AM12864測(cè)試程序(C語(yǔ)言)
/* AM12864測(cè)試程序 1.0 */
/* Designed by Andorin LCM R&D Group */
#include <reg51.h>
#include <ctype.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
/* Define the register command code */
#define Disp_On 0x3f
#define Disp_Off 0x3e
#define Col_Add 0x40
#define Page_Add 0xb8
#define Start_Line 0xc0
#define Lcd_Bus P1 //MCU P1<------> LCM
sbit Mcs=P2^3; //Master chip enable
sbit Scs=P2^4; //Slave chip enable
sbit Enable=P2^2; //6800 mode Enable single
sbit Di=P2^0; //Data or Instrument Select
sbit RW=P2^1; //Write or Read
sbit Lcd_Rst=P2^5; //Lcm reset
sbit Test_Key=P3^1;
char code ce[]={/*-- 文字: 測(cè) --*/0x08,0x31,0x86,0x60,0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0xF8,0x00,0x00,0xFF,0x00,
0x04,0xFC,0x03,0x00,0x80,0x47,0x30,0x0F,0x10,0x67,0x00,0x07,0x40,0x80,0x7F,0x00};
char code shi[]={/*-- 文字: 試 --*/0x40,0x42,0xDC,0x08,0x00,0x90,0x90,0x90,0x90,0x90,0xFF,0x10,0x12,0x1C,0x10,0x00,
0x00,0x00,0x7F,0x20,0x10,0x20,0x20,0x1F,0x10,0x10,0x01,0x06,0x18,0x20,0x78,0x00};
char code kai[]={/*-- 文字: 開(kāi) --*/0x40,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00};
char code shi2[]={0x10,0x90,0x70,0x1F,0x12,0xF0,0x00,0x20,0x70,0x28,0x27,0x22,0x28,0x70,0x20,0x00,
0x40,0x21,0x12,0x0C,0x06,0x09,0x30,0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x00};//始
char code wan[]={0x00,0x90,0x8C,0xA4,0xA4,0xA4,0xA5,0xA6,0xA4,0xA4,0xA4,0xA4,0x94,0x8C,0x04,0x00,
0x00,0x80,0x40,0x20,0x18,0x07,0x00,0x00,0x00,0x3F,0x40,0x40,0x40,0x70,0x00,0x00};//完
char code bi[]={0x00,0x00,0xFF,0x88,0x48,0x28,0x08,0x80,0x7F,0x88,0x88,0x88,0x84,0x84,0xE0,0x00,
0x04,0x04,0x04,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00};//畢
char code yang[]={0x20,0x10,0x2C,0x23,0x6A,0xAA,0x2A,0xAA,0x6A,0x2A,0x2A,0x2A,0xEA,0x02,0x00,0x00,
0x00,0x10,0x11,0x15,0x15,0x15,0xFF,0x15,0x15,0x15,0x11,0x10,0x3F,0x40,0x30,0x00};
char code qi[]={0x40,0x20,0x58,0x47,0x54,0x54,0x54,0x54,0x54,0x54,0xD4,0x14,0x06,0x04,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x40,0x80,0x70,0x00};//氣
char code nong[]={0x10 ,0x21 ,0x62 ,0x06 ,0x90 ,0x0C ,0x04 ,0x84,0x64 ,0x9F ,0x04 ,0x04 ,0x94 ,0xCC ,0x00 ,0x00,
0x04 ,0x04 ,0xFE ,0x01 ,0x04 ,0x02 ,0x01 ,0xFF, 0x40 ,0x21 ,0x06 ,0x09 ,0x10 ,0x30 ,0x10 ,0x00 };//濃
char code du[]={0x00 ,0x00 ,0x0FC ,0x24 ,0x24 ,0x24 ,0x0FC ,0xA5, 0xA6 ,0xA4 ,0x0FC ,0x24 ,0x34 ,0x26 ,0x04 ,0x00,
0x40 ,0x20 ,0x9F ,0x80 ,0x42 ,0x42 ,0x26 ,0x2A, 0x12 ,0x2A ,0x26 ,0x42 ,0x40 ,0xC0 ,0x40 ,0x00};//度
