這是代碼
- *** 定時(shí)器+左右流水燈 ***
- #include <reg52.h>
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define LED P1
- uchar code water_led1[] = {0XFE,0XFD,0XFB,0XF7,
- 0XEF,0XDF,0XBF,0X7F};//正向流動(dòng)
- uchar code water_led2[] = {0X7F,0XBF,0XDF,0XEF,
- 0XF7,0XFB,0XFD,0XFE};//反向流動(dòng)
- void main ()
- uint count = 0;
- uint i = 0;
- TMOD = 0X01;//定時(shí)器設(shè)置為工作模式1
- TH0 = 0XB8;
- TL0 = 0X00;
- TR0 = 1;//啟動(dòng)T0
- while (1)
- if (TF0 == 1)//判斷TF0是否溢出
- TF0 = 0;//T0溢出后,清零
- TH0 = 0XB8;
- TL0 = 0X00;
- count ++;
- if (count == 10)//計(jì)數(shù)滿200ms
- count = 0;
- if ( i < 8 )
- LED = water_led1[i];
- if ( i >= 8 )
- LED = water_led2[i - 8 ];
- i ++;
- if ( i == 16 )
- i = 0;
復(fù)制代碼 |
