300黑幣
本帖最后由 412489601 于 2016-10-24 16:45 編輯
求助修改現(xiàn)有程序?qū)崿F(xiàn):【1】啟動(dòng)仿真5S后,數(shù)碼管個(gè)位和十位顯示AT89C51接收到74LS165發(fā)來的數(shù)據(jù)中高電平數(shù)量;
【2】當(dāng)按鍵啟動(dòng)鍵按下后,步進(jìn)電機(jī)啟動(dòng)(啟動(dòng)后計(jì)時(shí)),直至某一時(shí)間手動(dòng)改變74LS165接收端按鍵值,判斷之前的值和手動(dòng)改變的值前后之間的運(yùn)行時(shí)間,并且顯示在數(shù)碼管的百位和千位;
【3】當(dāng)按鍵反向鍵按下后,步進(jìn)電機(jī)運(yùn)行5S后程序初始化;
【備注】:程序及仿真已上傳跪求大神多多指點(diǎn)
基本程序已上傳
#include<reg51.h>
#include<intrins.h>
** Marcos define
#define MotorTabNum 5
//IO設(shè)置
sbit QH = P3^0; //輸出端
sbit CLK74 = P3^1; //時(shí)鐘輸入端(上升沿有效)
sbit SPL = P3^2; //移位控制/置入控制(低電平有效)
//步進(jìn)電機(jī)
sbit K1 = P3^5; // 啟動(dòng)
sbit K2 = P3^7; // 反向
//數(shù)碼管
sbit SMG1 = P2^0; //數(shù)碼管第一位定義
sbit SMG2 = P2^1; //數(shù)碼管第二位定義
sbit SMG3 = P2^2; //數(shù)碼管第三位定義
sbit SMG4 = P2^3; //數(shù)碼管第四位定義
//74LS165
sbit FX = P2^4; // 方向
sbit MotorEn = P2^5; // 使能
sbit CLK = P2^6; // 脈沖
//電機(jī)狀態(tài)
unsigned char T0_NUM;
unsigned char g_MotorSt = 0; // 啟停
unsigned char g_MotorDir = 0; // 正反
//電機(jī)轉(zhuǎn)速
unsigned char MotorTab[6] = {12, 10, 8, 6, 4, 2};
//共陰極數(shù)碼管段值
//int table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
signed char g_MotorNum = 0;
void delayms(xms);
void mDelay(unsigned int DelayTime); //延時(shí)函數(shù)
void T0_Init();
void KeyScan(void);
* Function Name : read_int165
* Description : 接收數(shù)據(jù)
* Input : None
* Output : None
* Return : None
uint read_int165(void)
uchar i = 0;
uint read_data = 0;
SPL = 0; //置數(shù),讀入并行輸入口數(shù)據(jù)
_nop_();
SPL = 1; //移位,并口輸入被封鎖,串行轉(zhuǎn)換開始
_nop_();
for(i=0;i<16;i++) //16位數(shù)據(jù)
read_data <<= 1;
if(QH)
read_data|=QH;
CLK74=0; //下降沿
_nop_();
CLK74=1; //上升沿
_nop_();
return read_data;
* Function Name : main
* Description : 主函數(shù)
* Input : None
* Output : None
* Return : None
//初始化值
uint temp = 0;
uchar tempH = 0;
uchar tempL = 0;
CLK74=0;
T0_Init(); // 定時(shí)器0 初始化
MotorEn = 0;// L297 使能(只有使能,才能正常工作,否則停止)
FX = 1; //正反轉(zhuǎn)
temp = read_int165();
// tempH = (uchar) (temp>>8);//獲取高8位,存放置tempH
// tempL = (uchar) temp; //獲取低8位,存放置tempL
// P0=tempH; //接收到的字節(jié)顯示在P0 端口,顯示的值與撥碼開關(guān)對(duì)應(yīng)
// P1=tempL; //接收到的字節(jié)顯示在P1 端口,顯示的值與撥碼開關(guān)對(duì)應(yīng)
KeyScan();//掃描按鍵
* Function Name : T0_Init
* Description : 定時(shí)器初始化
* Input : None
* Output : None
* Return : None
void T0_Init()
TMOD = 0x01;
TH0 = (65535-100)/256; // 1ms
TL0 = (65535-100)%256;
EA = 1;
ET0 = 1;
TR0 = 1;
* Function Name : T0_time
* Description : 定時(shí)器中斷
* Input : None
* Output : None
* Return : None
void T0_time() interrupt 1
TR0 = 0;
T0_NUM++;
if(T0_NUM >= MotorTab[g_MotorNum]) // 增加按鍵g_MotorNum++ 減小按鍵g_MotorNum--
T0_NUM = 0;
CLK=CLK^0x01; // 輸出脈沖
TR0 = 1;
* Function Name : KeyScan
* Description : 按鍵控制
* Input : None
* Output : None
* Return : None
void KeyScan(void)
if(K1==0 && K2==1) // 僅KEY1 按下
delayms(10); // 軟件延時(shí)消抖
if(K1==0 && K2==1)
MotorEn ^= 1;
TR0 = 1;
if(K1==1 && K2==0) // 僅KEY2 按下
delayms(5); // 軟件延時(shí)消抖
if(K1==1 && K2 == 0)
FX ^= 1; //改變方向
while(!K2);
* Function Name : Display
* Description : 數(shù)碼管顯示
* Input : None
* Output : None
* Return : None
/*void Display(void)
unsigned char B1,B2,B3,B4; //定義數(shù)碼管的每一位
B1=g_MotorNum/1000; //取g_MotorNum的千位
B2=g_MotorNum%1000/1000; //取g_MotorNum的百位
B3=g_MotorNum%100/10; //取g_MotorNum的十位
B4=g_MotorNum%10; //取g_MotorNum的個(gè)位
//顯示千位
P0=table[B1];
SMG1=0;
delayms(3);
SMG1=1;
//顯示百位
P0=table[B2];
SMG2=0;
delayms(3);
SMG2=1;
//顯示十位
P0=table[B3];
SMG3=0;
delayms(3);
SMG3=1;
//顯示個(gè)位
P0=table[B4];
SMG4=0;
delayms(3);
SMG4=1;
* Function Name : delayms
* Description : 延時(shí)函數(shù)
* Input : None
* Output : None
* Return : None
void delayms(xms)
unsigned int x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
** End Of File