char code bi2[]={0x00, 0x00, 0xFE, 0x40, 0x40, 0x60, 0x40, 0x00,0xFF, 0x80, 0x40, 0x20, 0x30, 0x00, 0x00, 0x00,
0x00, 0x40, 0x7F, 0x20, 0x20, 0x10, 0x10, 0x00,0x3F, 0x40, 0x40, 0x40, 0x40, 0x40, 0x78, 0x00};//比
char code fen[]={0x00 ,0x80 ,0x40 ,0x20 ,0x98 ,0x86 ,0x80 ,0x80,0x83 ,0x8C ,0x90 ,0x20 ,0xC0 ,0x80 ,0x80 ,0x00,
0x01 ,0x00 ,0x80 ,0x40 ,0x20 ,0x1F ,0x00 ,0x40, 0x80 ,0x40 ,0x3F ,0x00 ,0x00 ,0x01 ,0x00 ,0x00 };// 分
char code bai[]={0x02 ,0x02 ,0x02 ,0xE2 ,0x22 ,0x32 ,0x2A ,0x26,0x22 ,0x22 ,0x22 ,0xF2 ,0x22 ,0x03 ,0x02 ,0x00,
0x00 ,0x00 ,0x00 ,0xFF ,0x42 ,0x42 ,0x42 ,0x42, 0x42 ,0x42 ,0x42 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00};// 百
char code wei[]={
0x20 ,0x20 ,0x20 ,0x22 ,0x24 ,0x2C ,0x20 , 0xE0,
0x3F ,0x20 ,0x20 ,0x20 ,0x20 ,0xF0 ,0x20 ,0x00,
0x00 ,0x40 ,0x20 ,0x10 ,0x08 ,0x04 ,0x03 ,0x00,
0x02 ,0x04 ,0x4C ,0x80 ,0x40 ,0x3F ,0x00 ,0x00
};//為
/*------------------延時(shí)子程序-----------------------------*/
void delay(unsigned int t)
unsigned int i,j;
for(i=0;i<t;i++) ;
for(j=0;j<10;j++) ;
/*------------------寫(xiě)命令到LCD------------------------------*/
void write_com(unsigned char cmdcode)
do{delay(0);}while(P0^7==1);
Di=0;
RW=0;
Lcd_Bus=cmdcode;
delay(0); //原來(lái)是delay(0)
Enable=1;
delay(0);
Enable=0;
/*-------------------寫(xiě)數(shù)據(jù)到LCD----------------------------*/
void write_data(unsigned char Dispdata)
{ do{delay(10);}while(P0^7==1);
Di=1;
RW=0;
Lcd_Bus=Dispdata;
delay(0);
Enable=1;
delay(0);
Enable=0;
/*-------------------讀LCD數(shù)據(jù)----------------------------*/
unsigned char read_data()
{ //do{delay(100);}while(P0^7==1);
unsigned char tmpin;
Di=1;
RW=1;
delay(0);
Enable=1;
delay(0);
Enable=0;do{delay(100);}while(P0^7==1);
tmpin=Lcd_Bus;
return tmpin;
/*------------------顯示邊框-------------------------------*/
void frame()
unsigned char i;
Mcs=1;
Scs=1;
write_com(Page_Add+0);
write_com(Col_Add+0);
for(i=0;i<64;i++) write_data(0x01);
write_com(Page_Add+7);
for(i=0;i<64;i++) write_data(0x80);
for(i=0;i<8;i++)
Mcs=0;
Scs=1;
write_com(Page_Add+i);
write_com(Col_Add+63);
write_data(0x55);
Mcs=1;
Scs=0;
write_data(0x55);
/*------------------清除內(nèi)存AM12864測(cè)試程序---------------*/
void Clr_Scr()
unsigned char j,k;
Mcs=1;Scs=1;
for(k=0;k<8;k++){
write_com(Page_Add+k);
for(j=0;j<64;j++)write_data(0x00);
/*------------------顯示12864圖片---------------------------*/
void Disp_Img(unsigned char code *img)
unsigned char j,k;
for(k=0;k<8;k++){
Mcs=1;Scs=0;delay(0);
for(j=0;j<64;j++) write_data(img[k*128+j]);
Mcs=0;Scs=1; delay(0);
for(j=64;j<128;j++) write_data(img[k*128+j]);
