查看: 10049|回復(fù): 11
很牛逼虛擬示波器proteus仿真 包含程序
ID:124161 發(fā)表于 2016-6-5 19:40 | 顯示全部樓層 |閱讀模式
虛擬示波器proteus仿真原理圖
虛擬示波器程序:
  1. /*Mini51B數(shù)字示波器*/
  2. /*原作者:田開(kāi)坤*/
  3. //移植:古道熱腸
  4. #include <reg52.h>
  5. #include "osc.h"
  6. #include "lcd12864.h"
  7. #include "irm.h"
  8. #include "timer2.h"
  9. #include "dots.h"
  10. void main()
  11. {
  12.            char i=0,j=0,k=0;
  13.         unsigned char dah,dal,dam;
  14.         int tmp,tmp1;
  15.         pointxA=10;
  16.         pointxB=110;
  17.         pointyA=14;
  18.         pointyB=44;
  19.         lcd12864_init();
  20.         extern2_init();
  21.         timer2_init();
  22.         lcd12864_put_xywhb(0,7,128,8,bg);
  23.         disp_vdiv();
  24.           disp_ypoint();
  25.
  26.         while(1)
  27.         {
  28.                 key_scan();
  29.                 if((da_finish)||(run_flag)) {
  30.                         dah=0;dal=255;
  31.                         for(i=0;i<DATA_SIZE/2;i++) {
  32.                                 if(da_buffer[i] > dah) dah = da_buffer[i]; //找出最大值
  33.                                 if(da_buffer[i] < dal) dal = da_buffer[i]; //找出最小值
  34.                         }
  35.                         dam=(dah-dal)/2+dal; //計(jì)算出中間值
  36.                         i=0;
  37.                         while(da_buffer[i] <= dam) if(++i > (DATA_SIZE/2)) break;
  38.                         while(da_buffer[i]  > dam) if(++i > (DATA_SIZE/2)) break;
  39.                         while(da_buffer[i] <= dam) if(++i > (DATA_SIZE/2)) break;
  40.                         while(da_buffer[i]  > dam) if(++i > (DATA_SIZE/2)) break;
  41.                         for(j=0;j<WIDTH;j++)
  42.                         {
  43.                                 if(acdc_flag==0)
  44.                                 {
  45.                                         tmp = da_buffer[i+j+movx]-dam;
  46.                                         tmp1 = da_buffer[i+j+movx+1]-dam;
  47.                                         tmp = tmp/(vdiv[val_vdiv])+HEIGHT/2 + movy; //過(guò)濾直流成分
  48.                                         tmp1 = tmp1/(vdiv[val_vdiv])+HEIGHT/2 + movy; //過(guò)濾直流成分
  49.                                 }
  50.                                 else
  51.                                 {
  52.                                         tmp = da_buffer[i+j+movx]/(vdiv[val_vdiv]) + movy;
  53.                                         tmp1 = da_buffer[i+j+movx+1]/(vdiv[val_vdiv]) + movy;
  54.                                 }
  55.                         if(tmp > HEIGHT-1) tmp = HEIGHT-1;
  56.                         if(tmp1 > HEIGHT-1) tmp1 = HEIGHT-1;
  57.                         if(tmp < 0) tmp =0;
  58.                         if(tmp1 < 0) tmp1 =0;
  59.                         k=tmp-tmp1;
  60.                         disp(j,tmp,k);
  61.                         }
  62.                         da_finish=0;
  63.                 }
  64.         }
  65. }
虛擬示波器的所有資料下載:
示波器程序.zip (102 KB, 下載次數(shù): 119)
虛擬示波器仿真電路.zip (74.13 KB, 下載次數(shù): 130)
ID:138443 發(fā)表于 2016-10-4 23:06 | 顯示全部樓層
你太牛了,謝謝
ID:138443 發(fā)表于 2016-10-5 00:37 | 顯示全部樓層
太好了,謝謝
ID:138443 發(fā)表于 2016-10-5 00:42 | 顯示全部樓層
太好了,謝謝了,下來(lái)玩玩
ID:142813 發(fā)表于 2016-10-15 11:56 | 顯示全部樓層
如果能測(cè)量就好了
ID:99525 發(fā)表于 2016-10-31 17:21 | 顯示全部樓層
這個(gè)應(yīng)該可以用于簡(jiǎn)單測(cè)量
ID:142559 發(fā)表于 2017-4-29 16:26 | 顯示全部樓層
頻率不變嗎?
ID:234779 發(fā)表于 2017-9-22 00:33 | 顯示全部樓層
很好的資料,謝謝
ID:57831 發(fā)表于 2018-3-1 21:05 | 顯示全部樓層
太好了,謝謝
ID:57831 發(fā)表于 2018-3-1 21:06 | 顯示全部樓層
你太牛了,謝謝
ID:32289 發(fā)表于 2019-1-12 20:30 | 顯示全部樓層
帶寬可以到多少?
ID:247623 發(fā)表于 2019-1-16 22:24 | 顯示全部樓層
頻率只有0-99HZ ?
