查看: 3649|回復(fù): 2
DC-DC閉環(huán)帶穩(wěn)壓控制 單片機程序
ID:201816 發(fā)表于 2017-5-17 15:32 | 顯示全部樓層 |閱讀模式
int main(void)
        u16 led0pwmval=1050;
  u8 key;                  //±£′æ¼üÖμ
        u16 adcx;
        u16 Zreal;
        float temp;
        float Xreal;
        KEY_Init();       //3õê¼»ˉóë°′¼üᬽóμÄó2¼t½ó¿ú
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//éèÖÃÏμí3ÖD¶ÏóÅÏè¼¶·Ö×é2
        delay_init(168);  //3õê¼»ˉÑóê±oˉêy
        uart_init(115200);//3õê¼»ˉ′®¿ú2¨ìØÂêÎa115200
        TIM3_PWM_Init(2100-1,2-1);
        SPI1_Init();
        LED_Init();                                        //3õê¼»ˉLED "ADC1_CH5_VOL:0.000V"
         LCD_Init();         //3õê¼»ˉLCD½ó¿ú"ADC1_CH5_VAL:"
        Adc_Init();         //3õê¼»ˉADC
        BACK_COLOR=WHITE;
        POINT_COLOR=RED;//éèÖÃ×ÖìåÎaREDé«
        //LCD_ShowString(30,130,200,16,16,"BOOST____VAL:      ");
        LCD_ShowString(30,150,200,16,16,"BOOST____VOL:0.000V");        //ÏèÔú1춨λÖÃÏÔê¾D¡êyμã
                key=KEY_Scan(0);                //μÃμ½¼üÖμ
          if(key)
                        switch(key)
                                case KEY2_PRES:
                                  led0pwmval+=105;
                                        break;
                                case KEY1_PRES:
                                        led0pwmval-=105;
                                        break;
                                case KEY0_PRES:
                                        led0pwmval+=105;
                                break;
                                case WKUP_PRES:
                                        led0pwmval-=105;
                                        break;
                }else
                delay_ms(10);
                TIM_SetCompare1(TIM3,led0pwmval);
                adcx=Get_Adc_Average(ADC_Channel_3,200);//»ñè¡í¨μà5μÄ×a»»Ö죬20′Îè¡Æ½¾ù  Õaàï»1¿éòÔè¡Æ½¾ù′ÎêyéÔ΢′óò»μ㣬
                //LCD_ShowxNum(134,130,adcx,4,16,0);     //ÏÔê¾ADCC2éÑùoóμÄÔ-ê¼Öμ
                temp=(float)adcx*(3.3/4096);           //»ñ衼ÆËãoóμÄ′øD¡êyμÄêμ¼êμçÑ1Ö죬±èèç3.1111
                adcx=temp;                                         //¸3ÖμÕûêy2¿·Ö¸øadcx±äá¿£¬òòÎaadcxÎau16ÕûDÎ
                Zreal=11*adcx;
                LCD_ShowxNum(134,150,Zreal,1,16,0);    //ÏÔê¾μçÑ1ÖμμÄÕûêy2¿·Ö£¬3.1111μÄ»°£¬Õaàï¾íêÇÏÔê¾3
                temp-=adcx;                            //°ÑòѾ-ÏÔê¾μÄÕûêy2¿·Öè¥μô£¬áôÏÂD¡êy2¿·Ö£¬±èèç3.1111-3=0.1111
                temp*=1000;                //D¡êy2¿·Ö3ËòÔ1000£¬àyèç£o0.1111¾í×a»»Îa111.1£¬Ïàμ±óú±£áôèyλD¡êy¡
          Xreal=11*temp;
                LCD_ShowxNum(150,150,Xreal,3,16,0X80); //ÏÔê¾D¡êy2¿·Ö£¨Ç°Ãæ×a»»ÎaáËÕûDÎÏÔê¾£©£¬ÕaàïÏÔê¾μľíêÇ111.
    while(Zreal!=(int)25200/(2100-led0pwmval))  //μ÷½úÕûêy2¿·Öò»¶¨òaóëÔ¤¶¨Ïàò»ÖÂ. 25200êÇ123ËéÏ2100£¬Õaàï¾-1y»ˉ¼òáË¡£
                {   if(Zreal>(int)25200/(2100-led0pwmval))    //intÇ¿ÖÆ×a»»£¬μ«ò2óD¿éÄüêǶàóàμÄ
                        led0pwmval-=0.02*led0pwmval;
                        else led0pwmval+=0.02*led0pwmval;
                  Zreal=11*adcx;                        //3ËéÏ11μÄÔ-òòêÇòòÎa¼óéÏáËÔË·Å£¬2aá¿ÖμËõD¡áË11±¶¡£
            Xreal=11*temp;
                delay_ms(150);
ID:304545 發(fā)表于 2018-4-12 10:53 | 顯示全部樓層
求電路圖
ID:56665 發(fā)表于 2019-7-2 11:25 | 顯示全部樓層
你這個閉環(huán)的輸出取樣點在哪里,怎么沒看到,沒有取樣點,靠開關(guān)控制PWM是開環(huán)。
