查看: 5297|回復(fù): 10
大神們 小白一枚 程序報(bào)錯(cuò) 解決不了 求助
ID:127278 發(fā)表于 2016-6-19 23:24 | 顯示全部樓層 |閱讀模式
#include <at89x51.h>
#include <intrins.h>
uchar wr_com;
sbit DQ=P2^3;//ds18b20與單片機(jī)連接口
sbit RS=P2^5;
sbit RW=P2^6;
sbit EN=P2^7;
uchar data disdata[5];
uint tvalue,CurrentT=0;//溫度值
uchar tflag;//溫度正負(fù)標(biāo)志
#define LCD_BUS P0
sbit SetKey = P2^2;
sbit UpKey  = P2^1;
sbit DnKey  = P2^0;
sbit BEEP   = P2^4;
sbit Heat  = P1^0;
sbit Cool   = P1^1;
unsigned char AlarmTempLow=10,AlarmTempTop=40,Set=0,NG=0;
void delayms(uint ms)   //延時(shí)xx毫秒
uchar i;  while(ms--)
for(i=0;i<120;i++);  } }
void command(uint com)
RS=0;
LCD_BUS=com;
delayms(5);
EN=1;
delayms(5);
EN=0;  }
void write_dat(uchar dat)
{        RS=1;
LCD_BUS=dat;
delayms(5);
EN=1;
delayms(5);
EN=0;  }
void writestring (uchar x ,uchar y,uchar s)
{ if (y == 0)  command(0x80 + x);
   else  command(0xC0 + x);
   while( s)
   write_dat( s);      } }
void writeChar (uchar x ,uchar y,uchar s)
   write_dat( s);
void LCD_Initial()
EN=0;
RW=0;
command(0x38);
command(0x0c);
command(0x06);
command(0x01);
command(0x80+0x02);  }
void delay_18B20(unsigned int i)
{while(i--);}
void ds1820rst(void)
{unsigned char x=0;
DQ=1;
delay_18B20(4);
DQ=0;
delay_18B20(4);
DQ=1;
delay_18B20(4);
uchar ds1820rd(void)
{unsigned char i=0;unsigned char dat=0;for(i=8;i>0;i--)
{DQ=0;dat>>=1;DQ=1;if(DQ)dat|=0x80;delay_18B20(10);}
return(dat);}
void ds1820wr(uchar wdata)
{unsigned char i=0;
for(i=8;i>0;i--)
{DQ=wdata&0x01;
delay_18B20(10);
DQ=1;wdata>>=1;}
unsigned int Read_Temperature(void)
{uchar a,b;
ds1820rst();
ds1820wr(0xcc);
ds1820wr(0x44);
ds1820rst();
ds1820wr(0xcc);
ds1820wr(0xbe);
a=ds1820rd();
b=ds1820rd();
tvalue=b;
tvalue<<=8;
tvalue=tvalue|a;
if(tvalue<0x0fff)
tflag=0;
else {tvalue=~tvalue+1;tflag=1;}
tvalue=tvalue*(0.625);
CurrentT=tvalue;
return(tvalue);
void Display_Temperature()
uchar flagdat;
disdata[0]=tvalue/1000+0x30;
disdata[1]=tvalue%1000/100+0x30;
disdata[2]=tvalue%100/10+0x30;
disdata[3]=tvalue%10+0x30;
if(tflag==0)
flagdat=0x20;
flagdat=0x2d;//負(fù)溫度顯示負(fù)號(hào):-    //
if(disdata[0]==0x30)
disdata[0]=0x20;
if(disdata[1]==0x30)
disdata[0]=0x20; }
if(tflag==1)
writeChar(10,0,flagdat); //
wr_com (0x8a); wr_dat(flagdat);//顯示符號(hào)位
writeChar(11,0,disdata[0]); //
