12864的顯示仿真電路圖
全部資料下載:
12864.rar
(49.89 KB, 下載次數(shù): 171)
2016-5-13 21:31 上傳
點(diǎn)擊文件名下載附件
不帶字庫(kù)的12864顯示程序:
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- //下面是"歡迎訪問(wèn)伊人憔悴百度空間"點(diǎn)陣數(shù)據(jù),一個(gè)漢字有32字節(jié)數(shù)據(jù)組成
- unsigned char code wu[]= // 梧
- 0x10,0x10,0xD0,0xFF,0x90,0x10,0x82,0x92,0xF2,0x9E,0x92,0x92,0x92,0xF2,0x82,0x00,
- 0x04,0x03,0x00,0xFF,0x00,0x01,0x00,0xFC,0x44,0x44,0x44,0x44,0x44,0xFC,0x00,0x00,
- unsigned char code zhou[]= //州
- 0x00,0xE0,0x00,0xFF,0x00,0x20,0xC0,0x00,0xFE,0x00,0x20,0xC0,0x00,0xFF,0x00,0x00,
- 0x81,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,
- unsigned char code xue[]= //學(xué)
- 0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,
- 0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00,
- unsigned char code yuan[]= //院
- 0x00,0xFE,0x22,0x5A,0x86,0x10,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x14,0x0C,0x00,
- 0x00,0xFF,0x04,0x08,0x07,0x80,0x41,0x31,0x0F,0x01,0x01,0x3F,0x41,0x41,0x71,0x00,
- unsigned char code huan[]= //歡
- 0x04,0x24,0x44,0x84,0x64,0x9C,0x40,0x30,0x0F,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,
- 0x10,0x08,0x06,0x01,0x82,0x4C,0x20,0x18,0x06,0x01,0x06,0x18,0x20,0x40,0x80,0x00,
- unsigned char code ying[]= //迎
- 0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x04,0x02,0x00,0xFC,0x04,0x04,0xFC,0x00,0x00,
- 0x00,0x40,0x20,0x1F,0x20,0x40,0x4F,0x44,0x42,0x40,0x7F,0x42,0x44,0x43,0x40,0x00,
- unsigned char code nin[]= //您
- 0x20,0x10,0x08,0xFC,0x23,0x10,0x88,0x67,0x04,0xF4,0x04,0x24,0x54,0x8C,0x00,0x00,
- 0x40,0x30,0x00,0x77,0x80,0x81,0x88,0xB2,0x84,0x83,0x80,0xE0,0x00,0x11,0x60,0x00,
- unsigned char code m[]= //!
- 0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- sbit CS1=P2^0;//片選1,低電平有效,CS1=0開(kāi)左屏幕,CS1=1關(guān)左屏幕
- sbit CS2=P2^1;//片選2,低電平有效,CS2=0開(kāi)右屏幕,CS2=1關(guān)右屏幕
- sbit RS=P2^2;//數(shù)據(jù),指令選擇信號(hào),RS=1為數(shù)據(jù)操作,RS=0為寫(xiě)指令或讀狀態(tài)(一般為讀忙標(biāo)志)
- sbit RW=P2^3;//讀寫(xiě)選擇信號(hào),RW=1為讀選通,RW=0為寫(xiě)選通
- sbit EN=P2^4;//讀寫(xiě)使能信號(hào)
- void busy()//忙檢測(cè)函數(shù)
- {P0=0X00; //這句不能少
- RS=0;
- RW=1;
- EN=1;
- while(P0&0X80);//P0&0X80結(jié)果為真則一直執(zhí)行空操作,也就是說(shuō)P0&0X80為0則結(jié)束循環(huán)
- EN=0;
- void wcmd(uchar cmd)
- {busy(); //每次寫(xiě)入指令或數(shù)據(jù)之前都進(jìn)行忙檢測(cè)
- RS=0;
- RW=0;
- P0=cmd;
- EN=1;_nop_();_nop_();//在EN下降沿寫(xiě)入數(shù)據(jù)和指令
- EN=0;
- void wdata(uchar dat) //寫(xiě)命令和寫(xiě)數(shù)據(jù)只在RS=0或RS=1上不同,其余都相同
- {busy();
- RS=1;
- RW=0;
- P0=dat;
- EN=0;
