#include <reg52.h> //
#include <LCD1602.H>
#include "DS1302.h"
#include<intrins.h>
sfr ADC_CONTR = 0xBC; //ADC control register
sfr ADC_RES = 0xBD; //ADC hight 8-bit result register
sfr ADC_RESL = 0xBE; //ADC low 2-bit result register
sfr P1ASF = 0x9D; //P1 secondary function control register
sbit xiay = P3^0; //定義
sbit key1 = P3^2; //定義 選擇鍵
sbit key2 = P3^3; //定義 加 按鍵端口
sbit key3 = P3^4; //定義 減 按鍵端口
sbit key4 = P3^5; //定義
sbit key5 = P3^6; //定義
sbit pwm0 = P2^0; //縱向舵機(jī)驅(qū)動(dòng)端口
sbit pwm1 = P2^1 ; //橫向舵機(jī)驅(qū)動(dòng)端口
#define uchar unsigned char //宏定義 unsigned char字符為uchar
#define uint unsigned int //宏定義 unsigned int
#define ulint unsigned long int //宏定義
/*定義相關(guān)特殊功能寄存器*/
#define ADC_POWER 0x80 //ADC power control bit
#define ADC_FLAG 0x10 //ADC complete flag
#define ADC_START 0x08 //ADC start control bit
#define ADC_SPEEDLL 0x00 //540 clocks
#define ADC_SPEEDL 0x20 //360 clocks
#define ADC_SPEEDH 0x40 //180 clocks
#define ADC_SPEEDHH 0x60 //90 clocks
uint guangmin_0=0,guangmin_1=0,guangmin_2=0,guangmin_3=0; //光敏值變量
uchar xdata Temp[16]="13-04-30 : G ";
uchar xdata Test[16]="19:14:00 : K ";
uchar xdata Temp1[16]="X: Y: ";
uchar xdata Test1[16]="guangzhao: ";
uchar xdata Temp2[16]=" G0 G1 ";
uchar xdata Test2[16]=" G2 G3 ";
uint nian,yue,ri,shi,fen,miao;
int _shi=18,_fen=30; //停止時(shí)間變量
int shi_=6,fen_=30; //啟動(dòng)時(shí)間變量
uchar set=0,set1=0,set2=0; //模式控制變量
uchar xian=0; //顯示模式標(biāo)志變量
uint GZ; //光照變量
uchar X,Y; //角度變量
uint js=0; //標(biāo)志位變量
uint b=107,d=107; //角度控制變量
void Delay1us() //@12.000MHz
_nop_();
_nop_();
_nop_();
_nop_();
void InitADC()
P1ASF = 0xf0; //Set all P1 as analog input port 0xff=1111 1111B 即P1全部用作AD,使用時(shí)根據(jù)實(shí)際情況賦值
ADC_RES = 0; //清零轉(zhuǎn)換結(jié)果寄存器高8位
ADC_RESL= 0; //清零轉(zhuǎn)換結(jié)果寄存器低2位
ADC_CONTR = 0x00;
Delay1us(); //等待ADC_CONTR值寫入
_nop_();
_nop_();
_nop_();
_nop_();
unsigned int GetADC(unsigned char ch,unsigned char speed)
unsigned int res;
ADC_CONTR =ADC_CONTR | ADC_POWER | speed | ADC_START | ch;
Delay1us();//確保ADC_CONTR的值寫入nop; nop; nop; nop;
while(!(ADC_CONTR & ADC_FLAG)); //如果AD轉(zhuǎn)換未結(jié)束FLAG位為0,程序在此等待,如果為1,跳出循環(huán)
res=ADC_RES*4+ADC_RESL; //讀AD轉(zhuǎn)換結(jié)果
ADC_RES=0;
ADC_RESL=0;
ADC_CONTR=0; //寄存器復(fù)位
return res;
void readtime()
nian= BCD_Decimal(read_1302(0x8d));
yue = BCD_Decimal(read_1302(0x89));
ri = BCD_Decimal(read_1302(0x87));
shi = BCD_Decimal(read_1302(0x85));
fen = BCD_Decimal(read_1302(0x83));
miao= BCD_Decimal(read_1302(0x81));
uchar key_bcd(uchar key_decimal) //轉(zhuǎn)成ds1302所需的BCD碼
uchar temp;
temp=(((key_decimal/10)&0x0f)<<4)|(key_decimal%10);
return temp;
void keyscan()
//-----------------------------模式鍵key1----------------------------
if(key1==0&&xian==0)
//delay(5);
if(key1==0)
//delay(10);
while(!key1);
set++;
set1=0;
set2=0;
if(set>6)set=0;
