查看: 3722|回復(fù): 0
ARM11 S3C6410 的地址表
ID:3721 發(fā)表于 2015-1-2 20:21 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
參考:1)《ARM1176 JZF-S Technical Reference Manual》:
Chapter 3 System Control Coprocessor
Chapter 6 Memory Management Unit
2)u-boot源碼:
u-boot-x.x.x/cpu/s3c64xx/start.S
u-boot-x.x.x/board/samsung/smdk6410/lowlevel_init.S
1. ARMv6 MMU簡(jiǎn)述
1)MMU由協(xié)處理器CP15控制;
2)MMU功能:地址映射(VA->PA),內(nèi)存訪問(wèn)權(quán)限控制;
3)虛擬地址到物理地址的轉(zhuǎn)換過(guò)程:Micro TLB->Main TLB->Page Table Walk
參考《ARM1176 JZF-S Technical Reference Manual》6.3節(jié),Memory access sequence
摘錄參考手冊(cè)中的一段描述:
When the processor generates a memory access, the MMU:
1. Performs a lookup for a mapping for the requested virtual address and current ASID and
   current world, Secure or Non-secure, in the relevant Instruction or Data MicroTLB.
2. If step 1 misses then a lookup for a mapping for the requested virtual address and current
   ASID and current world, Secure or Non-secure, in the main TLB is performed.
If no global mapping, or mapping for the currently selected ASID, or no matching NSTID, for
the virtual address can be found in the TLBs then a translation table walk is automatically
performed by hardware, unless Page Table Walks are disabled by the PD0 or PD1 bits in the
TTB Control register, that cause the processor to return a Section Translation fault. See
Hardware page table translation on page 6-36.
If a matching TLB entry is found then the information it contains is used as follows:
1. The access permission bits and the domain are used to determine if the access is permitted.
   If the access is not permitted the MMU signals a memory abort, otherwise the access is
   enabled to proceed. Memory access control on page 6-11 describes how this is done.
2. The memory region attributes control the cache and write buffer, and determine if the
   access is Secure or Non-secure cached, uncached, or device, and if it is shared, as Memory
   region attributes on page 6-14 describes.
3. The physical address is used for any access to external or tightly coupled memory to
   perform Tag matching for cache entries.
2. 址映射過(guò)程詳述
參考《ARM1176 JZF-S Technical Reference Manual》6.11節(jié),Hardware page table translation
關(guān)于頁(yè)表:ARMv6的MMU進(jìn)行地址映射時(shí)涉及到兩種頁(yè)表,一級(jí)頁(yè)表(first level page table)和二級(jí)頁(yè)表(coarse page table)。
關(guān)于映射方式:映射方式有兩種,段映射和頁(yè)映射。段映射只用到一級(jí)頁(yè)表,頁(yè)映射用到一級(jí)頁(yè)表和二級(jí)頁(yè)表。
關(guān)于映射粒度:段映射的映射粒度有兩種,1M section和16M supersection;頁(yè)映射的映射粒度也有兩種,4K small page和64K large page。
硬件在做地址轉(zhuǎn)換時(shí),如何知道當(dāng)前是什么映射方式以及映射粒度是多少呢?
