查看: 2630|回復(fù): 0
這是負(fù)載平衡監(jiān)控系統(tǒng)的程序 請(qǐng)大神幫我看看有沒(méi)有錯(cuò)誤的地方
ID:157790 發(fā)表于 2016-12-26 16:06 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<STC89XC2.h>
unsigned char code SEGtable[]=
0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0x00
sbit sw7 = P0 ^ 7;
sbit sw6 = P0 ^ 6;
sbit sw5 = P0 ^ 5;
sbit sw4 = P0 ^ 4;
sbit sw3 = P0 ^ 3;
sbit sw2 = P0 ^ 2;
sbit sw1 = P0 ^ 1;
sbit sw0 = P0 ^ 0;
sbit FMQ = P1 ^ 7;
bit alarmflg = 0;
unsigned RxByte = 0x00;
unsigned char counter = 0;
unsigned char Scounter,Lcounter;         //分別存放自己的水位狀態(tài)和遠(yuǎn)方的水位狀態(tài)          و
unsigned char FMcounter = 0x02;       //報(bào)警狀態(tài)參數(shù)
void DelayFM(unsigned int x)
     unsigned char t;
while(x--)
     for(t=0;t<120;t++);
//蜂鳴器驅(qū)動(dòng)函數(shù),參數(shù)為發(fā)聲聲調(diào)
void FM(unsigned char x)
     unsigned char i;
for(i=0;i<100;i++)
     FMQ =~FMQ;
     DelayFM(x);
FMQ = 0;
Void Delayms(unsigned int MS)      //延時(shí) ms 函數(shù)
unsigned int i,j;
for(i=0;i<MS;i++)
     for(j=0;j<1141;j++);
void InitUART(void)
     TMOD = 0x20;          //9600b/s
     SCON = 0x50;
     TH1 = 0xFD;
     TL1 = TH1;
     PCON = 0x00;
     EA = 1;
     ES = 1;
     TR1 = 1;
void Send(unsigned char x)
  SBUF = x;
  while(TI == 0);
  TI = 0;
void Serial(void)interrupt 4 using 1
unsigned char RxByte;
if(RI == 1)
     RxByte = SBUF;
     RI = 0;
    P2 = RxByte;
    switch(RxByte)
      case 0x00:Lcounter = 0;break;
      case 0xf9:Lcounter = 1;break;
      case 0xa4:Lcounter = 2;break;
      case 0xb0:Lcounter = 3;break;
      case 0x99:Lcounter = 4;break;
      case 0x92:Lcounter = 5;break;
      case 0x82:Lcounter = 6;break;
      case 0xF8:Lcounter = 7;break;
      case 0x80:Lcounter = 8;break;
      default:{};
    if(Scounter>Lcounter)
      if((Scounter - Lcounter) > 2)       //如果超過(guò)2%
        FMcounter = Scounter - Lcounter;
        alarmflg = 1;        //報(bào)警標(biāo)志位
      eles
        alarmflg = 0;
    eles
        alarmflg = 0;        //清除
  main(void)
     InitUART();
       Delayms(100);
       P0 = 0xFF;
       counter = 0;
       counter = counter + (unsigned char)sw7;
       counter = counter + (unsigned char)sw6;
       counter = counter + (unsigned char)sw5;
       counter = counter + (unsigned char)sw4;
       counter = counter + (unsigned char)sw3;
       counter = counter + (unsigned char)sw2;
       counter = counter + (unsigned char)sw1;
       counter = counter + (unsigned char)sw0;        //計(jì)算當(dāng)前的負(fù)載
       Scounter = counter;
       Send(SEGtable[counter]);
       if(alamflg == 1)
        FM(FMcounter);
相關(guān)帖子