//-----------------------------模式鍵key4----------------------------
if(key4==0&&xian==0)
//delay(5);
if(key4==0)
//delay(10);
while(!key4);
set=0;
set1++;
set2=0;
if(set1>2)set1=0;
//-----------------------------模式鍵key5----------------------------
if(key5==0&&xian==0)
//delay(5);
if(key5==0)
//delay(10);
while(!key5);
set=0;
set1=0;
set2++;
if(set2>2)set2=0;
//-----------------------------key2----------------------------
if(key2==0)
//delay(2);
if(key2==0)
//delay(5);
while(!key2);
switch(set)
case 1: nian++;
if(nian>99)nian=0;
write_1302(0x8e,0x00);
write_1302(0x8c,key_bcd(nian)| 0x80);
write_1302(0x8e,0x80);
break;
case 2: yue++;
if(yue>12)yue=1;
write_1302(0x88,key_bcd(yue));
break;
case 3: ri++;
if(ri>31)ri=1;
write_1302(0x86,key_bcd(ri));
break;
case 4: shi++;
if(shi>23)shi=0;
write_1302(0x84,key_bcd(shi));
break;
case 5: fen++;
if(fen>59)fen=0;
write_1302(0x82,key_bcd(fen));
break;
case 6: miao++;
if(miao>59)miao=0;
write_1302(0x80,key_bcd(miao)&0x7f);
break;
switch(set1)
case 1: _shi++;
if(_shi>23)_shi=23;
break;
case 2: _fen++;
if(_fen>59)_fen=0;
break;
switch(set2)
case 1: shi_++;
if(shi_>_shi)shi_=_shi;
break;
case 2: fen_++;
if(fen_>59)fen_=0;
break;
//-----------------------------key3----------------------------
if(key3==0)
//delay(2);
if(key3==0)
//delay(5);
while(!key3);
if(set==0&&set1==0&&set2==0)
xian++;
if(xian>2)xian=0;
b++;d++;
switch(set)
case 1: nian--;
if(nian>99)nian=99;
break;
case 2: yue--;
if(yue>12)yue=12;
break;
case 3: ri--;
if(ri>31)ri=31;
break;
case 4: shi--;
if(shi>23)shi=23;
break;
case 5: fen--;
if(fen>59)fen=59;
break;
case 6: miao--;
if(miao>59)miao=59;
break;
switch(set1)
case 1: _shi--;
if(_shi<shi_)_shi=shi_;
break;
case 2: _fen--;
if(_fen<0)_fen=59;
break;
switch(set2)
case 1: shi_--;
if(shi_<0)shi_=0;
break;
case 2: fen_--;
if(fen_<0)fen_=59;
break;
uchar ttt;
void display()
if(xian==0) //顯示模式0
ttt++;
if(ttt>5)ttt=0;
if(set==1)
if(ttt>2)
Temp[0]=nian/10+'0';
Temp[1]=nian%10+'0';
Temp[0]=' ';
Temp[1]=' ';
if(set==2)
if(ttt>2)
Temp[3]=yue/10+'0';
Temp[4]=yue%10+'0';
Temp[3]=' ';
Temp[4]=' ';
Temp[3]=yue/10+'0';
Temp[4]=yue%10+'0';
if(set==3)
if(ttt>2)
Temp[6]=ri/10+'0';
Temp[7]=ri%10+'0';
Temp[6]=' ';
Temp[7]=' ';
Temp[6]=ri/10+'0';
Temp[7]=ri%10+'0';
if(set1==1)
if(ttt>2)
Temp[9]=_shi/10+'0';
Temp[10]=_shi%10+'0';
Temp[9]=' ';
Temp[10]=' ';
if(set1==2)
if(ttt>2)
Temp[12]=_fen/10+'0';
Temp[13]=_fen%10+'0';
Temp[12]=' ';
Temp[13]=' ';
ShowString(0,Temp);
if(set==4)
if(ttt>2)
Test[0]=shi/10+'0';
Test[1]=shi%10+'0';
Test[0]=' ';
Test[1]=' ';
Test[0]=shi/10+'0';
Test[1]=shi%10+'0';
if(set==5)
if(ttt>2)
Test[3]=fen/10+'0';
Test[4]=fen%10+'0';
Test[3]=' ';
Test[4]=' ';
Test[3]=fen/10+'0';
Test[4]=fen%10+'0';
if(set==6)
if(ttt>2)
Test[6]=miao/10+'0';
Test[7]=miao%10+'0';
Test[6]=' ';
Test[7]=' ';
if(set2==1)
