查看: 6141|回復(fù): 1
壓力傳感器的程序看不懂啊求解
ID:128451 發(fā)表于 2016-6-28 22:04 | 顯示全部樓層 |閱讀模式
                   壓力測(cè)試儀
系統(tǒng)描述;輸入  15--115kPA壓力信號(hào)
         輸出  00h--ffh數(shù)字信號(hào)(adc0832)
         在LCD上顯示實(shí)際的壓力值,如果超限則報(bào)警
線性區(qū)間標(biāo)度變換公式:    y=(115-15)/(243-13)*X+15kpa
作者:
單位:
日期:2008.3.7
#include<reg51.h>
#include<intrins.h>
#include <absacc.h>
#include <math.h>
#define uint   unsigned int
#define BUSY  0x80                               //常量定義
#define DATAPORT P0
//ADC0832的引腳
sbit ADCS =P3^5;  //ADC0832 chip seclect
sbit ADDI =P3^7;  //ADC0832 k in
sbit ADDO =P3^7;  //ADC0832 k out
sbit ADCLK =P3^6;  //ADC0832 clock signal
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_EN=P2^2;
uchar ad_data;                                    //采樣值存儲(chǔ)
sbit Alarm_led_red =P3^1;                         //超過壓力表量程最大值紅色led報(bào)警定義
sbit Alarm_led_green=P3^2;                        //低于壓力表量程最小值綠色led報(bào)警定義
                          //adc采樣值存儲(chǔ)單元
char press_data;                                  //標(biāo)度變換存儲(chǔ)單元
unsigned char ad_alarm;                           //報(bào)警值存儲(chǔ)單元
unsigned char press_ge=0;                        //顯示值百位
unsigned char press_shifen=0;                        //顯示值十位
unsigned char press_baifen=0;                         //顯示值個(gè)位
unsigned char press_qianfen=0;                        //顯示值十分位
uchar code str0[]={"Weight:  .   Kg "};
uchar code str1[]={"Make by GUO TAO "};
uchar code str2[]={"Price:          "};
uchar code str3[]={"Total:          "};
void delay(uint);
void lcd_wait(void);
void delay_LCM(uint);                        //LCD延時(shí)子程序
void initLCM( void);                          //LCD初始化子程序
void lcd_wait(void);                         //LCD檢測(cè)忙子程序
void WriteCommandLCM(uchar WCLCM,uchar BusyC);                              //寫指令到ICM子函數(shù)
void WriteDataLCM(uchar WDLCM);                                             //寫數(shù)據(jù)到LCM子函數(shù)
void DisplayOneChar(uchar X,uchar Y,uchar DData);                           //顯示指定坐標(biāo)的一個(gè)字符子函數(shù)
void DisplayListChar(uchar X,uchar Y,uchar code *DData);      //顯示指定坐標(biāo)的一串字符子函數(shù)
  void keyscan();
void display(void);                                                         //系統(tǒng)顯示子函數(shù)
uchar Adc0832(unsigned char channel);
void alarm(void);
void data_pro(void);
/**********main funcation************/
void main(void)
    delay(500);                      //系統(tǒng)延時(shí)500ms啟動(dòng)
// ad_data=0;                       //采樣值存儲(chǔ)單元初始化為0
    initLCM( );
    WriteCommandLCM(0x01,1);      //清顯示屏
    DisplayListChar(0,0,str0);
    DisplayListChar(0,1,str2);
    ad_data =Adc0832(0);    //采樣值存儲(chǔ)單元初始化為0
     alarm();
  data_pro();
  display();
/*********延時(shí)K*1ms,12.000mhz**********/
void delay(uint k)
    uint i,j;
    for(i=0;i<k;i++)
        for(j=0;j<60;j++)
/**********寫指令到ICM子函數(shù)************/
    if(BusyC)lcd_wait();
DATAPORT=WCLCM;
    LCM_RS=0;                   // 選中指令寄存器
    LCM_RW=0;                // 寫模式
    LCM_EN=1;
_nop_();
_nop_();
_nop_();
    LCM_EN=0;
/**********寫數(shù)據(jù)到LCM子函數(shù)************/
    lcd_wait( );             //檢測(cè)忙信號(hào)
DATAPORT=WDLCM;
    LCM_RS=1;                // 選中數(shù)據(jù)寄存器
    LCM_RW=0;             // 寫模式
    LCM_EN=1;
    _nop_();
_nop_();
_nop_();
    LCM_EN=0;
/***********lcm內(nèi)部等待函數(shù)*************/
void lcd_wait(void)
    DATAPORT=0xff;      //讀LCD前若單片機(jī)輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會(huì)有顯示邏輯黃色
LCM_EN=1;
    LCM_RS=0;
    LCM_RW=1;
    _nop_();
    _nop_();
_nop_();
    while(DATAPORT&BUSY)
{  LCM_EN=0;
    _nop_();
    _nop_();