/*------------------顯示橫--------------AM12864測(cè)試程序-------------*/
void Disp_H_Line()
unsigned char i,j;
Mcs=1;
Scs=1;
write_com(Disp_On);
write_com(Page_Add);
write_com(Start_Line);
write_com(Col_Add);
for(j=0;j<8;j++)
write_com(Page_Add+j);
// write_com(Start_Line+0);
for(i=0;i<64;i++)write_data(0x00);
/*------------------顯示列-----------------------------*/
void Disp_V_Line()
unsigned char i,j;
write_com(Disp_On);
write_com(Col_Add);
for(j=0;j<8;j++)
for(i=0;i<32;i++)
write_data(0x00);
write_data(0x55);
/*------------------棋盤(pán)-----------------------------*/
void Disp_Cross_Line(unsigned char mode)
unsigned char i,j;
unsigned char data1,data2;
if(mode==0) {data1=0xaa;data2=0x55;}
else if(mode==1) {data1=0x55;data2=0xaa;}
else return;
Mcs=1;Scs=1;
write_com(Disp_On);
write_com(Col_Add);
for(j=0;j<8;j++)
for(i=0;i<32;i++){
write_data(data1);
write_data(data2);
/*---------------------指定位置顯示漢字16*16-----------------------*/
void hz_disp16(unsigned char pag,unsigned char col, unsigned char code *hzk)
unsigned char j=0,i=0;
for(j=0;j<2;j++){
write_com(Page_Add+pag+j);
write_com(Col_Add+col);
for(i=0;i<16;i++) write_data(hzk[16*j+i]);
/*------------------初始化LCD屏--------------------------*/
void init_lcd()
{ Lcd_Rst=0;
delay(100);
Lcd_Rst=1;
delay(100);
Mcs=1;
Scs=1;/////////////////////////////////////////////////////////
delay(100);
write_com(Disp_Off); /////////////////////
write_com(Col_Add);
write_com(Disp_On);
/*------------------------------信息顯示------------------------*/
void Msg(int flg)
Clr_Scr();
frame();
if(flg==0){ //顯示"測(cè)試開(kāi)始"
Mcs=1;Scs=0;
hz_disp16(3,32,ce);
delay(2000);
hz_disp16(3,48,shi);
delay(2000);
Mcs=0;Scs=1;
hz_disp16(3,0,kai);
delay(2000);
hz_disp16(3,16,shi2);
delay(2000);
else if(flg==1){ //顯示"測(cè)試完畢"
Mcs=1;Scs=0;
hz_disp16(0,32,ce);
hz_disp16(0,48,shi);
Mcs=0;Scs=1;
hz_disp16(0,0,wan);
hz_disp16(0,16,bi);
Mcs=1;Scs=0;
hz_disp16(3,0,yang);
hz_disp16(3,16,qi);
hz_disp16(3,32,nong);
hz_disp16(3,48,du);
Mcs=0;Scs=1;
hz_disp16(3,0,bai);
hz_disp16(3,16,fen);
hz_disp16(3,32,bi2);
hz_disp16(3,48,wei);
/*--------------------------------鍵盤(pán)掃描-------------------------*/
void Key_Scan()
while(Test_Key);
while(~Test_Key);
/*--------------------主程序-----------AM12864測(cè)試程序----------------------*/
main()
unsigned char i=0;
while(1){
// Key_Scan();
init_lcd();
//Disp_Img(FirstPage);
//delay(10000);
// Key_Scan();
Msg(0);
delay(10000);
Disp_H_Line();
delay(10000);
Disp_V_Line();
delay(10000);
Msg(1);
delay(10000);
Clr_Scr();
//while(1);
