2017-4-8 23:11 上傳
30.6后面的東西不曉得咋出來的,下面T2后面本來是通過按鍵設(shè)定數(shù)值的,現(xiàn)在也不行了,是不是定時中斷哪里出問題了 ,求大神指點指點。(這是主程序,問題就這這里面就是不曉得在哪里)
- #include <reg52.h>
- #include<stdlib.h>
- #include<intrins.h>
- sbit RELAY = P2^4; //定義繼電器對應(yīng)單片機管腳
- bit flag1s = 0; //1s定時標志
- unsigned char T0RH = 0; //T0重載值的高字節(jié)
- unsigned char T0RL = 0; //T0重載值的低字節(jié)
- unsigned char T1RH = 0; //T0重載值的高字節(jié)
- unsigned char T1RL = 0; //T0重載值的低字節(jié)
- extern bit Start18B20();
- extern bit Get18B20Temp(int *temp);
- extern void InitLcd1602();
- extern void LcdShowStr(unsigned char *str);
- extern void LcdSetCursor(unsigned char addr);
- extern void LcdWriteDat(unsigned char dat);
- extern void LcdWriteCmd(unsigned char del);
- extern void keyscan();
- extern unsigned char key,flag1;
- unsigned char a[7];
- struct _pid{
- float SV;//用戶設(shè)定溫度
- float PV; //測量溫度
- float KP; //比例常數(shù)
- float T; //PID計算周期--采樣周期
- float TI; //積分常數(shù)
- float TD; //微分常數(shù)
- float EK; //本次偏差
- float EK_1;//上次偏差
- float SEK; //歷史偏差之和
- float IOUT;//積分輸出
- float POUT; //比例輸出
- float DOUT;//微分輸出
- float OUT0;
- float OUT;
- unsigned int C10ms;
- unsigned char pwmcycle;//pwm周期
- }PID;
- void pid_init()
- PID.KP=20;
- PID.T=1000;
- PID.TI=5000;
- PID.TD=1200;
- PID.pwmcycle=1000;//PWM的周期
- void ConfigTimer0(unsigned int ms);
- void ConfigTimer1(unsigned int ms1);
- void pid_calc(); //PID計算
- void pid_out(); //PID輸出結(jié)果到負載
- void main()
- unsigned char m;
- unsigned char i,e=0;
- unsigned char IntToString(unsigned char *str, int dat);
- unsigned char code table[]={'0','1','2','3','4','5','6','7','8','9', '.','-',':',' ','=','.'};
- bit res;
- int temp; //讀取到的當前溫度值
- int intT, decT; //溫度值的整數(shù)和小數(shù)部分
- unsigned char len;
- unsigned char str[5];
- unsigned char stt[16] = {"T1:"};
- unsigned char sty[16] = {"T2:"};
- EA = 1; //開總中斷
- ConfigTimer0(10); //T0定時10ms
- ConfigTimer1(1); //T1定時1ms
- Start18B20(); //啟動DS18B20
- InitLcd1602(); //初始化液晶
- pid_init() ;
- LcdWriteCmd(0x0C); //關(guān)閉光標閃爍
- /*實時溫度*/
- while(1)
- /*顯示實時溫度標識"T1:"*/
- LcdSetCursor(0x00);
- m = 0;
- while(stt[m] != '\0')
- LcdWriteDat(stt[m]);
- m++;
- /*顯示設(shè)定溫度標識"T2:"*/
- LcdSetCursor(0x40);
- m = 0;
- while(sty[m] != '\0')
- LcdWriteDat(sty[m]);
- m++;
- if (flag1s) //每秒更新一次溫度
- flag1s = 0;
- res = Get18B20Temp(&temp); //讀取當前溫度
- if (res) //讀取成功時,刷新當前溫度顯示
- intT = temp >> 4; //分離出溫度值整數(shù)部分
- decT = temp & 0xF; //分離出溫度值小數(shù)部分
- len = IntToString(str, intT); //整數(shù)部分轉(zhuǎn)換為字符串
- str[len++] = '.'; //添加小數(shù)點
- decT = (decT*10) / 16; //二進制的小數(shù)部分轉(zhuǎn)換為1位十進制位
- str[len++] = decT + '0'; //十進制小數(shù)位再轉(zhuǎn)換為ASCII字符
- LcdShowStr(str); //顯示到液晶屏上
- Start18B20();
- PID.PV=atof(str);
- /*設(shè)定溫度*/
- keyscan();
- if(flag1==1)