這些信息可以從頁(yè)表的入口描述符中獲得。
一級(jí)頁(yè)表的入口描述符(first-level descriptor)格式如下:
第[1:0]位決定映射方式:
[1:0]=10b時(shí),是段映射,此時(shí)只需作一級(jí)映射,描述符的最高12或8位存放的是段基址;
[1:0]=01b時(shí),是頁(yè)映射,此時(shí)虛擬地址轉(zhuǎn)換為物理地址需要經(jīng)歷二級(jí)映射,描述符的最高22位存放的是二級(jí)頁(yè)表的物理地址;
第[18]位決定段映射的粒度:
[18]=0b時(shí),映射粒度為1M,描述符的最高12位存放段基址;
[18]=1b時(shí),映射粒度為16M,描述符的最高8位存放段基址;
當(dāng)映射方式為頁(yè)映射時(shí),我們用到二級(jí)頁(yè)表,二級(jí)頁(yè)表的入口描述符(second-level descriptor)格式如下:
第[1:0]位決定頁(yè)映射的映射粒度:
[1:0]=10b或11b時(shí),映射粒度為4KB,描述符的最高20位為頁(yè)基址;
[1:0]=01b時(shí),映射粒度為64KB,描述符的最高16位為頁(yè)基址;
下面分4種情況對(duì)地址映射過(guò)程做詳細(xì)描述:
1)段映射,映射粒度為1M
2)段映射,映射粒度為16M
3)頁(yè)映射,映射粒度為4K
4)頁(yè)映射,映射粒度為64K
2.1段映射,映射粒度為1M
當(dāng)映射方式為段映射,且映射粒度為1M時(shí),映射圖如下:
虛擬地址到物理地址的映射過(guò)程如下:
虛擬地址的[31:20]位存放一級(jí)頁(yè)表的入口index,[19:0]位存放段偏移;
從TTBR(translation table base register,協(xié)處理器CP15中的一個(gè)寄存器,用于存放一級(jí)頁(yè)表的基址)寄存器中獲取一級(jí)頁(yè)表的基址;
一級(jí)頁(yè)表基址+ VA[31:20] = 該虛擬地址對(duì)應(yīng)的頁(yè)表描述符的入口地址;
頁(yè)表描述符的[31:20]位為該虛擬地址對(duì)應(yīng)的物理段基址;
物理段基址+ VA[19:0]段偏移= 物理地址
由映射圖可知,一個(gè)虛擬地址可以索引2^12個(gè)一級(jí)頁(yè)表入口,每個(gè)入口映射2^20大小的內(nèi)存,故虛擬地址可以映射的最大物理內(nèi)存為:2^12 * 2^20,即4G。
2.2 段映射,映射粒度為16M
當(dāng)映射方式為段映射,且映射粒度為16M時(shí),映射圖如下:
虛擬地址的[31:24]位存放一級(jí)頁(yè)表的入口index,[23:0]位存放段偏移;
一級(jí)頁(yè)表基址+ VA[31:24] = 該虛擬地址對(duì)應(yīng)的頁(yè)表描述符的入口地址;
頁(yè)表描述符的[31:24]位為該虛擬地址對(duì)應(yīng)的物理段基址;
物理段基址+ VA[23:0]段偏移= 物理地址
由映射圖可知,一個(gè)虛擬地址可以索引2^8個(gè)一級(jí)頁(yè)表入口,每個(gè)入口映射2^24大小的內(nèi)存,故虛擬地址可以映射的最大物理內(nèi)存為:2^8 * 2^24,即4G。
2.3 頁(yè)映射,映射粒度為4K
當(dāng)映射方式為頁(yè)映射,且映射粒度為4K時(shí),映射圖如下:
虛擬地址的[31:20]位存放一級(jí)頁(yè)表的入口index,[19:12]位存放二級(jí)頁(yè)表的入口index,[11:0]位存放頁(yè)偏移;
一級(jí)頁(yè)表基址+ VA[31:20] = 一級(jí)頁(yè)表描述符的入口地址;
一級(jí)頁(yè)表描述符的[31:10]位存放二級(jí)頁(yè)表的基址;
二級(jí)頁(yè)表基址+ VA[19:12] = 二級(jí)頁(yè)表描述符的入口地址;
二級(jí)頁(yè)表描述符的[31:12]位存放該虛擬地址在內(nèi)存中的物理頁(yè)基址;
物理頁(yè)基址+ VA[11:0]頁(yè)偏移= 物理地址
由映射圖可知,一個(gè)虛擬地址可以索引2^12個(gè)一級(jí)頁(yè)表入口,每個(gè)一級(jí)頁(yè)表入口指向的二級(jí)頁(yè)表最大可以有2^8個(gè)二級(jí)頁(yè)表入口,每個(gè)二級(jí)頁(yè)表入口映射2^12大小的內(nèi)存,故虛擬地址可以映射的最大物理內(nèi)存為:2^12 * 2^8 * 2^12 ,即4G。
2.4 頁(yè)映射,映射粒度為64K
當(dāng)映射方式為頁(yè)映射,且映射粒度為64K時(shí),映射圖如下:
虛擬地址的[31:20]位存放一級(jí)頁(yè)表的入口index,[19:16]位存放二級(jí)頁(yè)表的入口index,[15:0]位存放頁(yè)偏移;
二級(jí)頁(yè)表基址+ VA[19:16] = 二級(jí)頁(yè)表描述符的入口地址;
二級(jí)頁(yè)表描述符的[31:16]位存放該虛擬地址在內(nèi)存中的物理頁(yè)基址;
