查看: 2195|回復(fù): 2
急急急!! 數(shù)字時(shí)鐘 但切換不了調(diào)鬧鐘的畫面
一直按著切換按鈕 可以調(diào)鬧鐘  鬧鐘到了LED閃爍    但是程序按著切換按鈕無(wú)法切換到鬧鐘畫面   還是繼續(xù)計(jì)時(shí) 為什么 ? #include<reg51.h>
#include<intrins.h>
sbit NZSET=P1^7;
uchar code DSY_CODE[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xFF};
uchar DSY_BUFFER[]={0,0,0xBF,0,0,0xBF,0,0}; //顯示緩存
uchar Scan_BIT;    //掃描位,選擇要顯示的數(shù)碼管
uchar DSY_IDX;            //顯示緩存索引
uchar Key_State;   //P1端口按鍵狀態(tài)
uchar h,m,s,s100;  //十分秒,1/100s
uchar dispnz[8];   //鬧鐘數(shù)組
uchar code table[13]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0x39,0x00};
uchar code scan[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xbf,0x7f,0xdf};
unsigned char restar=0;
unsigned char Second1,Minute1,Hour1;
bit nzbz;
void Delay(uchar x)  //延時(shí)
uchar i;
while(x--) for(i=0;i<120;i++);           //計(jì)時(shí)函數(shù)
//鬧鐘設(shè)置掃描顯示函數(shù)
void SCANDISPNZ()
  unsigned char i,value;
  for(i=0;i<8;i++)
        P3=0xff;
        value=table[dispnz[i]];
        P0=value;
        P3=scan[i];
        Delay(50);
//鬧鐘顯示內(nèi)容處理函數(shù)
void DISPLAYNZ()
  SCANDISPNZ();
  dispnz[6]=Second1/10;
  dispnz[7]=Second1%10;
  dispnz[5]=10;
  dispnz[3]=Minute1/10;
  dispnz[4]=Minute1%10;
  dispnz[2]=10;
  dispnz[0]=Hour1/10;
  dispnz[1]=Hour1%10;
void Increase_Hour()                         //計(jì)算時(shí)的函數(shù)
if(++h>23)h=0;
    DSY_BUFFER[0]=DSY_CODE[h/10];
    DSY_BUFFER[1]=DSY_CODE[h%10];
void Increase_Minute()
{                                                           //計(jì)算分的函數(shù)
if(++m>59)
m=0;Increase_Hour();
DSY_BUFFER[3]=DSY_CODE[m/10];
DSY_BUFFER[4]=DSY_CODE[m%10];
void Increase_Second()                   //計(jì)算秒的函數(shù)
if((++s>59))
     s=0;Increase_Minute();
DSY_BUFFER[6]=DSY_CODE[s/10];
DSY_BUFFER[7]=DSY_CODE[s%10];
void T0_INT() interrupt 1          //T0中斷動(dòng)態(tài)掃描數(shù)碼管顯示
  TH0=(65536-1000)/256;
  TL0=(65536-1000)%256;
  P3=Scan_BIT;                                 //選通相應(yīng)數(shù)碼管
  P0=~DSY_BUFFER[DSY_IDX];   //段碼送P0取反
  Scan_BIT=_crol_(Scan_BIT,1); //準(zhǔn)別下次選通的數(shù)碼管
  DSY_IDX=(DSY_IDX+1)%8;            //索引0-7內(nèi)循環(huán)
void T1_INT() interrupt 3         //中斷時(shí)鐘控制程序運(yùn)行
    TH1=(65536-50000)/256;
    TL1=(65536-50000)%256;
    if(++s100==20)
    {                                                //50ms*20=1s延時(shí)
    s100=0;Increase_Second();
void KEY_TEST()          //時(shí)間設(shè)定與復(fù)位
  P0=P3=0xFF;
  TMOD=0x11;            //T0,T1工作在模式1
  TH1=0xDC;
  TL1=0;
  TCON=0x01;
  EA=1;                     //開(kāi)中斷
  ET0=1;
  ET1=1;
  h=0;
  m=s=s100=0;                                    //將時(shí)分秒放入顯存
   Scan_BIT=0xFE; DSY_IDX=0;
   TR0=TR1=1;                                    //啟動(dòng)兩個(gè)定時(shí)器
Key_State=0xFF;
if(P1^Key_State)
Delay(10);
if(P1^Key_State)
Key_State=P1;EA=0;
  if((Key_State&0x04)==0)Increase_Hour();           //小時(shí)+1
  if((Key_State&0x02)==0)Increase_Minute();          //分鐘+1
  if((Key_State&0x01)==0)Increase_Second();          //秒+1
  else if((Key_State&0x08)==0)
   s=0;
   m=0;
   h=0;
   EA=1;
//鬧鐘設(shè)定按鍵掃描和鍵值處理函數(shù)
void NZKEY_TEST()
  DISPLAYNZ();
  P1=0xff;
  restar=0;
  if((Key_State&0x10)==0)                                   //秒+1
        Delay(100);
          Increase_Second1();
          if(Second1==60)
                Second1=0;
                while((Key_State&0x10)==0) DISPLAY();
  if((Key_State&0x20)==0)                                        //分+1
        Delay(100);
          Increase_Minute1();
          if(Minute1==60)
                Minute1=0;
                while((Key_State&0x20)==0) DISPLAY();
  if((Key_State&0x40)==0);                                        //時(shí)+1
        Delay(100);
          Increase_Hour1();
          if(Hour1==24)
                 Hour1=0;
                while((Key_State&0x40)==0) DISPLAY();
//主函數(shù)
  Hour1=0;
  Minute1=0;
  Second1=0;
  s100=0;
  h=0;
  m=0;
  s=0;
  TMOD=0x01;
  TH0=(65536-1000)/256;                          //T0定時(shí)器
  IE=0x82;
  TR0=1;
  P2=1;
  while(1)                                                         //跳轉(zhuǎn)鬧鐘程序
        if(NZSET=1)
        {KEY_TEST();}
        else  NZKEY_TEST();
        if((h=Hour1)&&(m=Minute1)&&(s=Second1))
          P2=0;
          nzbz=1;
        if(restar==1)
        break;
ID:125657 發(fā)表于 2016-6-11 22:14 | 只看該作者
ID:125657 發(fā)表于 2016-6-12 09:17 來(lái)自手機(jī) | 只看該作者
大神都在哪里