if(ttt>2)
Test[9]=shi_/10+'0';
Test[10]=shi_%10+'0';
Test[9]=' ';
Test[10]=' ';
if(set2==2)
if(ttt>2)
Test[12]=fen_/10+'0';
Test[13]=fen_%10+'0';
Test[12]=' ';
Test[13]=' ';
ShowString(1,Test);
if(xian==1) //顯示模式1
Y=b;
X=d;
GZ=(guangmin_0+guangmin_1+guangmin_2+guangmin_3)/4;
if(X<=107)
X=107-X;
Temp1[3]='-'; //角度數(shù)值轉(zhuǎn)換顯示
Temp1[4]=X/100%10+'0';
Temp1[5]=X/10%10+'0';
Temp1[6]=X%10+'0';
if(X>=107)
X=X-107;
Temp1[3]='+'; //角度數(shù)值轉(zhuǎn)換顯示
Temp1[6]=X%10+'0';
if(Y<=107)
Y=107-Y;
Temp1[11]='-'; //角度數(shù)值轉(zhuǎn)換顯示
Temp1[12]=Y/100%10+'0';
Temp1[13]=Y/10%10+'0';
Temp1[14]=Y%10+'0';
if(Y>=107)
Y=Y-107;
Temp1[11]='+'; //角度數(shù)值轉(zhuǎn)換顯示
Temp1[14]=Y%10+'0';
Test1[10]=GZ/1000+'0'; //光敏數(shù)值轉(zhuǎn)換顯示
Test1[11]=GZ/100%10+'0';
Test1[12]=GZ/10%10+'0';
Test1[13]=GZ%10+'0';
ShowString(0,Temp1);
ShowString(1,Test1);
if(xian==2) //顯示模式2
Temp2[4]=guangmin_0/1000+'0'; //光敏數(shù)值轉(zhuǎn)換顯示
Temp2[5]=guangmin_0/100%10+'0';
Temp2[6]=guangmin_0/10%10+'0';
Temp2[7]=guangmin_0%10+'0';
Temp2[11]=guangmin_1/1000+'0'; //光敏數(shù)值轉(zhuǎn)換顯示
Temp2[12]=guangmin_1/100%10+'0';
Temp2[13]=guangmin_1/10%10+'0';
Temp2[14]=guangmin_1%10+'0';
Test2[4]=guangmin_2/1000+'0'; //光敏數(shù)值轉(zhuǎn)換顯示
Test2[5]=guangmin_2/100%10+'0';
Test2[6]=guangmin_2/10%10+'0';
Test2[7]=guangmin_2%10+'0';
Test2[11]=guangmin_3/1000+'0'; //光敏數(shù)值轉(zhuǎn)換顯示
Test2[12]=guangmin_3/100%10+'0';
Test2[13]=guangmin_3/10%10+'0';
Test2[14]=guangmin_3%10+'0';
ShowString(0,Temp2);
ShowString(1,Test2);
void timer0_irpt()interrupt 1 //中斷1服務(wù)程序
TH0 = (65536-10)/256; //重裝計(jì)數(shù)值
TL0 = (65536-10)%256; //重裝計(jì)數(shù)值
js++; //a自加1
if(js==2000) //如果a等于2000
pwm0=1;
pwm1=1; //縱向舵機(jī)驅(qū)動(dòng)端口取反
js=0; //把a(bǔ)置0
else //否則判斷a是否等于b
if(js==b){pwm0=0;} //如果等于就把縱向舵機(jī)驅(qū)動(dòng)端口取反
if(js==d){pwm1=0;}
void chushihua() //內(nèi)部中斷初始化函數(shù)
TMOD = 0x01; //將計(jì)數(shù)器設(shè)置為工作方式1
TH0 = (65536-10)/256; //給計(jì)數(shù)器高八位賦值
TL0 = (65536-10)%256; //給計(jì)數(shù)器低八位賦值
EA = 1; //開總中斷
ET0 = 1; //開中斷1
TR0 = 1;
void pianzhuankongzhi(void)
if(((guangmin_0+guangmin_1)-10)<(guangmin_2+guangmin_3))
b--;
if(b<45){b=45;}
if(((guangmin_2+guangmin_3)-10)<(guangmin_0+guangmin_1))
b++;
if(b>140){b=140;}
Delay1us();
if(((guangmin_3+guangmin_0)-10)<(guangmin_1+guangmin_2))
d--;
if(d<45){d=45;}
if(((guangmin_1+guangmin_2)-10)<(guangmin_3+guangmin_0))
d++;
if(d>170){d=170;}
void main(void)
InitADC(); //ADC初始化
InitLcd_LCD1602(); //液晶初始化
ds1302_init(); //DS1302初始化
chushihua(); //PWM中斷初始化
readtime(); //讀取時(shí)間
display(); //顯示控制
keyscan(); //按鍵控制
if(((shi*60+fen)>=(shi_*60+fen_))&&((shi*60+fen)<=(_shi*60+_fen-1))) //判斷時(shí)間段開跟蹤
guangmin_0=GetADC(0,ADC_SPEEDLL);
guangmin_1=GetADC(1,ADC_SPEEDLL);
guangmin_2=GetADC(2,ADC_SPEEDLL);
guangmin_3=GetADC(3,ADC_SPEEDLL);
pianzhuankongzhi(); //舵機(jī)控制
EA=1;
EA=0;
