查看: 4518|回復(fù): 1
stc12c5a16s2采用官方提供的ADC采樣程序在采集一定范圍的電壓值后顯示不正常
ID:143203 發(fā)表于 2016-11-19 14:08 | 顯示全部樓層 |閱讀模式
先附程序:
#include <STC12C5a60s2.h>
#include <stdio.h>
#include <intrins.H>
#define  u8 char
#define  u16 int
#define AD_SPEED   0x60
u8 tab[16] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
sbit DAT=P1^1;
sbit CLK=P1^0;
u8 u82;// u81,
u16 u80;
u16 n=2,l=40,sec=0,min=0;
u16 temp;
u8 Time_10ms=0,Time_flag=0;
void delay(u8 t)
{                 u16 j;
                for(;t>0;t--)
                  for(j=200;j>0;j--)
void send164(u8 data1,u8 data2);
u8 get_AD_result(u8 channel)
    u8 AD_finished=0;            //存儲 A/D 轉(zhuǎn)換標(biāo)志
        u16 adc;
    ADC_RES = 0;
    ADC_RESL = 0;
    channel &= 0x07;                //0000,0111 清0高5位
    ADC_CONTR = AD_SPEED;
    _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
    ADC_CONTR |= channel;           //選擇 A/D 當(dāng)前通道
    _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
    ADC_CONTR |= 0x80;              //啟動(dòng) A/D 電源
    _nop_();
        _nop_();
        _nop_();
        _nop_();
//使輸入電壓達(dá)到穩(wěn)定
    ADC_CONTR |= 0x08;              //0000,1000 令 ADCS = 1, 啟動(dòng)A/D轉(zhuǎn)換,
        _nop_();
        _nop_();
        _nop_();
        _nop_();
    AD_finished = 0;
    while (AD_finished ==0 )        //等待A/D轉(zhuǎn)換結(jié)束
        AD_finished = (ADC_CONTR & 0x10); //0001,0000 測試A/D轉(zhuǎn)換結(jié)束否
    ADC_CONTR &= 0xE7;              //1111,0111 清 ADC_FLAG 位, 關(guān)閉A/D轉(zhuǎn)換,
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        adc=ADC_RES;
    return adc ;               //返回 A/D 高 8 位轉(zhuǎn)換結(jié)果ADC_RES
void init_time0()
        TMOD = 0x01; //16位定時(shí)器
    TL0  = 0x3C; //50ms定時(shí)
    TH0  = 0xB0;
    ET0 = 1; //允許T0中斷
    EA  = 1; //開放中斷
    TR0 = 1;
void Time0(void) interrupt 1
        TL0  = 0x3C;
    TH0  = 0xB0;
        send164(tab[u82%10],tab[u82/10]);
         delay(200);
void adc_init()
        P1ASF|=0x04;
        AUXR1 &= ~0x04;
        ADC_CONTR=0X80;
        delay(4);
{        u82=0;
        u80=0;
        init_time0();
        adc_init();
        delay(20);
        u80=get_AD_result(2);
         delay(10);
        u82=u80*49/256;
        delay(10);
        delay(0x1);
        //L H
void send164(u8 udata1,u8 udata2)
  u8 i;
        u8 j;
  for(i=0;i<8;i++)
    if    ((udata1&0x80)==0x80)
      DAT=1;
      DAT=0;
        CLK=0;
        udata1 = udata1<<1;
    CLK=1;
  for(j=0;j<8;j++)
    if    ((udata2&0x80)==0x80)
      DAT=1;
      DAT=0;
        CLK=0;
        udata2 = udata2<<1;
    CLK=1;
硬件部分是采用P1^2作為ADC采集入口,采用的接法與官方一致
說下問題吧:
在電壓值在0~23.4v的時(shí)候數(shù)碼管顯示正常,在將電壓調(diào)高后數(shù)碼管顯示全亮或非正常數(shù)字。想請問下這是因?yàn)槭裁此鶎?dǎo)致的?
數(shù)碼管是采用兩枚74xx驅(qū)動(dòng)的。
