查看: 4642|回復: 6
pwm控制16位流水燈(用定時器)
ID:209672 發(fā)表于 2017-6-14 22:23 | 顯示全部樓層 |閱讀模式
//led燈為共陽接法  P0 P1 口 單片機型號STC89C52
#include<reg52.h>
unsigned int a=0;
unsigned char num;
unsigned char pp0=0;//LED占空比值 0-16 0最亮
unsigned char pp1=1;
unsigned char pp2=2;
unsigned char pp3=3;
unsigned char pp4=4;
unsigned char pp5=5;
unsigned char pp6=6;
unsigned char pp7=7;
unsigned char pp8=8;
unsigned char pp9=9;
unsigned char pp10=10;
unsigned char pp11=11;
unsigned char pp12=12;
unsigned char pp13=13;
unsigned char pp14=14;
unsigned char pp15=15;
sbit LED0=P2^0;
sbit LED1=P2^1;
sbit LED2=P2^2;
sbit LED3=P2^3;
sbit LED4=P2^4;
sbit LED5=P2^5;
sbit LED6=P2^6;
sbit LED7=P2^7;
sbit LED8=P0^0;
sbit LED9=P0^1;
sbit LED10=P0^2;
sbit LED11=P0^3;
sbit LED12=P0^4;
sbit LED13=P0^5;
sbit LED14=P0^6;
sbit LED15=P0^7;
unsigned char pwm_t;//
//定時器1中斷
void timer1() interrupt 3
a++;
if(a>8192)
  a=0;
pwm_t++;
if(pwm_t > 15)
  pwm_t = 0;
  P2 = 0xff;
  P0 = 0xff;
if(a/512==0){//狀態(tài)一
  pp0=0;//LED占空比值 此時只有0亮, 0最亮
  pp1=16;
  pp2=16;
  pp3=16;
  pp4=16;
  pp5=16;
  pp6=16;
  pp7=16;
  pp0=16;
  pp1=16;
  pp2=16;
  pp3=16;
  pp4=16;
  pp5=16;
  pp6=16;
  pp7=16;
}else if(a/512==1){狀態(tài)二
  pp0=1;
  pp1=0;
  pp2=16;
  pp3=16;
  pp4=16;
  pp5=16;
  pp6=16;
  pp7=16;
  pp8=16;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
}else if(a/512==2){
  pp0=2;
  pp1=1;
  pp2=0;
  pp3=16;
  pp4=16;
  pp5=16;
  pp6=16;
  pp7=16;
  pp8=16;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
}else if(a/512==3){
  pp0=3;
  pp1=2;
  pp2=1;
  pp3=0;
  pp4=16;
  pp5=16;
  pp6=16;
  pp7=16;
  pp8=16;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
}else if(a/512==4){
  pp0=4;
  pp1=3;
  pp2=2;
  pp3=1;
  pp4=0;
  pp5=16;
  pp6=16;
  pp7=16;
  pp8=16;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
}else if(a/512==5){
  pp0=5;
  pp1=4;
  pp2=3;
  pp3=2;
  pp4=1;
  pp5=0;
  pp6=16;
  pp7=16;
  pp8=16;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
}else if(a/512==6){
  pp0=6;
  pp1=5;
  pp2=4;
  pp3=3;
  pp4=2;
  pp5=1;
  pp6=0;
  pp7=16;
  pp8=16;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
else if(a/512==7){
  pp0=7;
  pp1=6;
  pp2=5;
  pp3=4;
  pp4=3;
  pp5=2;
  pp6=1;
  pp7=0;
  pp8=16;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
else if(a/512==8){
  pp0=8;
  pp1=7;
  pp2=6;
  pp3=5;
  pp4=4;
  pp5=3;
  pp6=2;
  pp7=1;
  pp8=0;
  pp9=16;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
