查看: 6577|回復(fù): 8
多功能數(shù)碼管秒表(帶正、倒計(jì)時(shí),及時(shí)鐘模式)有代碼
基于STC89C52的數(shù)碼管顯示秒表,用矩陣鍵盤,有走秒,輸入時(shí)間正計(jì)時(shí)、倒計(jì)時(shí),到時(shí)提醒,及切換到時(shí)鐘模式的功能
鍵盤位置:7                 8                   9                    開始(正計(jì)時(shí))
                 4                 5                   6                    暫停
                 1                 2                   3                    倒計(jì)時(shí)
                 模式切換     0                   時(shí)間校正        清零
很容易理解,所以,這個(gè)就直接附代碼~~
下載地址:
多功能秒表.doc (6.43 KB, 下載次數(shù): 85)
///////////////////////////////////////////////////頭文件和一些定義和初始化在附件里有///////////////////////////////////////////////////
char codetable[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                   0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,
                   0x54};//數(shù)碼管段碼,最后一個(gè)為n
char code weixuan[]={0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//數(shù)碼管位碼
void Init()//清零
    run=0;
    remind=0;
    num=0;
    time=0;
    miao=0;
    fen=0;
    time0=0.00001;
    beep=1;
    key=16;
    EA=0;
    ET0=0;
    TR0=0;
void delay(unsigned char i)//延時(shí)
char j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void bee()//蜂鳴器
beep=0;
delay(500);
beep=1;
void keyscan()//按鍵檢測
    uchar temp;
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
        delay(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
            temp=P3;
            switch(temp)
                case 0xee:
                      key=7;
                     break;
                case0xde:
                      key=8;
                     break;
                case 0xbe:
                      key=9;
                     break;
                case0x7e:
                      key=12;
                     break;
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
   if(temp!=0xf0)
        delay(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
            temp=P3;
            switch(temp)
                case 0xed:
                      key=4;
                     break;
                case0xdd:
                      key=5;
                     break;
                case0xbd:
                      key=6;
                     break;
                case0x7d:
                      key=13;
                     break;
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
   if(temp!=0xf0)
        delay(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
            temp=P3;
            switch(temp)
                case 0xeb:
                      key=1;
                     break;
                case0xdb:
                      key=2;
                     break;
                case0xbb:
                      key=3;
                     break;
                case0x7b:
                      key=14;
                     break;
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
    P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
   if(temp!=0xf0)
        delay(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
            temp=P3;
            switch(temp)
                case 0xe7:
                      key=10;
                     break;
                case0xd7:
                      key=0;
                     break;
                case0xb7:
                      key=11;
                     break;
                case0x77:
                      key=15;
                     break;
            while(temp!=0xf0)
                temp=P3;
                temp=temp&0xf0;
void stor()
   if(key!=16)
       if(key>11)
            switch(key)
                case 12:run=1;break;
                case13:run=0;break;
                case14:run=2;break;
                case15:Init();
        if(key<10)
            if(time0==0.00001)
                time0=0;
            time0=time0*10+key;
            run=3;
    key=16;//防止循環(huán)進(jìn)入此函數(shù)
