查看: 5769|回復(fù): 4
自己改的RC522門禁程序,管腳定義都在程序里
ID:127973 發(fā)表于 2016-12-10 21:09 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
如題。傳動(dòng)是用的直流減速電機(jī)帶動(dòng)門上的主軸。,
驅(qū)動(dòng)用的是L9110H芯片。
全部代碼下載:
RC522_C51.zip (63.73 KB, 下載次數(shù): 102)
主程序:
  1. #include "lpcreg.h"
  2. #include "main.h"
  3. #include "mfrc522.h"
  4. sbit LED=P0^6;
  5. sbit LED1=P0^7;
  6. sbit key=P1^2;
  7. sbit returnkey=P1^3;
  8. #define N 6//卡數(shù)量
  9. unsigned char *g_ucTbuf;
  10. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  11. unsigned char code data2[4]  = {0x12,0,0,0};
  12. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  13. unsigned char g_ucTempbuf[20];
  14. char code *Date[]={"F2B4F51C","126AE91C","9256F41C","1290F41C","961F8141","AA33263B"};//卡ID
  15. void open_door(void)
  16. {
  17.                         int j,l;
  18.                 for(j=0;j<50;j++)
  19.                    for(l=0;l<1000;l++);
  20.                  LED1=1;
  21.                  LED=0;
  22.                 for(j=0;j<500;j++)
  23.                    for(l=0;l<1000;l++);
  24.                  LED=0;
  25.                  LED1=0;
  26.               for(j=0;j<1000;j++)
  27.                  for(l=0;l<1000;l++);
  28.                  LED=1;
  29.                                  LED1=0;
  30.
  31.           for(j=0;j<200;j++)
  32.               for(l=0;l<1000;l++);
  33.                  LED=0;
  34.                  LED1=0;
  35. }
  36. void set()
  37. {
  38.         TMOD=0x20;
  39.         TH1=0x00;
  40.         TH1=0x00;
  41.         IT0=1;
  42.         EX0=1;
  43.         ET1=1;
  44.         EA=1;
  45.         TR1 =1;
  46. }
  47. void DelayMs(unsigned int _MS)
  48. {
  49.     TH0 = (unsigned char)(RCAP2_1ms>>8);
  50.     TL0 = (unsigned char)(RCAP2_1ms);
  51.     ET0     = 0;                                            // Disable timer2 interrupt
  52.     TR0     = 1;
  53.     while (_MS--)
  54.     {
  55.         while (!TF1);
  56.                 TF0 = 0;
  57.         TH0 = (unsigned char)(RCAP2_1ms>>8);
  58.         TL0 = (unsigned char)(RCAP2_1ms);
  59.         }
  60.     TR0 = 0;
  61. }
  62. void rfidpanduan(void)
  63. {
  64.         int f;
  65.       unsigned char status,Card[8];
  66.                 unsigned char code *ar={"0123456789ABCDEF"};
  67.                  status = PcdRequest(PICC_REQALL,g_ucTbuf);
  68.          if (status == MI_OK)
  69.          {
  70.                         status = PcdAnticoll(g_ucTempbuf);
  71.                  if (status == MI_OK)
  72.                  {
  73.
  74.                                  status = PcdSelect(g_ucTempbuf);
  75.                          if (status == MI_OK)
  76.                          {
  77.
  78.                   for(f=0;f<4;f++)
  79.                          {
  80.                                  Card[f*2]=ar[*(g_ucTempbuf+f)/16];
  81.                                 Card[f*2+1]=ar[*(g_ucTempbuf+f)%16];
  82.                          }
  83.                         for(f=0;f<N;f++)
  84.                         {
  85.                                 if(Card[0]==Date[f][0]&&Card[1]==Date[f][1]&&Card[2]==Date[f][2]&&Card[3]==Date[f][3]&&Card[4]==Date[f][4]&&Card[5]==Date[f][5]&&Card[6]==Date[f][6]&&Card[7]==Date[f][7])
  86.                                 {
  87.                                           open_door();
  88.                                         break;
  89.                                 }
  90.                         }
  91.                         }
  92.                 }
  93.                 }
  94. }
  95. void main( )
  96. {
  97.      InitializeSystem( );
  98.      PcdReset();
  99.      PcdAntennaOff();
  100.      PcdAntennaOn();
  101.          set();
  102.          M500PcdConfigISOType( 'A' );
  103.          LED=0;
  104.          LED1=0;
  105.      while (1)
  106.      {
  107.                          rfidpanduan();
  108.                          if(key==0)
  109.                          {
  110.                                  returnkey=1;
  111.                                    open_door();
  112.                          }
  113.                          else
  114.                          {
  115.                                   returnkey=0;
  116.                          }
  117.         }
  118. }
  119. /////////////////////////////////////////////////////////////////////
  120. //系統(tǒng)初始化
  121. /////////////////////////////////////////////////////////////////////
  122. void InitializeSystem()
  123. {
  124.     P0M1 = 0x0; P0M2 = 0x0;
  125.     P1M1 = 0x0;        P1M2 = 0x0;
  126.     P3M1 = 0x0; P3M2 = 0xFF;
  127.     P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
  128. }
  129. /////////////////////////////////////////////////////////////////////
  130. //用T2做延時(shí)子程序
  131. /////////////////////////////////////////////////////////////////////
收藏收藏4 分享淘帖 頂 踩
ID:127973 發(fā)表于 2017-1-10 19:43 | 只看該作者
char code *Date[]={"F2B4F51C","126AE91C","9256F41C","1290F41C","961F8141","AA33263B"};//卡ID這個(gè)數(shù)組大小可改,里面的就是卡ID,也要改成自己ID
ID:134870 發(fā)表于 2017-1-24 16:35 來(lái)自手機(jī) | 只看該作者
51hei有你更精彩!
ID:134242 發(fā)表于 2017-4-24 11:02 | 只看該作者
我司供應(yīng)完全PIN對(duì)PIN兼容RC522之非接芯片,可直接替換,不需做任何軟硬件更改,功耗更低,成本更低,歡迎索樣,QQ458231727
ID:607641 發(fā)表于 2020-1-13 09:28 | 只看該作者
正在學(xué)習(xí)rc522