else if(a/512==9){
  pp0=9;
  pp1=8;
  pp2=7;
  pp3=6;
  pp4=5;
  pp5=4;
  pp6=3;
  pp7=2;
  pp8=1;
  pp9=0;
  pp10=16;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
else if(a/512==10){
  pp0=10;
  pp1=9;
  pp2=8;
  pp3=7;
  pp4=6;
  pp5=5;
  pp6=4;
  pp7=3;
  pp8=2;
  pp9=1;
  pp10=0;
  pp11=16;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
else if(a/512==11){
  pp0=11;
  pp1=10;
  pp2=9;
  pp3=8;
  pp4=7;
  pp5=6;
  pp6=5;
  pp7=4;
  pp8=3;
  pp9=2;
  pp10=1;
  pp11=0;
  pp12=16;
  pp13=16;
  pp14=16;
  pp15=16;
else if(a/512==12){
  pp0=12;
  pp1=11;
  pp2=10;
  pp3=9;
  pp4=8;
  pp5=7;
  pp6=6;
  pp7=5;
  pp8=4;
  pp9=3;
  pp10=2;
  pp11=1;
  pp12=0;
  pp13=16;
  pp14=16;
  pp15=16;
else if(a/512==13){
  pp0=13;
  pp1=12;
  pp2=11;
  pp3=10;
  pp4=9;
  pp5=8;
  pp6=7;
  pp7=6;
  pp8=5;
  pp9=4;
  pp10=3;
  pp11=2;
  pp12=1;
  pp13=0;
  pp14=16;
  pp15=16;
else if(a/512==14){
  pp0=14;
  pp1=13;
  pp2=12;
  pp3=11;
  pp4=10;
  pp5=9;
  pp6=8;
  pp7=7;
  pp8=6;
  pp9=5;
  pp10=4;
  pp11=3;
  pp12=2;
  pp13=1;
  pp14=0;
  pp15=16;
else if(a/512==15){
  pp0=15;
  pp1=14;
  pp2=13;
  pp3=12;
  pp4=11;
  pp5=10;
  pp6=9;
  pp7=8;
  pp8=7;
  pp9=6;
  pp10=5;
  pp11=4;
  pp12=3;
  pp13=2;
  pp14=1;
  pp15=0;
if(pp0 == pwm_t)
  LED0 = 0;
if(pp1 == pwm_t)
  LED1 =0 ;
if(pp2== pwm_t)
  LED2 = 0;
if(pp3 == pwm_t)
  LED3 = 0;
if(pp4 == pwm_t)
  LED4 = 0;
if(pp5 == pwm_t)
  LED5 = 0;
if(pp6 == pwm_t)
  LED6 = 0;
if(pp7 == pwm_t)
  LED7 = 0;
  if(pp8 == pwm_t)
  LED8 = 0;
  if(pp9 == pwm_t)
  LED9 = 0;
  if(pp10 == pwm_t)
  LED10 = 0;
  if(pp11 == pwm_t)
  LED11 = 0;
  if(pp12 == pwm_t)
  LED12 = 0;
  if(pp13 == pwm_t)
  LED13 = 0;
  if(pp14 == pwm_t)
  LED14 = 0;
  if(pp15 == pwm_t)
  LED15 = 0;
TMOD |= 0x20;//8位自動重裝模塊
TH1 = 240;
TL1 = 240;//11.0592M晶振下占空比最大比值是20,輸出2880HZ
TR1 = 1;//啟動定時器1
ET1 = 1;//允許定時器1中斷
EA = 1;//總中斷允許
交流QQ:1461264417
參與人數(shù) 4黑幣 +65 收起 理由
5314039 + 5 很給力!
13976778401 + 5 贊一個!
348652560 + 5 很給力!
admin + 50 共享資料的黑幣獎勵!
相關帖子
ID:112693 發(fā)表于 2017-6-15 10:23 | 顯示全部樓層
厲害了樓主。!值得學習,定時器是我的弱項!
ID:209672 發(fā)表于 2017-6-15 13:33 來自手機 | 顯示全部樓層
dragon19790000 發(fā)表于 2017-6-15 10:23
厲害了樓主!。≈档脤W習,定時器是我的弱項!
主要是pwm控制拖尾燈。哈哈哈 我的課設。
ID:211258 發(fā)表于 2017-6-15 17:37 | 顯示全部樓層
非常好
ID:84765 發(fā)表于 2017-6-15 17:55 | 顯示全部樓層
學到了!
ID:159139 發(fā)表于 2017-6-17 23:05 來自手機 | 顯示全部樓層
學習了,挺好的,謝謝。
ID:216258 發(fā)表于 2017-9-27 11:12 | 顯示全部樓層
請問一下,我的單片機是stc15w201s,用這個程序為什麼不會動作?需要修改嗎?謝謝
