前不久參加學校挑戰(zhàn)杯,然后自己做了個手勢遙控小車,51單片機+mpu605+藍牙,大約半天就搞定了,現在把這個分享出來
2016-7-17 12:16 上傳
左邊那個是遙控器
2016-7-17 12:16 上傳
小車的程序這是遙控器
- #include <REG52.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- typedef unsigned char uchar;
- typedef unsigned short ushort;
- typedef unsigned int uint;
- // 定義51單片機端口
- #define DataPort P2 //LCD1602數據端口
- sbit SCL=P1^1;
- sbit SDA=P1^0;
- sbit LCM_RS=P0^7
- sbit LCM_RW=P0^6;
- sbit LCM_EN=P0^5;
- sbit led=P1^2;
- // 定義MPU6050內部地址
- #define SMPLRT_DIV 0x19 //陀螺儀采樣率,典型值:0x07(125Hz)
- #define CONFIG 0x1A //低通濾波頻率,典型值:0x06(5Hz)
- #define GYRO_CONFIG 0x1B //陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
- #define ACCEL_CONFIG 0x1C //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
- #define ACCEL_XOUT_H 0x3B
- #define ACCEL_XOUT_L 0x3C
- #define ACCEL_YOUT_H 0x3D
- #define ACCEL_YOUT_L 0x3E
- #define ACCEL_ZOUT_H 0x3F
- #define ACCEL_ZOUT_L 0x40
- #define TEMP_OUT_H 0x41
- #define TEMP_OUT_L 0x42
- #define GYRO_XOUT_H 0x43
- #define GYRO_XOUT_L 0x44
- #define GYRO_YOUT_H 0x45
- #define GYRO_YOUT_L 0x46
- #define GYRO_ZOUT_H 0x47
- #define GYRO_ZOUT_L 0x48
- #define PWR_MGMT_1 0x6B //電源管理,典型值:0x00(正常啟用)
- #define WHO_AM_I 0x75 //IIC地址寄存器(默認數值0x68,只讀)
- #define SlaveAddress 0xD0 //IIC寫入時的地址字節(jié)數據,+1為讀取
- //定義類型及變量
- uchar dis[4]; //顯示數字(-511至512)的字符數組
- int dis_data; //變量
- void delay(unsigned int k);//延時
- //LCD相關函數
- void InitLcd();//初始化lcd1602
- void lcd_printf(uchar *s,int temp_data);
- void WriteDataLCM(uchar dataW);//LCD數據
- void WriteCommandLCM(uchar CMD,uchar Attribc); //LCD指令
- void DisplayOneChar(uchar X,uchar Y,uchar DData);//顯示一個字符
- void DisplayListChar(uchar X,uchar Y,uchar *DData,L); //顯示字符串
- //MPU6050操作函數
- void InitMPU6050();//初始化MPU6050
- void Delay5us();
- void I2C_Start();
- void I2C_Stop();
- void I2C_SendACK(bit ack);
- bit I2C_RecvACK();
- void I2C_SendByte(uchar dat);
- uchar I2C_RecvByte();
- void I2C_ReadPage();
- void I2C_WritePage();
- void display_ACCEL_x();
- void display_ACCEL_y();
- void display_ACCEL_z();
- uchar Single_ReadI2C(uchar REG_Address);
- void Single_WriteI2C(uchar REG_Address,uchar REG_data)
- //整數轉字符串
- if(temp_data<0)
- temp_data=-temp_data;
- *s='-';
- else *s=' ';
- *++s =temp_data/100+0x30;
- temp_data=temp_data%100; //取余運算
- *++s =temp_data/10+0x30;
- temp_data=temp_data%10; //取余運算
- *++s =temp_data+0x30;
- //延時
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++);
- //LCD1602初始化
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- DisplayOneChar(0,0,'A');
- //LCD1602寫允許
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- //while(DataPort&0x80);
- LCM_EN=0;
- //LCD1602寫入命令
- if(Attribc)
- WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- //LCD1602寫入數據
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- //LCD1602寫入一個字符
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- //LCD1602顯示字符串
- uchar ListLength=0;
- Y&=0x1;
- X&=0xF;
- while(L--)
- DisplayOneChar(X,Y,DData[ListLength]);
- ListLength++;
- X++;