物理頁(yè)基址+ VA[15:0]頁(yè)偏移= 物理地址
由映射圖可知,一個(gè)虛擬地址可以索引2^12個(gè)一級(jí)頁(yè)表入口,每個(gè)一級(jí)頁(yè)表入口指向的二級(jí)頁(yè)表最大可以有2^4個(gè)二級(jí)頁(yè)表入口,每個(gè)二級(jí)頁(yè)表入口映射2^16大小的內(nèi)存,故虛擬地址可以映射的最大物理內(nèi)存為:2^12 * 2^4 * 2^16 ,即4G。
2.5 地址映射總圖
《ARM1176 JZF-S Technical Reference Manual》中有一張對(duì)上述四種映射情況的匯總圖:
3. 關(guān)于一級(jí)頁(yè)表基址
參考《ARM1176 JZF-S Technical Reference Manual》6.12 MMU descriptors
ARMv6中有兩個(gè)協(xié)處理器寄存器用來(lái)存放一級(jí)頁(yè)表基地址,TTBR0和TTBR1。操作系統(tǒng)把虛擬內(nèi)存劃分為內(nèi)核空間和用戶空間,TTBR0存放用戶空間的一級(jí)頁(yè)表基址,TTBR1存放內(nèi)核空間的一級(jí)頁(yè)表基址。
In this model, the virtual address space is divided into two regions:
? 0x0 -> 1<<(32-N) that TTBR0 controls
? 1<<(32-N) -> 4GB that TTBR1 controls.
N的大小由TTBCR寄存器決定。0x0 -> 1<<(32-N)為用戶空間,由TTBR0控制,1<<(32-N) -> 4GB為內(nèi)核空間,由TTBR1控制。
N的大小與一級(jí)頁(yè)表大小的關(guān)系圖如下:
操作系統(tǒng)為用戶空間的每個(gè)進(jìn)程分配各自的頁(yè)表,即每個(gè)進(jìn)程的一級(jí)頁(yè)表基址是不一樣的,故當(dāng)發(fā)生進(jìn)程上下文切換時(shí),TTBR0需要被存放當(dāng)前進(jìn)程的一級(jí)頁(yè)表基址;TTBR1中存放的是內(nèi)核空間的一級(jí)頁(yè)表基址,內(nèi)核空間的一級(jí)頁(yè)表基址是固定的,故TTBR1中的基址值不需要改變。
4.  u-boot中MMU初始化代碼分析
u-boot中的MMU地址映射方式為段映射,映射粒度為1M,只用到一級(jí)頁(yè)表。
start.S中的MMU初始化代碼如下:
#ifdef CONFIG_ENABLE_MMU
enable_mmu:
    /* enable domain access */
    ldr    r5, =0x0000ffff
    mcr    p15, 0, r5, c3, c0, 0        @ load domain access register
    /* Set the TTB register */
    ldr    r0, _mmu_table_base
    ldr    r1, =CFG_PHY_UBOOT_BASE
    ldr    r2, =0xfff00000
    bic    r0, r0, r2
    orr    r1, r0, r1
    mcr    p15, 0, r1, c2, c0, 0
    /* Enable the MMU */
mmu_on:
    mrc    p15, 0, r0, c1, c0, 0
    orr    r0, r0, #1            /* Set CR_M to enable MMU */
    mcr    p15, 0, r0, c1, c0, 0
    nop
    nop
    nop
    nop
#endif
_mmu_table_base:
    .word mmu_table
#endif
對(duì)協(xié)處理器的寄存器操作參考:
《ARM1176 JZF-S Technical Reference Manual》Chapter 3 System Control Coprocessor
MMU初始化過(guò)程中有一步是將頁(yè)表基址(CFG_PHY_UBOOT_BASE + mmu_table)存入TTBR0中,在lowlevel_init.S中可以看到對(duì)頁(yè)表的初始化:
* MMU Table for SMDK6400
    /* form a first-level section entry */
.macro FL_SECTION_ENTRY base,ap,d,c,b
    .word (ase << 20) | (ap << 10) |
          (d << 5) | (1<<4) | (c << 3) | ( << 2) | (1<<1)
.endm
.section .mmudata, 'a'
    .align 14
    // the following alignment creates the mmu table at address 0x4000.