wr_com (0x8b); wr_dat(disdata[0]);//顯示百位
writeChar(12,0,disdata[1]);//
wr_com (0x8c);wr_dat(disdata[1]);//顯示十位
  writeChar(13,0,disdata[2]);//
  wr_com(0x8d);        wr_dat(disdata[2]);//顯示個(gè)位
  writeChar(14,0,0X2E);//
  wr_com (0x8e);wr_dat(0x2e);//顯示小數(shù)點(diǎn)
  writeChar(15,0,disdata[3]);//
  wr_com (0x8f); wr_dat(disdata[3]);//顯示小數(shù)位
  else  {writeChar (10,0,disdata[0]);//
  wr_com(0x8a);wr_dat(disdata[0]);//顯示百位
   writeChar(11,0,disdata[1]);//
   wr_com(0x8b);wr_dat(disdata[1]);//顯示十位
   writeChar(12,0,disdata[2]);//
   wr_com(0x8c);
   writeChar(13,0,0X2e);
   wr_com(0x8d);
    writeChar(14,0,disdata[3]);
        wr_com(0x8e);
void SetFun(void)
unsigned char i1=0,i2=0,i3=0,i4=0,i5=0,i6=0;
if(SetKey==0)
{   delayms(20);   if(SetKey==0)
{   if(Set<2) Set++;    else Set=0; }
switch(Set)
case 0:  writestring(0,1," ");
writestring(8,1," ");
break;
case 1: writestring(0,1,">");
break;
case 2: writestring(0,1," ");
writestring(8,1,">");
break;   }
while(SetKey==0);  }
if((UpKey==0)&&(Set!=0))
delayms(20);
if(UpKey==0)
switch(Set)
case 1: if(AlarmTempLow<99)
AlarmTempLow++;
else AlarmTempLow=99;
break;
  case 2: if(AlarmTempTop<99) AlarmTempTop++;
else AlarmTempTop=99; break;    }
i1 = AlarmTempLow/100;
i2 = AlarmTempLow%100/10;
i3 = AlarmTempLow%10;
  i4 = AlarmTempTop/100;
i5 = AlarmTempTop%100/10;
i6 = AlarmTempTop%10;
writestring(5,1,"   ");
writestring(13,1,"     ");
if(i1!=0) writeChar(5,1,i1+'0');
if((i1==0)&&(i2!=0)) writeChar(5,1,i2+'0');
if(i1!=0) writeChar(6,1,i2+'0');
if((i1==0)&&(i2==0)) writeChar(5,1,i3+'0');
else if((i1==0)&&(i2!=0)) writeChar(6,1,i3+'0');
if((i1!=0))  writeChar(7,1,i3+'0');
if(i4!=0) writeChar(13,1,i4+'0');
if((i4==0)&&(i5!=0))
writeChar(13,1,i5+'0');
if(i4!=0) writeChar(14,1,i5+'0');
if((i4==0)&&(i5==0)) writeChar(13,1,i6+'0');
else if((i4==0)&&(i5!=0)) writeChar(14,1,i6+'0');
if((i4!=0)) writeChar(15,1,i6+'0');
while(UpKey==0);   }  }
if((DnKey==0)&&(Set!=0))
delayms(20);
if(DnKey==0)
switch(Set)
case 1: if(AlarmTempLow>0) AlarmTempLow--;
else AlarmTempLow=0;
break;
case 2: if(AlarmTempTop>0) AlarmTempTop--;
else AlarmTempTop=0; break;    }
i2 = AlarmTempLow%(10,0,disdata[0]);
i3 = AlarmTempLow%10;   //獲得溫度值的個(gè)位
i4 = AlarmTempTop/100;   //獲得溫度值的百位
i5 = AlarmTempTop%100/10;  //獲得溫度值的十位