- void set_page(uchar page)//設(shè)置頁(yè),12864LCD共有8頁(yè),每頁(yè)有8行點(diǎn)陣點(diǎn)。
- {page=0xb8|page; //首頁(yè)地址為0XB8
- wcmd(page); //page取值范圍為0~7,表示第1到8頁(yè)
- void set_line(uchar line)//設(shè)置顯示的起始行,共有0--63行,一般從0行開(kāi)始顯示
- {line=0xc0|line; //起始行地址0XC0
- wcmd(line); //line取值范圍為0~63,表示第1到64行
- void set_column(uchar column)//設(shè)置顯示的列
- {//column=column&0x3f; //列的最大值為0X3F,即64
- column=0x40|column; //列的首地址為0X40,
- wcmd(column); //column的取值范圍為0~63,共64列
- void set_onoff(uchar onoff)//設(shè)置顯示開(kāi)關(guān),onoff取值為0或1
- {onoff|=0x3e;//0X3E是關(guān)顯示,0X3F是開(kāi)顯示
- wcmd(onoff);//所以若onoff為0,則表示關(guān)顯示,onoff為1,則表示開(kāi)顯示
- void select_screen(uchar screen)//選屏,screen取值范圍為0,1,2
- {switch(screen)
- {case 0:CS1=0;CS2=0;break; //全屏
- case 1:CS1=0;CS2=1;break; //左半屏
- case 2:CS1=1;CS2=0;break; //右半屏
- default:break;
- void clear_screen(uchar screen)//清屏
- {uchar i,j;
- select_screen(screen);//先選屏
- for(i=0;i<8;i++)//控制頁(yè)數(shù)0--7,共8頁(yè)
- {set_page(i);//設(shè)置頁(yè)
- set_column(0); //設(shè)置列,每頁(yè)都從第1列開(kāi)始,共64列
- for(j=0;j<64;j++)//控制列數(shù)0--63,共64列
- wdata(0x00);//寫(xiě)入0,列地址指針會(huì)自動(dòng)加1
- void init() //LCD初始化
- {busy(); //忙檢測(cè)
- select_screen(0);//選屏,全屏
- set_onoff(0); //關(guān)顯示
- select_screen(0); //選屏,全屏
- set_onoff(1); //開(kāi)顯示
- clear_screen(0); //清屏
- set_line(0); //起始行:0
- void show(uchar screen,uchar page,uchar column,uchar *p)//顯示一個(gè)漢字,一個(gè)漢字有32字節(jié)數(shù)據(jù)
- {uchar i; //screen表示選擇屏幕,page表示頁(yè),column表示列,*p表示漢字的數(shù)組
- select_screen(screen); //選屏
- set_page(page); //設(shè)置頁(yè),寫(xiě)上半頁(yè)
- set_column(column);//設(shè)置列
- for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
- wdata(p[i]); //漢字的上半部分
- set_page(page+1); //寫(xiě)下半頁(yè)
- set_column(column); //控制列
- wdata(p[i+16]); //漢字的下半部分
- void main()
- {init(); //LCD初始化
- set_line(0); //顯示開(kāi)始行
- //1表示左屏顯示,0表示從0頁(yè)開(kāi)始顯示。因?yàn)橐豁?yè)只有8行點(diǎn),
- //而顯示一個(gè)漢字需要16行點(diǎn)(整屏有64行點(diǎn)),所以顯示一個(gè)漢字需要2頁(yè)
- //第0頁(yè)顯示"歡"字的上半部分,第1頁(yè)顯示"歡"漢字的下半部分
- //2*16表示從第32列開(kāi)始顯示,前面空出0~31列(即2個(gè)字的位置)
- show(1,2,2*16,wu);//梧
- //3*16表示從第48列開(kāi)始顯示,前面空出0~47列(即3個(gè)漢字的位置)
- show(1,2,3*16,zhou);//州
- //2表示右屏顯示,0表示從0頁(yè)開(kāi)始顯示
- //0*16表示從第0列開(kāi)始顯示(即第一個(gè)漢字的位置)
- show(2,2,4*16,xue);//學(xué)
- //1*16表示從第16列開(kāi)始顯示,前面空出0~15列(即一個(gè)漢字的位置)
- show(2,2,5*16,yuan); //院
- //左屏開(kāi),從第3頁(yè)(共8頁(yè))第0列開(kāi)始顯示,即第3,4頁(yè)顯示"伊人憔悴百度空間"幾個(gè)字
- show(1,4,2*16,huan); //歡
- show(1,4,3*16,ying); //迎
- show(2,4,4*16,nin); //您
- show(2,4,5*16,m); //!
- while(1);