    .globl mmu_table
mmu_table:
    .set __base,0
    // 1:1 mapping for debugging
    .rept 0xA00
    FL_SECTION_ENTRY __base,3,0,0,0
    .set __base,__base+1
    .endr
    // access is not allowed.
    .rept 0xC00 - 0xA00
    .word 0x00000000
    .endr
    // 128MB for SDRAM 0xC0000000 -> 0x50000000
    .set __base, 0x500
    .rept 0xC80 - 0xC00
    FL_SECTION_ENTRY __base,3,0,1,1
    .endr
    .rept 0x1000 - 0xc80
    .word 0x00000000
    .endr
#endif
下面對(duì)頁(yè)表的初始化代碼作詳細(xì)解釋:
.endm
定義一個(gè)宏FL_SECTION_ENTRY用來(lái)設(shè)置頁(yè)表入口描述符,base即物理基址,ap即access permission,d即domain,c即cacheable,b即bufferable。
內(nèi)存訪問(wèn)控制和段屬性相關(guān)描述請(qǐng)參考:
《ARM1176 JZF-S Technical Reference Manual》6.6 Memory access control和6.7 Memory region attributes。
    .align 14
定義一個(gè)名為mmudata的段,段屬性為“a”,allowable,該段16K對(duì)齊。從u-boot.lds中可以看到,u-boot的各個(gè)段在內(nèi)存中的分布依次為:.text,.rodata,.data,.got,.u_boot_cmd,.mmudata,.bss。
為什么頁(yè)表是16K對(duì)齊呢?
在上一節(jié)我們講過(guò):有兩個(gè)寄存器TTBR0和TTBR1用來(lái)存放一級(jí)頁(yè)表基址,操作系統(tǒng)把虛擬地址空間劃分為用戶空間和內(nèi)核空間,0x0 -> 1<<(32-N)為用戶空間,由TTBR0控制,1<<(32-N) -> 4GB為內(nèi)核空間,由TTBR1控制,N的大小由TTBCR寄存器決定。由于u-boot主要作用是硬件初始化和引導(dǎo)操作系統(tǒng),所以沒(méi)有必要對(duì)虛擬地址空間進(jìn)行劃分,即N=0,整個(gè)虛擬地址空間由TTBR0控制,TTBR0的格式如下:
N=0時(shí),[31:14]存放頁(yè)表基址,即一級(jí)頁(yè)表的基址為([31:14]<<14),2^14為16K。
    .set __base,0
    .rept 0xA00
    .endr
對(duì)虛擬地址0x0-0xA0000000作平行映射(flat mapping),即把虛擬地址0x0-0xA0000000映射到物理地址0x0-0xA0000000。
    .rept 0xC00 - 0xA00
    .word 0x00000000
    .endr
不對(duì)虛擬地址空間0xA0000000-0xC0000000作映射,即禁止訪問(wèn)虛擬地址空間0xA0000000-0xC0000000。
    .set __base, 0x500
    .rept 0xC80 - 0xC00
    .endr
把虛擬地址空間0xC0000000-0xC8000000映射到物理地址空間0x50000000-0x58000000,0x50000000-0x58000000為sdram的地址空間,此時(shí)sdram有128M。
    .word 0x00000000
    .endr
不對(duì)虛擬地址空間0xc8000000-0xffffffff作映射,即禁止訪問(wèn)虛擬地址空間0xc8000000-0xffffffff。