- //延時5微秒(STC90C52RC@12M)
- //不同的工作環(huán)境,需要調整此函數
- //當改用1T的MCU時,請調整此延時函數
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- //I2C起始信號
- void I2C_Start()
- SDA = 1; //拉高數據線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 0; //產生下降沿
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- //I2C停止信號
- void I2C_Stop()
- SDA = 0; //拉低數據線
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SDA = 1; //產生上升沿
- Delay5us(); //延時
- //I2C發(fā)送應答信號
- //入口參數:ack (0:ACK 1:NAK)
- SDA = ack; //寫應答信號
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- //I2C接收應答信號
- bit I2C_RecvACK()
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- CY = SDA; //讀應答信號
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return CY;
- //向I2C總線發(fā)送一個字節(jié)數據
- uchar i;
- for (i=0; i<8; i++) //8位計數器
- dat <<= 1; //移出數據的最高位
- SDA = CY; //送數據口
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- I2C_RecvACK();
- //從I2C總線接收一個字節(jié)數據
- uchar i;
- uchar dat = 0;
- SDA = 1; //使能內部上拉,準備讀取數據,
- dat <<= 1;
- SCL = 1; //拉高時鐘線
- Delay5us(); //延時
- dat |= SDA; //讀數據
- SCL = 0; //拉低時鐘線
- Delay5us(); //延時
- return dat;
- //向I2C設備寫入一個字節(jié)數據
- I2C_Start(); //起始信號
- I2C_SendByte(SlaveAddress); //發(fā)送設備地址+寫信號
- I2C_SendByte(REG_Address); //內部寄存器地址,
- I2C_SendByte(REG_data); //內部寄存器數據,
- I2C_Stop(); //發(fā)送停止信號
- //從I2C設備讀取一個字節(jié)數據
- uchar REG_data;
- I2C_SendByte(REG_Address); //發(fā)送存儲單元地址,從0開始
- I2C_SendByte(SlaveAddress+1); //發(fā)送設備地址+讀信號
- REG_data=I2C_RecvByte(); //讀出寄存器數據
- I2C_SendACK(1); //接收應答信號
- I2C_Stop(); //停止信號
- return REG_data;
- //初始化MPU6050
- Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠狀態(tài)
- Single_WriteI2C(SMPLRT_DIV, 0x07);
- Single_WriteI2C(CONFIG, 0x06);
- Single_WriteI2C(GYRO_CONFIG, 0x18);
- Single_WriteI2C(ACCEL_CONFIG, 0x01);
- //合成數據
- int GetData(uchar REG_Address)
- char H,L;
- int value;
- H=Single_ReadI2C(REG_Address);
- L=Single_ReadI2C(REG_Address+1);
- //return (H<<8)+L; //合成數據
- value=(H<<8)+L;
- value/=64;
- return value;
- //在1602上顯示10位數據
- void Display10BitData(int value,uchar x,uchar y) //num為XYZ的代表12
- //value/=64; //轉換為10位數據
- lcd_printf(dis, value); //轉換數據顯示
- DisplayListChar(x,y,dis,4); //啟始列,行,顯示數組,顯示長度
- void send(uchar pd)
- SBUF=pd
- while(!TI);
- TI=0;
- void send_init()
- TMOD=0X20;
- TH1=0XFD;
- TL1=0XFD;
- TR1=1;
- SM0=0;
- SM1=1;
- EA=1;
- ES=1;
- void main()
- int y;
- led=0;
- delay(500); //上電延時
- InitLcd(); //液晶初始化
- InitMPU6050();
- send_init();
- delay(150);
- while(1)
- y=0;
- Display10BitData(GetData(ACCEL_XOUT_H),2,0);
- if(GetData(ACCEL_YOUT_H)>200)
- send('f');
- led=1;
- else if(GetData(ACCEL_YOUT_H)<=(-200))
- send('b');
- led=1;
- Display10BitData(GetData(ACCEL_YOUT_H),7,0)
- if(GetData(ACCEL_XOUT_H)>200)
- send('r');
- y=1;
- led=1;
- else if(GetData(ACCEL_XOUT_H)<(-200))
- send('l');
- y=1;
- led=1;
- if(GetData(ACCEL_YOUT_H)<200&&GetData(ACCEL_YOUT_H)>(-200)&&y==0)
- send('s');
- led=1;
- Display10BitData(GetData(ACCEL_ZOUT_H),12,0);
- delay(500);
復制代碼