    LCM_EN=1;
    _nop_();
    _nop_();
    LCM_EN=0;
/**********LCM初始化子函數(shù)***********/
void initLCM( )
DATAPORT=0;
delay(15);
WriteCommandLCM(0x38,0);    //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
    delay(5);
    delay(5);
    delay(5);
    WriteCommandLCM(0x38,1);    //8bit數(shù)據(jù)傳送,2行顯示,5*7字型,檢測(cè)忙信號(hào)
    WriteCommandLCM(0x08,1);    //關(guān)閉顯示,檢測(cè)忙信號(hào)
    WriteCommandLCM(0x01,1);    //清屏,檢測(cè)忙信號(hào)
    WriteCommandLCM(0x06,1);    //顯示光標(biāo)右移設(shè)置,檢測(cè)忙信號(hào)
    WriteCommandLCM(0x0c,1);    //顯示屏打開,光標(biāo)不顯示,不閃爍,檢測(cè)忙信號(hào)
/****顯示指定坐標(biāo)的一個(gè)字符子函數(shù)****/
   Y&=0x01;
    X&=0x0f;
    if(Y)X|=0x40;               //若y為1(顯示第二行),地址碼+0X40
    X|=0x80;                    //指令碼為地址碼+0X80
    WriteCommandLCM(X,1);
    WriteDataLCM(DData);
/*******顯示指定坐標(biāo)的一串字符子函數(shù)*****/
    uchar ListLength=0;
    Y&=0x01;
    X&=0x0f;
    while(X<16)
        DisplayOneChar(X,Y,DData[ListLength]);
        ListLength++;
        X++;
/*****************系統(tǒng)顯示子函數(shù)*****************/
void display(void)
DisplayOneChar(8,0,press_ge+0x30);
DisplayOneChar(10,0,press_shifen+0x30);
DisplayOneChar(11,0,press_baifen+0x30);
    DisplayOneChar(12,0,press_qianfen+0x30);
delay(1000);                               //穩(wěn)定顯示
讀ADC0832函數(shù)
//采集并返回
uchar Adc0832(unsigned char channel)     //AD轉(zhuǎn)換,返回結(jié)果
    uchar i=0;
    uchar j;
    uint dat=0;
    uchar ndat=0;
    if(channel==0)channel=2;
    if(channel==1)channel=3;
    ADDI=1;
    _nop_();
    _nop_();
    ADCS=0;//拉低CS端
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿1
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=channel&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿2
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=(channel>>1)&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿3
    ADDI=1;//控制命令結(jié)束
    _nop_();
    _nop_();
    dat=0;
    for(i=0;i<8;i++)
        dat|=ADDO;//收數(shù)據(jù)
        ADCLK=1;
        _nop_();
        _nop_();
        ADCLK=0;//形成一次時(shí)鐘脈沖
        _nop_();
        _nop_();
        dat<<=1;
        if(i==7)dat|=ADDO;
    for(i=0;i<8;i++)
        j=0;
        j=j|ADDO;//收數(shù)據(jù)
        ADCLK=1;
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        j=j<<7;
        ndat=ndat|j;
        if(i<7)ndat>>=1;
    ADCS=1;//拉低CS端
    ADCLK=0;//拉低CLK端
    ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
    dat<<=8;
    dat|=ndat;
    return(dat);            //return ad k
void data_pro(void)
      unsigned int temp;
      float  press;
   if(14<ad_data<243)                  //當(dāng)壓力值介于15kpa到115kpa之間時(shí),遵循線性變換
      int vary=ad_data;      //y=(115-15)/(243-13)*X+15kpa
   press=((10.0/23.0)*vary)+9.3;   //測(cè)試時(shí)補(bǔ)償值為9.3
   temp=(int)(press*10);                 //放大10倍,便于后面的計(jì)算
   press_ge=temp/1000;         //取壓力值百位
   press_shifen=(temp%1000)/100;       //取壓力值十位
   press_baifen=((temp%1000)%100)/10;      //取壓力值個(gè)位
   press_qianfen=((temp%1000)%100)%10;   //取壓力值十分位
/*****************報(bào)警子函數(shù)*******************/
void alarm(void)
  if(ad_data>=243)                           //如果當(dāng)前壓力值大于115kpa,
          {  Alarm_led_red=0; }                 //則啟動(dòng)red led報(bào)警
      {   Alarm_led_red=1; }          //關(guān)閉red led 報(bào)警
   if(ad_data<=14)       //如果當(dāng)前壓力值小于16kpa
      {  Alarm_led_green=0;  }               //則啟動(dòng)green led報(bào)警
      {   Alarm_led_green=1; }         //關(guān)閉green  led 報(bào)警
相關(guān)帖子
ID:128531 發(fā)表于 2016-6-29 11:48 | 顯示全部樓層
void delay(uint);
  void keyscan();
void alarm(void);
程序已經(jīng)標(biāo)注的很詳細(xì)了啊
