WR_SET(0);                        // 設(shè)置寫(xiě)狀態(tài)
         LCD_CS_SET(0);                        // Chip select
         LCD_PORT=Cmd;                    // 發(fā)送命令
         LCD_EN_SET(1);
         _nop_();
         LCD_EN_SET(0);
         LCD_CS_SET(1);
         Hal_EnableAllInts();   //中斷開(kāi)
void SendData(UINT8 DData)
         //CheckBusy()
     LCD_RST_CS_CFG;
         LCD_RST_CS_OUT;
         LCD_PORT_CFG;
         LCD_PORT_OUT;
     LCD_A0_OUT;
         LCD_WR_EN_OUT;
         LCD_A0_SET(1);                      //設(shè)置數(shù)據(jù)通道
         LCD_WR_SET(0);
         LCD_CS_SET(0);
         LCD_PORT=DData;             //發(fā)送數(shù)據(jù)
         LCD_EN_SET(1);
         _nop_();
         LCD_EN_SET(0);
         LCD_CS_SET(1);
UINT8 ReadData()
     UINT8 DData;
         LCD_RST_CS_CFG;
         LCD_RST_CS_OUT;
     LCD_PORT_CFG;
         LCD_PORT_OUT;
     LCD_A0_OUT;
         LCD_WR_EN_OUT;
         LCD_A0_SET(1);                   //數(shù)據(jù)通道選通
         LCD_CS_SET(0);
         LCD_PORT=0xff;
         LCD_EN_SET(1);
         LCD_PORT_IN;
         _nop_();
         DData=LCD_PORT;
         LCD_EN_SET(0);
         LCD_CS_SET(1);
     return(DData);       // 返回?cái)?shù)據(jù)值
void DrawDots2(UINT8 x,UINT8 y,UINT8 flg)
{// 坐標(biāo)(x,y),x為列地址,y為行地址
     UINT8 p,m;
     p=y/8;
     SendCmd(p|PAGE_ADDRESS_SET);       // 設(shè)置頁(yè)地址
     SendCmd((x>>4)|COLUMN_HIGH_SET);  // 設(shè)置列地址高4位
     SendCmd(x&COLUMN_LOW_SET);       // 設(shè)置列地址低4位
     SendCmd(DISPLAY_RD_WR_MODIFY);         // 設(shè)置修改寫(xiě)模式
     y=y%8;
     m=0x01;
     y=m<<y;                 /列地址不進(jìn)行加1
     m=ReadData();          // 空讀操作
     m=ReadData();          // 讀第m列數(shù)據(jù)
     SendCmd(OP_NOP);         // 空操作
         if (flg)               //實(shí)點(diǎn)
        m|=y;
         else                         //虛點(diǎn)
            m&=(~y);
     SendData(m);             // 寫(xiě)數(shù)據(jù)
     SendCmd(DISPLAY_RD_WR_MODIFY_END);
void PrintAscii(UINT8 x,UINT8 y,UINT8 *pstr)
{ //(x,y)為坐標(biāo)
     UINT8 ii,jj;
         UINT16 addr;
         if ((y%8)==0)
            SendCmd(y|PAGE_ADDRESS_SET);
        while (*pstr)
             addr=*pstr++;                      // 取字符代碼
             addr=(addr-0x20)*8;                // 計(jì)算字符字模起始地址
             for (jj=0;jj<6;jj++)
                  SendData(ASCIITAB[addr+jj]);  //  寫(xiě)字模數(shù)據(jù)
         else                                                           //如否, 由于是跨頁(yè)操作,則采用描點(diǎn)方式
                      while (*pstr)                           //非0
                                   for (jj=0;jj<6;jj++)           //6*8點(diǎn)陣字符
                                    for (ii=0;ii<8;ii++)
                                             DrawDots2(x+jj,y+ii,((ASCIITAB[addr+jj]>>ii)&0x01));
                                   x+=6; //        描完一個(gè)字,地址加6
void PrintChar2(UINT8 x, UINT8 y,UINT8 *pstr)
{// 坐標(biāo)(x,y),x為水平方向像素列;y為垂直方向字符行(8點(diǎn)像素/行)
     UINT8 jj,ii;
     UINT16 addr;
void PrintText(UINT8 x, UINT8 y,UINT16 *pstr)
     UINT16 addr;
     UINT8 jj;
         UINT16 Index,ii;
         BOOL IsASCII=FALSE;
         UINT8 n,ch;
     while(*pstr)
            if (*pstr<0x8000 && *pstr!=0x2300/*#*/)        //是否是ASCII碼
                    ch=(UINT8)(*pstr>>8);
                        PrintChar2(x,y+4,&ch);          //地址調(diào)整
                        x+=6;
                        ch=(UINT8)(*pstr);
                        pstr++;
                        x+=6;
                else{
               ii=0;
               while(1)        //查找機(jī)內(nèi)碼
                      if (GBK16TAB[ii]==(*pstr>>8) && GBK16TAB[ii+1]==(*pstr&0xff))
                            Index=ii;
                                break;
                        ii+=34;
                        if (ii>=500-32) break;           //避免溢出
                        if (*pstr==0x2300/*#*/) break;
