查看: 3833|回復(fù): 1
自做藍(lán)牙小車(chē),代碼源程序
ID:188276 發(fā)表于 2017-4-10 21:59 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
簡(jiǎn)單實(shí)現(xiàn)前后左右
#include<AT89x51.H>
//HL-1小車(chē)驅(qū)動(dòng)接線(xiàn)定義
#define A_left_moto_go  {P2_0 = 1,P2_1 = 0;}
#define A_left_moto_back {P2_0 = 0,P2_1 = 1;}
#define A_left_moto_stop {P2_0 = 0,P2_1 = 0;}
#define A_right_moto_go {P2_2 = 1,P2_3 = 0;}
#define A_right_moto_back {P2_2 = 0,P2_3 = 1;}
#define A_right_moto_stop {P2_2 = 0,P2_3 = 0;}
#define B_left_moto_go {P1_0 = 1,P1_1 = 0;}
#define B_left_moto_back {P1_0 = 0,P1_1 = 1;}
#define B_left_moto_stop {P1_0 = 0,P1_1 = 0;}
#define B_right_moto_go {P1_2 = 1,P1_3 = 0;}
#define B_right_moto_back {P1_2 = 0,P1_3 = 1;}
#define B_right_moto_stop {P1_2 = 0,P1_3 = 0;}
#define uint    unsigned int                          //重定義無(wú)符號(hào)整數(shù)類(lèi)型
#define uchar   unsigned char                         //重定義無(wú)符號(hào)字符類(lèi)型
#define led P0_0
//延時(shí)函數(shù)
   void delay(unsigned int k)
     unsigned int x,y;
         for(x=0;x<k;x++)
           for(y=0;y<2000;y++);
void run()
        A_left_moto_go;
        A_right_moto_go;
        B_left_moto_go;
        B_right_moto_go;
void back_run()
        A_left_moto_back;
        A_right_moto_back;
        B_left_moto_back;
        B_right_moto_back;
void stop_run()
        A_left_moto_stop;
        A_right_moto_stop;
        B_left_moto_stop;
        B_right_moto_stop;
void left_run()
        A_left_moto_back;
        A_right_moto_go;
        B_left_moto_back;
        B_right_moto_go;
void right_run()
        A_left_moto_go;
        A_right_moto_back;
        B_left_moto_go;
        B_right_moto_back;
char uart_data; // 函數(shù)變量
char temp;
void main(void) //主函數(shù)
        SCON=0X50; //設(shè)置串口方式為1 方式1
        TMOD=0X20;//設(shè)置為定時(shí)器1,
        TH1= 0x0FD; //賦初值
        TL1= 0x0FD;
        ES=1; //開(kāi)串口中斷
        EA=1; //開(kāi)中中斷
        TR1=1; //啟動(dòng)定時(shí)器1
        led = 1; //p2.0置1,燈滅
        while(1);
void serial_IT(void) interrupt 4 //中斷程序
        if(RI==1) //R1置1.向cpu 申請(qǐng)中斷,循環(huán)
        RI=0; //軟件清零,取消申請(qǐng)
        uart_data = SBUF; //藍(lán)牙輸入數(shù)據(jù)賦值
        SBUF = uart_data; //返回終端
        temp = uart_data; //賦值
        if(temp == 0x00 ) led = ~led;
        switch(temp)
                case 'a'         :        run();                 break;// 前進(jìn)
                case 'b'        :         back_run();        break;//后退
                case 'c'        :        left_run();        break;//左轉(zhuǎn)
                case 'd'        :        right_run();break;//右轉(zhuǎn)
                case 'e'        :        stop_run();        break;//停止
        else T1 = 0; //中斷關(guān)閉
ID:268015 發(fā)表于 2018-1-15 19:45 | 只看該作者
有藍(lán)牙接收代碼嗎
