50針SCSI接口
SCSI 是 Small Computer System Interface 的縮寫(xiě),外置式 50針SCSI接口的外觀為母插座:
50針SCSI接口引腳定義 |
Pin |
Name |
Dir |
Description |
01 |
GND |
Ground |
02 |
+DB0 |
+Data Bus 0 |
03 |
+DB1 |
+Data Bus 1 |
04 |
+DB2 |
+Data Bus 2 |
05 |
+DB3 |
+Data Bus 3 |
06 |
+DB4 |
+Data Bus 4 |
07 |
+DB5 |
+Data Bus 5 |
08 |
+DB6 |
+Data Bus 6 |
09 |
+DB7 |
+Data Bus 7 |
10 |
+DBP |
+Data Bus Parity (odd Parity) |
11 |
DIFFSENS |
12 |
res |
Reserved |
13 |
TERMPWR |
Termination Power |
14 |
res |
Reserved |
15 |
+ATN |
+Attention |
16 |
GND |
Ground |
17 |
+BSY |
+Bus is busy |
18 |
+ACK |
+Acknowledge |
19 |
+RST |
+Reset |
20 |
+MSG |
+Message |
21 |
+SEL |
+Select |
22 |
+C/D |
+Control or Data |
23 |
+REQ |
+Request |
24 |
+I/O |
+In/Out |
25 |
GND |
Ground |
26 |
GND |
Ground |
27 |
-DB0 |
-Data Bus 0 |
28 |
-DB1 |
-Data Bus 1 |
29 |
-DB2 |
-Data Bus 2 |
30 |
-DB3 |
-Data Bus 3 |
31 |
-DB4 |
-Data Bus 4 |
32 |
-DB5 |
-Data Bus 5 |
33 |
-DB6 |
-Data Bus 6 |
34 |
-DB7 |
-Data Bus Parity7 |
35 |
-DBP |
-Data Bus Parity (odd Parity) |
36 |
GND |
Ground |
37 |
res |
Reserved |
38 |
TERMPWR |
Termination Power |
39 |
res |
Reserved |
40 |
-ATN |
-Attention |
41 |
GND |
Ground |
42 |
-BSY |
-Bus is busy |
43 |
-ACK |
-Acknowledge |
44 |
-RST |
-Reset |
45 |
-MSG |
-Message |
46 |
-SEL |
-Select |
47 |
-C/D |
-Control or Data |
48 |
-REQ |
-Request |
49 |
-I/O |
-In/Out |
50 |
GND |
Ground |
SCSI的英文全稱(chēng)為“Small Computer System Interface”(小型計(jì)算機(jī)系統(tǒng)接口),是同IDE(ATA)完全不同的接口,IDE接口是普通PC的標(biāo)準(zhǔn)接口,而SCSI并不是專(zhuān)門(mén)為硬盤(pán)設(shè)計(jì)的接口,是一種廣泛應(yīng)用于小型機(jī)上的高速數(shù)據(jù)傳輸技術(shù)。SCSI接口具有應(yīng)用范圍廣、多任務(wù)、帶寬大、CPU占用率低,以及熱插拔等優(yōu)點(diǎn),但較高的價(jià)格使得它很難如IDE硬盤(pán)般普及,因此SCSI硬盤(pán)主要應(yīng)用于中、高端服務(wù)器和高檔工作站中。
