查看: 1819|回復(fù): 0
按鍵鍵盤加數(shù)碼管顯示
ID:204300 發(fā)表于 2017-5-24 15:01 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
uchar data dir_buf; //顯示緩沖區(qū)
uchar key;           //計(jì)算所得到的鍵值
uchar i2;  //鍵號(hào)
//code uchar dirtab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};//顯示代碼表
code uchar dirtab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
code uchar keytab[]={0xee,0xed,0xeb,0xe7,0xde,0xdd,0xdb,0xd7,0xbe,0xbd,0xbb,0xb7,0x7e,0x7d,0x7b,0x77};//顯示鍵值表
void delay(uint); //延時(shí)函數(shù)
void display();        //顯示函數(shù)
void keyscan();          //鍵盤掃描函數(shù)
//i2=16;
//dir_buf=16;
  keyscan();
  dir_buf=i2;
  display();
void delay(uint x)
uint t1,t2;
for(t1=0;t1<x;t1++)
   for(t2=0;t2<120;t2++);
void display()
   if(i2>9)
   P0=dirtab[1];
   P3=dirtab[dir_buf-10];
   P0=dirtab[0];
   P3=dirtab[dir_buf];
void keyscan()
uchar code_l,code_h,i1;
P1=0xf0;
code_l=P1;
code_l=code_l&0xf0;
if(code_l!=0xf0)
  delay(6);
   code_l=P1;
   code_l=code_l&0xf0;
   if(code_l!=0xf0)
    code_h=0xfe;
        for(i1=0;i1<4;i1++)
         P1=code_h;
         code_l=P1;
     code_l=code_l&0xf0;
     if(code_l==0xf0)
          code_h=(code_h<<1)|0x01;
         else break;
        P1=0xff;
        while(P1!=0xff);
        code_h=code_h&0x0f;
        key=code_h+code_l;
        for(i2=0;i2<16;i2++)
         if(key==keytab[i2])
           break;
相關(guān)帖子
