查看: 2964|回復(fù): 1
進(jìn)行PAC定時(shí)器仿真時(shí),IO口沒(méi)有變化,程序哪里不對(duì)?程序是從網(wǎng)上下載的,學(xué)習(xí)PAC
ID:37147 發(fā)表于 2016-10-19 21:03 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "STC12C2052AD.H"
#include "intrins.h"
sbit    LED =   P2^1;       //測(cè)試LED
sbit    LED2=   P2^2;       //接LED觀察
unsigned int t0=1000;       //定義16位變量t,定時(shí)1ms
unsigned int t1=3000;       //定義16位變量t,定時(shí)3ms
unsigned int value0;
unsigned int value1;
void PCA_isr() interrupt 6
    if(CCF0)
        CCF0    =   0;         //清中斷,因PCA計(jì)數(shù)溢出中斷已禁止,所以這里不必再清CF
        CCAP0L  =   value0;     //更新比較值
        CCAP0H  =   value0>>8;
        value0  +=  t0;         //累加定時(shí)間隔值
        LED     =!  LED;        //LED取反
    if (CCF1)
        CCF1    =   0;         //清中斷,因PCA計(jì)數(shù)溢出中斷已禁止,所以這里不必再清CF
        CCAP1L  =   value1;     //更新比較值
        CCAP1H  =   value1>>8;
        value1  +=  t1;         //累加定時(shí)間隔值
        LED2    =!  LED2;       //LED2取反
    CCON=0;
    CL=0;
    CH=0;
        value0  =   t0;
        CCAP0L  =   t0;     //更新比較值
        CCAP0H  =   t0>>8;
        value1  =   t1;     //如改成value1=3500,進(jìn)中斷后還是按照value1=3000,則可讓波形2延時(shí)0.5ms,如下頁(yè)波形圖
        CCAP1L  =   t1;     //更新比較值
        CCAP1H  =   t1>>8;
    CMOD   =    0x00;   //模式:FSOC/12、關(guān)ECF允許PCA中斷
    EPCA_LVD  =   1;   //打開PCA總中斷
    CCAPM0 =    0x49;   //模塊0設(shè)置16位定時(shí)器,并產(chǎn)生模塊0的中斷信息CCF0
    CCAPM1  =   0x49;   //模塊1相同設(shè)置
    EA=1;
    CR=1;
    while(1);
ID:600982 發(fā)表于 2020-11-24 10:35 | 只看該作者
解決了嗎,是不是時(shí)鐘不一樣啊