- if(key<11) //10以下是數(shù)字顯示部分
- LcdSetCursor(0x43+e++) ;
- LcdWriteDat(table[key]);
- a[i]=table[key];
- i++;
- PID.SV=atof(&a);
- else if(key==11)
- LcdWriteCmd(0x01) ; //刪除設(shè)定值
- e=0;
- for(i=0;i<7;i++)
- a[i]='0';
- flag1=0; //鍵盤檢測標志置0進行下一次檢測
- pid_calc();
- /* 整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長度 */
- signed char i = 0;
- unsigned char len = 0;
- unsigned char buf[6];
- if (dat < 0) //如果為負數(shù),首先取絕對值,并在指針上添加負號
- dat = -dat;
- *str++ = '-';
- len++;
- do
- { //先轉(zhuǎn)換為低位在前的十進制數(shù)組
- buf[i++] = dat % 10;
- dat /= 10;
- } while (dat > 0);
- len += i; //i最后的值就是有效字符的個數(shù)
- while (i-- > 0) //將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
- *str++ = buf[i] + '0';
- *str = '\0'; //添加字符串結(jié)束符
- return len; //返回字符串長度
- /* 配置并啟動T0,ms-T0定時時間 10ms*/
- unsigned long tmp; //臨時變量
- tmp = 11059200 / 12; //定時器計數(shù)頻率
- tmp = (tmp * ms) / 1000; //計算所需的計數(shù)值
- tmp = 65536 - tmp; //計算定時器重載值
- tmp = tmp + 12; //補償中斷響應(yīng)延時造成的誤差
- T0RH = (unsigned char)(tmp>>8); //定時器重載值拆分為高低字節(jié)
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = T0RH; //加載T0重載值
- TL0 = T0RL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動T0
- /* T0中斷服務(wù)函數(shù),10ms一次,完成1秒定時 */
- void InterruptTimer0() interrupt 1
- static unsigned char tmr1s = 0;
- TH0 = T0RH; //重新加載重載值
- TL0 = T0RL;
- tmr1s++;
- PID.C10ms++;
- if (tmr1s >= 100) //定時1s
- tmr1s = 0;
- flag1s = 1;
- /* 配置并啟動T1,ms-T1定時時間1ms */
- unsigned long tmp1; //臨時變量
- tmp1 = 11059200 / 12; //定時器計數(shù)頻率
- tmp1 = (tmp1 * ms1) / 1000; //計算所需的計數(shù)值
- tmp1 = 65536 - tmp1; //計算定時器重載值
- tmp1 = tmp1 + 12; //補償中斷響應(yīng)延時造成的誤差
- T1RH = (unsigned char)(tmp1>>8); //定時器重載值拆分為高低字節(jié)
- T1RL = (unsigned char)tmp1;
- TMOD &= 0xF0; //清零T1的控制位
- TMOD |= 0x01; //配置T1為模式1
- TH1 = T1RH; //加載T1重載值
- TL1 = T1RL;
- ET1 = 1; //使能T1中斷
- TR1 = 1; //啟動T1
- /* T1中 斷服務(wù)函數(shù),1ms一次 */
- void InterruptTimer1() interrupt 3
- TH1 = T1RH; //重新加載重載值
- TL1 = T1RL;
- // PID.C10ms++;
- pid_out(); //輸出PID運算結(jié)果到負載
- void pid_calc()
- float DELEK;
- float ti;
- float ki;
- float td;
- float kd;
- float out;
- if(PID.C10ms<(PID.T/10))
- {return;}
- PID.EK=PID.SV-PID.PV; //當前偏差
- PID.POUT=PID.KP*PID.EK;//比例輸出
- PID.SEK+=PID.EK; //歷史偏差
- DELEK=PID.EK-PID.EK_1;//最近兩次偏差之差
- ti=PID.T/PID.TI;
- ki=ti*PID.KP;
- PID.IOUT=ki*PID.SEK*PID.KP; //積分輸出
- td=PID.TD/PID.T;
- kd=PID.KP*td;
- PID.DOUT=kd*DELEK;
- PID.OUT=PID.POUT+PID.IOUT+PID.DOUT+PID.OUT0;//計算結(jié)果
- if(PID.OUT>PID.pwmcycle)
- {PID.OUT=PID.pwmcycle;}
- if(PID.OUT<0)
- {PID.OUT=0;}
- PID.OUT=out;
- PID.EK_1=PID.EK;//更新偏差
- PID.C10ms=0;
- void pid_out() //每一毫秒運算一次
- static unsigned char pw;
- pw++;
- if(pw>PID.pwmcycle) //pw=0-999
- {pw=0;}
- if(pw<PID.OUT)
- RELAY=0;//加熱
- else
- RELAY=1;//停止加熱
復(fù)制代碼 |