          addr=Index+2;                 // 取得字模存儲(chǔ)首地址
                  for (n=0;n<2;n++)  //
                  for (jj=0; jj<16;jj++) //先左后右,共width點(diǎn)
                          for (ii=0;ii<8;ii++)  //先描上后下,共8點(diǎn)
                                   DrawDots2(x,y+ii,((GBK16TAB[addr+jj]>>ii)&0x01));
                              x++;
                  y+=8;
                          x-=16;
                          addr+=16;
                  x+=16;
                  y-=16;
                  pstr++;
void LCD_SetContrast(BOOL bhv)
     if (bhv)
        if (ContrastLevel>0x3f) ContrastLevel++;
            if (ContrastLevel>0x00) ContrastLevel--;
     SendCmd(DISPLAY_CONTTAST_LEVEL);
     SendCmd(ContrastLevel);
         return;
void ShowBMP(UINT8 x,UINT8 y,UINT8 width,UINT8 hight,UINT8 bmp[])
{// (x,y)為圖像顯示開(kāi)始坐標(biāo)
     UINT8 ii,jj,page,Index;
         Index=0;
         page=0;
     while(page<hight)
             for (jj=0; jj<width;jj++) //先左后右,共width點(diǎn)
                             DrawDots2(x,y+ii,((bmp[Index]>>ii)&0x01));
                         x++;
                         Index++;
             y+=8;
                 x-=width;
                 page+=8;
void DrawLine(UINT8 x1,UINT8 y1,UINT8 x2,UINT8 y2)
{//坐標(biāo)(x1,y1)為線起始地址坐標(biāo);坐標(biāo)(x2,y2)為線終止地址坐標(biāo)
     UINT8 temp;
     INT8 Xt,Yt,err=0;
     if (y1>y2)
        temp=x1; x1=x2; x2=temp;
        temp=y1; y1=y2; y2=temp;
     DrawDots2(x1,y1,1);
     Xt=x2-x1;
     Yt=y2-y1;
     if (Xt>=0)
        if (Yt>Xt)//k>1
           while (y1<y2)
               if (err<0)
                  x1=x1+1;
                  y1=y1+1;
                  err=err+Yt-Xt;
               else        //err>=0
                  y1=y1+1;
                  err=err-Xt;
               DrawDots2(x1,y1,1);
       else  // 0<=k=<1
          if (Yt==0) y1=y1-1;
          while (x1<x2)
              if (err<0)
                 x1=x1+1;
                 err=err+Yt;
                 y1=y1+1;
                 x1=x1+1;
                 err=err+Yt-Xt;
              DrawDots2(x1,y1,1);
       Xt=x1-x2;
       if (Yt>Xt)//k<-1
          while (y1<y2)
             if (err<0)
                 x1=x1-1;
                 y1=y1+1;
                 err=err+Yt-Xt;
                 y1=y1+1;
                 err=err-Xt;
             DrawDots2(x1,y1,1);
    else       //0>k>=-1
       if (Yt==0) y1=y1-1;
       while (x1>x2)
          if (err<0)
              x1=x1-1;
              err=err+Yt;
              x1=x1-1;
              y1=y1+1;
              err=err+Yt-Xt;
          DrawDots2(x1,y1,1);
void ClearAllRAM()
     UINT16 i,j;
     for (i=0;i<8;i++)            //寫(xiě)8頁(yè)
          SendCmd(i|PAGE_ADDRESS_SET);
          SendCmd(0x10);
          SendCmd(0x00);
          for (j=0;j<132;j++)
             SendData(0);
void InitLCM6059B(void)
     LCD_RST_CS_CFG;
         LCD_RST_CS_OUT;
         LCD_RST_SET(0);
         DelayMs(10);
         LCD_RST_SET(1);
         DelayMs(10);
     ContrastLevel=0x21;                // 對(duì)比度參數(shù)初始化設(shè)置
     SendCmd(DISPLAY_ON);               // 開(kāi)顯示
     SendCmd(DISPLAY_START_LINE_SET|0); // 設(shè)置顯示起始行=0
     SendCmd(ADC_DIR_SELECT);           // RAM列地址與列驅(qū)動(dòng)同順序
     SendCmd(DISPLAY_NORMAL);           // 正向顯示
     SendCmd(DISPLAY_ALL_POINT_ON);     // 顯示全亮功能關(guān)閉
     SendCmd(LCD_BIAS_SET|0);           // LCD偏壓比為1/9
     SendCmd(COM_OUTPUT_SET|0x08);      // 行驅(qū)動(dòng)方向?yàn)榉聪?br />      SendCmd(POWER_CTRL_SET|0x0f);      // 啟用內(nèi)部LCD驅(qū)動(dòng)電源
         SendCmd(VO_CTRL_SET|0x05);                        // 電阻比
     SendCmd(BOOST_RATIO_SET);
         SendCmd(0x00);                     // 倍壓設(shè)置為4X
         SendCmd(0x21);                     // 設(shè)置對(duì)比度
         ClearAllRAM();
         return;
ID:1 發(fā)表于 2016-5-11 16:57 | 只看該作者
#include "user.h"
這個(gè)幾個(gè)頭文件能否打包分享一下呢?