i6 = AlarmTempTop%10;   //獲得溫度值的個(gè)位
if((i1!=0))
if((i4!=0))
writeChar(4,1,i1+'0');
writeChar(12,1,i4+'0');
while(DnKey==0);   }  } }
void Alarm(void)
if((CurrentT>(AlarmTempTop*10))||(CurrentT<(AlarmTempLow*10))||(tflag==1))
  {    BEEP=0;   }
{    BEEP=1;   } }
void main(void)
unsigned char i=0;
P3=0xef;
P2=0xef;P1=0x00;BEEP=1;
LCD_Initial();
Read_Temperature();
writestring(1,0,"DS18B20 Alarmer");   //顯示“DS18B20 Alarmer”  delayms(1000);  //延時(shí)1S
writestring(0,0,"Current T=      ");   //顯示“Current T= ”
writestring(0,1," Low=10  Top=40 ");   //顯示“ Low=10  Top=40
NG=0; while(1)
Read_Temperature(); // //讀取溫度值
Display_Temperature();  //顯示溫度值
SetFun();
Alarm();
if((CurrentT<(AlarmTempTop*10))&&(CurrentT>(AlarmTempLow*10)))
{   Cool=0;Heat=0;  }
else if((CurrentT>(AlarmTempTop*10)))
{   Cool=1;Heat=0;  }
else if((CurrentT<(AlarmTempLow*10))||(tflag==1))
{   Cool=0;Heat=1;  } }
一直這兩個(gè)報(bào)錯(cuò)
.C(128): error C211: call not to a function
C(128): error C208: 'function': too many actual parameters
Target not created
ID:127343 發(fā)表于 2016-6-20 09:15 | 顯示全部樓層
chengxunhaochanga
ID:99130 發(fā)表于 2016-6-20 19:09 | 顯示全部樓層
你用的編譯軟件包含這個(gè)頭文件嗎?頭文件有沒有寫錯(cuò)?很多時(shí)候頭文件沒有正確調(diào)用錯(cuò)誤是一大堆的
ID:127278 發(fā)表于 2016-6-20 23:43 | 顯示全部樓層
越快樂越墮落 發(fā)表于 2016-6-20 19:09
軟件應(yīng)該問題不大      用keil編譯的  主要是小白  看不懂程序
ID:110895 發(fā)表于 2016-6-21 06:31 | 顯示全部樓層
報(bào)什么錯(cuò)貼出來。那么長(zhǎng)的程序,不知道什么錯(cuò)誤;沒有人有時(shí)間和耐心一句一句的分析程序的。
ID:127532 發(fā)表于 2016-6-21 11:16 | 顯示全部樓層
看下字符是否有錯(cuò)漏
ID:99130 發(fā)表于 2016-6-21 16:18 | 顯示全部樓層
944201454 發(fā)表于 2016-6-20 23:43
。。。。軟件不能有問題 就算你看不懂 但是軟件它看得懂啊 你錯(cuò)了一點(diǎn)都不行的 就比如那個(gè)頭文件 沒有包含它還真不行 就算下面的程序都是對(duì)的 也不行
ID:135253 發(fā)表于 2016-8-5 17:08 | 顯示全部樓層
wr_com()函數(shù)聲明
ID:136098 發(fā)表于 2016-8-5 23:28 | 顯示全部樓層
ID:111634 發(fā)表于 2016-8-6 09:51 | 顯示全部樓層
本帖最后由 zl2168 于 2016-8-6 09:52 編輯
實(shí)例97  一線式DS18B20測(cè)溫
Proteus仿真一下,確認(rèn)有效。
實(shí)例97 DS18B20測(cè)溫.rar (51.78 KB, 下載次數(shù): 6)
以上摘自張志良編著《單片機(jī)實(shí)驗(yàn)實(shí)訓(xùn)100例》 ISBN 978-7-5124-1603-1,北航社出版
書中電路和程序設(shè)計(jì)有詳細(xì)說明,程序語(yǔ)句條條有注解。
ID:114189 發(fā)表于 2016-8-6 15:20 | 顯示全部樓層
這個(gè)程序不知道誰(shuí)寫的 問題很多 你那個(gè)是沒有wr_com 這個(gè)函數(shù) 而且也沒有wr_dat這個(gè)函數(shù) 里面又有許多應(yīng)該是在中文下輸入的字符  建議你還是重新找一個(gè)程序吧 這個(gè)改起來很累 而且中文字符 不知道 還要重新寫一遍
