剛玩了一下arduino與andriod手機(jī)的連接,非常棒?梢栽谑謾C(jī)上直接控制arduino了。具體的操作如下。
本實驗需要一個arduino,一個ethernet shield,一個andriod的手機(jī),一個無線路由器。
在arduino端寫入程序:
#include <SPI.h>
#include <Ethernet.h>
#define action_none -1
#define action_out_all 0
#define action_on_light 1
#define action_off_light 2
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xBE }; //physical mac address
byte ip[] = { 192, 168, 1, 222 }; // 填寫ip,設(shè)置arduino服務(wù)器地址,但要和路由器的地址一致
byte gateway[] = { 192, 168, 1, 1 }; // 這是你的默認(rèn)網(wǎng)關(guān)
byte subnet[] = { 255, 255, 255, 0 }; //子網(wǎng)掩碼
Server server(80); //服務(wù)器端口
String readString = String(30); //string for fetching data from address
// arduino out
int pinOutPlight = 4;//把led燈插到pin 4口
// incoming GET command
String r_pinOnLight = "GET /?out=4&status=1";
String r_pinOffLight = "GET /?out=4&status=0";
String r_out_all = "GET /?out=all";
// current action
int current_action;
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
delay(1000);
pinMode(pinOutPlight, OUTPUT);
digitalWrite(pinOutPlight, LOW);
//enable serial datada print
Serial.begin(9600);
current_action = -1;
void loop(){
// Create a client connection
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 30)
//store characters to string
readString = readString + c;
//output chars to serial port
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.print(readString);
if(readString.startsWith(r_pinOnLight))
Serial.print("\n ON UP \n");
current_action = action_on_light;
else if(readString.startsWith(r_pinOffLight))
Serial.print("\n OFF UP \n");
current_action = action_off_light;
else if(readString.startsWith(r_out_all))
Serial.print("\n ALL\n");
current_action = action_out_all;
Serial.print("\n None \n");
current_action = action_none;
// now output HTML data starting with standart header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
char buf[12];
switch(current_action)
case action_out_all:
client.print("{\"ip\" : \"192.168.1.222\", \"devices\" : [{ \"type\" : \"light\", \"name\" : \"LED\", \"out\" : \"");
client.print(pinOutPlight);
client.print("\"}");
client.print("]}");
break;
case action_on_light:
digitalWrite(pinOutPlight, HIGH);
client.print("{\"status\" : \"1\" , \"out\" : \"");
break;
case action_off_light:
client.print("{\"status\" : \"0\" , \"out\" : \"");
break;
default:
//clearing string for next read
readString="";
//stopping client
client.stop();
手機(jī)端安裝軟件domotichome,電子市場上有下載。
copy完后,在手機(jī)上打開domotichome,點擊菜單鍵-settings,輸入剛才在sketch中設(shè)置的那個ip地址,我上面填的是192.168.1.222,下面的port當(dāng)中填寫80,最后save,然后菜單鍵-sync,在界面上會出現(xiàn)light(1),點擊會有LED,左右兩邊有兩個鎖的圖標(biāo),一個控制開,一個控制關(guān)。
