查看: 3742|回復(fù): 3
1602+24c02定時(shí)器時(shí)鐘單片機(jī)仿真
定時(shí)器時(shí)間可調(diào),時(shí)間顯示正常,但美中不足之處程序有點(diǎn)瑕疵,望高手指點(diǎn)
  1. #include<REG52.h>
  2. #include<24c02.h>
  3. #include<1602.h>
  4. sbit s1=P3^2;//光標(biāo)移位
  5. sbit s2=P3^3;//加鍵
  6. sbit s3=P3^4;//減鍵
  7. sbit beep=P1^0;//蜂鳴器
  8. unsigned char count,s1num;
  9. unsigned char miao,shi,fen;
  10. void delayms(unsigned int time)
  11. {
  12.         unsigned int x,y;
  13.         for(x=time;x>0;x--)
  14.             for(y=110;y>0;y--);
  15.       }
  16.
  17. void di()
  18. {
  19.         beep=0;
  20.         delayms(100);
  21.         beep=1;
  22. }
  23. void write_sfm(uchar add,uchar date)
  24. {
  25.                 uchar shi,ge;
  26.                 shi=date/10;
  27.                 ge=date%10;
  28.                 write_Com(0x80+0x40+add);
  29.                 write_Date(0x30+shi);
  30.                 write_Date(0x30+ge);
  31. }
  32. void InitTimer0(void)
  33. {
  34.     TMOD = 0x01;
  35.     TH0=(65536-50000)/256;
  36.           TL0=(65536-50000)%256;
  37.     EA = 1;
  38.     ET0 = 1;
  39.     TR0 = 1;
  40. }
  41. void keyscan()
  42. {
  43.         if(s1==0)//0是高電平,開(kāi)
  44.         {
  45.                 delayms(5);
  46.                 if(s1==0)
  47.                 {
  48.                  s1num++;
  49.                  while(!s1);
  50.                  di();
  51.
  52.                  if(s1num==1)
  53.                  {
  54.                         TR0=0;
  55.                         write_Com(0x80+0x40+10);
  56.                         write_Com(0x0f);
  57.                  }
  58.
  59.                  if(s1num==2)
  60.                  {
  61.                         write_Com(0x80+0x40+7);
  62.                  }
  63.
  64.                  if(s1num==3)
  65.                  {
  66.                         write_Com(0x80+0x40+4);
  67.                  }
  68.
  69.                  if(s1num==4)
  70.                  {
  71.                         s1num=0; //記錄鍵清零
  72.                         write_Com(0x0c);
  73.                         TR0=1; //到第四次啟動(dòng)定時(shí)器開(kāi)始走
  74.                  }
  75.                 }
  76.         }
  77. /********************************/
  78.         if(s1num!=0) //按完S1才能激活S2
  79.         {
  80. /********************************/
  81.                 if(s2==0)
  82.                 {
  83.                  delayms(5);
  84.                  if(s2==0)
  85.                  {
  86.                         while(!s2);
  87.                         di();
  88.
  89.                         if(s1num==1)//按下每秒加1
  90.                         {
  91.                          miao++;
  92.                          if(miao==60)
  93.                                 miao=0;
  94.                          write_sfm(10,miao);//每調(diào)節(jié)一次送液晶顯示一次
  95.                          write_Com(0x80+0x40+10);//顯示輸入地址
  96.                          write_add(1,miao);//調(diào)節(jié)完畢數(shù)據(jù)立即保存
  97.                         }
  98.
  99.                         if(s1num==2)//按下每分加1
  100.                         {
  101.                          fen++;
  102.                          if(fen==60)
  103.                                 fen=0;
  104.                          write_sfm(7,fen);//每調(diào)節(jié)一次送液晶顯示一次
  105.                          write_Com(0x80+0x40+7);//顯示輸入地址
  106.                          write_add(2,fen);//調(diào)節(jié)完畢數(shù)據(jù)立即保存
  107.                         }
  108.
  109.                         if(s1num==3)//按下每時(shí)加1
  110.                         {
  111.                          shi++;
  112.                          if(shi==24)
  113.                                 shi=0;
  114.                          write_sfm(4,shi);//每調(diào)節(jié)一次送液晶顯示一次
  115.                          write_Com(0x80+0x40+4);//顯示輸入地址
  116.                          write_add(3,shi);//調(diào)節(jié)完畢數(shù)據(jù)立即保存
  117.                         }
  118.                  }
  119.                 }
  120.
  121. /********************************/
  122.                 if(s3==0)
  123.                 {
  124.                  delayms(5);
  125.                  if(s3==0)
  126.                  {
  127.                         while(!s3);
  128.                         di();
  129.
  130.                         if(s1num==1)//按下每秒減1
  131.                         {
  132.                          miao--;
  133.                          if(miao==-1)
  134.                                 miao=59;
  135.                          write_sfm(10,miao);//每調(diào)節(jié)一次送液晶顯示一次
  136.                          write_Com(0x80+0x40+10);//顯示輸入地址
  137.                          write_add(1,miao);//調(diào)節(jié)完畢數(shù)據(jù)立即保存
  138.                         }
  139.
  140.                         if(s1num==2)//按下每分減1
  141.                         {
  142.                          fen--;
  143.                          if(fen==-1)
  144.                                 fen=59;
  145.                          write_sfm(7,fen);//每調(diào)節(jié)一次送液晶顯示一次
  146.                          write_Com(0x80+0x40+7);//顯示輸入地址
  147.                          write_add(2,fen);//調(diào)節(jié)完畢數(shù)據(jù)立即保存
  148.                         }
  149.
  150.                         if(s1num==3)//按下每時(shí)減1
  151.                         {
  152.                          shi--;
  153.                          if(shi==-1)
  154.                                 shi=23;
  155.                          write_sfm(4,shi);//每調(diào)節(jié)一次送液晶顯示一次
  156.                          write_Com(0x80+0x40+4);//顯示輸入地址
  157.                          write_add(3,shi);//調(diào)節(jié)完畢數(shù)據(jù)立即保存
  158.       }
  159.      }
  160.     }
  161.   }
  162. }
  163. void main()
  164. {
  165.         P0=0X00;
  166.         dula=0;
  167.         wela=0;
  168.         init();
  169.         lcdinit();
  170.         InitTimer0();
  171.         miao=read_add(1);
  172.         fen=read_add(2);
  173.         shi=read_add(3);
  174.
  175.         LCD_Write_String(1,2,"2017-6-17-MON");
  176.         LCD_Write_String(0,5,"16-26-00");
  177.         while(1)
  178.         {
  179.                 keyscan();
  180.    }
  181.   }
  182. void timer0() interrupt 1
  183. {
  184.         TH0=(65536-50000)/256;
  185.         TL0=(65536-50000)%256;
  186.         count++;
  187.         if(count==20)
  188.         {
  189.   count=0;
  190.
  191.   miao++;
  192.   if(miao==60)
  193.   {
  194.    miao=0;
  195.
  196.    fen++;
  197.    if(fen==60)
  198. ……………………
  199. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
1602 24c02 定時(shí)器時(shí)間.zip (57.67 KB, 下載次數(shù): 46)
相關(guān)帖子
ID:135253 發(fā)表于 2017-6-19 08:45 | 只看該作者
24C02沒(méi)有看到,圖文程序似乎不太一致!
ID:836287 發(fā)表于 2020-10-29 19:01 | 只看該作者
加了24c02.h,燒寫(xiě)程序的時(shí)候燒不進(jìn)去怎么回事?
ID:728202 發(fā)表于 2020-10-31 10:46 | 只看該作者
沒(méi)有AT24C02啊
