/***************************************************** 007.ASM 接線:P0口接數(shù)碼管 P2接矩陣鍵盤 用定時(shí)中斷,若一段時(shí)間無操作,數(shù)碼管進(jìn)入自到循環(huán)顯示 2010.09.05 *******************************************************/ ORG 0000H LJMP MAIN ORG 000BH LJMP INT_T0 ORG 0020H MAIN: ;主程序 MOV SP,#50H MOV DPTR,#LED_DATA ;取表首地址 MOV TMOD,#01H ;設(shè)置定時(shí)器T0工作模式 MOV TH0,#15H ;寫計(jì)時(shí)初值 MOV TL0,#9FH MOV P2,#0FFH ;P2口賦初值 MOV R4,#00H ;賦定時(shí)計(jì)數(shù)初值 SETB 00H ;00H為鍵值改變標(biāo)志位 SETB TR0 ;啟動(dòng)定時(shí)器T0 MOV IE,#82H ;開中斷 LCALL SHOW ;數(shù)碼管初始化 loop: ;主循環(huán) LCALL KEY_READ ;讀鍵盤 JBC 00H,LOOP0 ;判斷是否有鍵被按下,有則轉(zhuǎn)去刷新輸出并清零定時(shí)計(jì)數(shù) CJNE R4,#0C8H,LOOP ;沒有鍵被按下,則判斷定時(shí)時(shí)間是否達(dá)到,到,則進(jìn)入數(shù)碼管循環(huán)輸出 LCALL SHOW1 ;沒到,則回到主循環(huán),重新掃描鍵盤 SJMP LOOP LOOP0: LCALL SHOW MOV R4,#00H SJMP LOOP ;輸出刷新完畢,回到主循環(huán),重新掃描鍵盤 /*鍵盤掃描程序*/ KEY_READ: CLR P2.6 ;P2.6輸出低 JB P2.0,N0_0 MOV R0,#01H LCALL DELAY JB P2.0,N0_0 JNB P2.0,$ MOV R5,#04H SETB 00H SETB P2.6 LJMP NEAT N0_0: JB P2.1,N0_1 MOV R0,#01H LCALL DELAY JB P2.1,N0_1 MOV R5,#03H JNB P2.1,$ SETB 00H SETB P2.6 LJMP NEAT N0_1: JB P2.2,N0_2 MOV R0,#01H LCALL DELAY JB P2.2,N0_2 JNB P2.2,$ MOV R5,#02H SETB 00H SETB P2.6 LJMP NEAT N0_2: JB P2.3,N1_0 MOV R0,#01H LCALL DELAY JB P2.3,N1_0 JNB P2.3,$ MOV R5,#01H SETB 00H SETB P2.6 LJMP NEAT N1_0: SETB P2.6 CLR P2.5 JB P2.0,N1_1 MOV R0,#01H LCALL DELAY JB P2.0,N1_1 JNB P2.0,$ MOV R5,#08H SETB 00H SETB P2.5 LJMP NEAT N1_1: JB P2.1,N1_2 MOV R0,#01H LCALL DELAY JB P2.1,N1_2 JNB P2.1,$ MOV R5,#07H SETB 00H SETB P2.5 LJMP NEAT N1_2: JB P2.2,N1_3 MOV R0,#01H LCALL DELAY JB P2.2,N1_3 JNB P2.2,$ MOV R5,#06H SETB 00H SETB P2.5 LJMP NEAT N1_3: JB P2.3,N2_0 MOV R0,#01H LCALL DELAY JB P2.3,N2_0 JNB P2.3,$ MOV R5,#05H SETB 00H SETB P2.5 LJMP NEAT N2_0: SETB P2.5 CLR P2.4 JB P2.0,N2_1 MOV R0,#01H LCALL DELAY JB P2.0,N2_1 JNB P2.0,$ MOV R5,#0CH SETB 00H SETB P2.4 LJMP NEAT N2_1: JB P2.1,N2_2 MOV R0,#01H LCALL DELAY JB P2.1,N2_2 JNB P2.1,$ MOV R5,#0BH SETB 00H SETB P2.4 LJMP NEAT N2_2: JB P2.2,N2_3 MOV R0,#01H LCALL DELAY JB P2.2,N2_3 JNB P2.2,$ MOV R5,#0AH SETB 00H SETB P2.4 LJMP NEAT N2_3: JB P2.3,NEAT MOV R0,#01H LCALL DELAY JB P2.3,NEAT JNB P2.3,$ MOV R5,#09H SETB 00H SETB P2.4 LJMP NEAT NEAT: SETB P2.4 RET /*顯示子程序*/ SHOW: MOV A,R5 MOVC A,@A+DPTR MOV P0,A RET /*循環(huán)顯示子程序*/ SHOW1: ; MOV R3,#00H LOOP1: MOV A,R3 MOVC A,@A+DPTR MOV P0,A MOV R0,#35H LCALL DELAY INC R3 LCALL KEY_READ JB 00H,RETUN1 CJNE R3,#10H,LOOP1 MOV R3,#00H SJMP LOOP1 RETUN1: RET /*延時(shí)子程序*/ DELAY: D0: MOV R2,#0FH D1: MOV R1,#0BFH D2: DJNZ R1,D2 DJNZ R2,D1 DJNZ R0,D0 RET /*定時(shí)中斷T0處理子程序*/ INT_T0: CLR EA PUSH ACC INC R4 MOV TH0,#15H MOV TL0,#9FH POP ACC SETB EA RETI /*數(shù)碼管顯示代碼,0~F*/ LED_DATA: DB 03H,9FH,25H,0DH,99H,49H,41H,1FH DB 01H,09H,11H,0C1H,63H,85H,61H,71H END