void T0_time()interrupt 1
   TH0=(65536-9216)/256;
    TL0=(65536-9216)%256;
//  num++;
//  if(num==2)
//      num=0;
        if(run==1)
          time+=0.01;
          time-=0.01;
void display(float t)
    intmiao_,time10,a[6],n1;
    time10=t*100;
    miao_=time10%100;
    miao=time10/100%60;
    fen=time10/100/60;
    a[0]=miao_%10;
   a[1]=miao_/10;
   a[2]=miao%10;
   a[3]=miao/10;
    a[4]=fen%10;
    a[5]=fen/10;
        for(n1=0;n1<6;n1++)
           if(n1!=2&&n1!=4)
                P0=table[a[n1]];
                dula=1;
                dula=0;
               P0=weixuan[n1];
               wela=1;
               wela=0;
               delay(5);
            {                                       //05 4744
                P0=table[a[n1]]+0x80;
               dula=1;
               dula=0;
               P0=weixuan[n1];
               wela=1;
               wela=0;
               delay(5);
//  if(remind==0)
//  for(a5=0;a5<3;a5++)//數(shù)碼管0-2位依次顯示
//       yu1=shang1%10;//取余
//        shang1=shang1/10;//取商
//           if(a5==1)//循環(huán)到個(gè)位時(shí)顯示小數(shù)點(diǎn)
//              P0=table[yu1]+0x80;
//              dula=1;
//               dula=0;
//               P0=weixuan[a5];
//               wela=1;
//               wela=0;
//                delay(5);
//          else
//              P0=table[yu1];
//               dula=1;
//               dula=0;
//               P0=weixuan[a5];
//               wela=1;
//               wela=0;
//               delay(5);
//      for(;a5<5;a5++)//數(shù)碼管3-4位依次顯示
//          yu2=shang2%10;//取余
//           shang2=shang2/10;//取商
//           if(a5==3)//循環(huán)到個(gè)位時(shí)顯示小數(shù)點(diǎn)
//              P0=table[yu2]+0x80;
//              dula=1;
//               dula=0;
//               P0=weixuan[a5];
//               wela=1;
//               wela=0;
//               delay(5);
//          else
//              P0=table[yu2];
//               dula=1;
//               dula=0;
//                P0=weixuan[a5];
//               wela=1;
//               wela=0;
//               delay(5);
//  else
//              P0=table[13];
//               dula=1;
//               dula=0;
//                P0=weixuan[0];
//               wela=1;
//               wela=0;
//               delay(5);
//              P0=table[16];
//               dula=1;
//               dula=0;
//               P0=weixuan[1];
//               wela=1;
//                wela=0;
//               delay(5);
//              P0=table[14];
//               dula=1;
//               dula=0;
//               P0=weixuan[2];
//               wela=1;
//               wela=0;
//               delay(5);
void check_display()
    if(run==0)
      TR0=0;
    if(run==1&&TR0==0||run==2&&TR0==0)
        TMOD=0x01;
        EA=1;
        ET0=1;
        TR0=1;
        if(run==2&&time0!=0.00001)
            time=time0;
    if(time==time0&&run==1&&remind==0)
//      bee();
        run=0;
        remind=1;
    if(time<=0&&run==2&&remind==0)
//      bee();
        run=0;
        remind=1;
    if(run!=3)
        display(time);
        display(time0);
    Init();
        keyscan();
        stor();
        check_display();
參與人數(shù) 3黑幣 +108 收起 理由
13202036330 + 3
51pp + 5 贊一個(gè)!
admin + 100 共享資料的黑幣獎(jiǎng)勵(lì)!
收藏收藏2 分享淘帖 頂 踩
相關(guān)帖子
ID:151927 發(fā)表于 2016-12-3 17:57 | 只看該作者
可以用作課程設(shè)計(jì)嗎
ID:151893 發(fā)表于 2016-12-3 19:21 | 只看該作者
shizhanglei 發(fā)表于 2016-12-3 17:57
可以用作課程設(shè)計(jì)嗎
怎么樣的課程設(shè)計(jì)?有什么要求
ID:151893 發(fā)表于 2016-12-3 19:55 | 只看該作者
可以用作課程設(shè)計(jì)嗎
你具體什么要求?
ID:152009 發(fā)表于 2016-12-3 23:47 | 只看該作者
ID:257970 發(fā)表于 2017-12-6 10:08 來自手機(jī) | 只看該作者
這個(gè)可以改成實(shí)現(xiàn)6位數(shù)碼管顯示時(shí)分秒倒計(jì)時(shí)的嗎?
ID:267933 發(fā)表于 2017-12-27 20:02 | 只看該作者
大神,沒有仿真圖。
ID:781537 發(fā)表于 2020-6-17 13:38 | 只看該作者
可以,這功能完美
ID:243874 發(fā)表于 2020-10-19 13:07 | 只看該作者
這個(gè)有電路嗎
