數(shù)碼管顯示的電子時(shí)鐘C51程序
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2011年01月23日   【字體:
功能:
    實(shí)現(xiàn)電子時(shí)鐘顯示(C)
定義:
    P3口位選,P1口段選,P0.0,P0.1,P0.2為調(diào)時(shí)口
時(shí)間:
    2010—11—26
說(shuō)明:
    仿真存在問(wèn)題,這可能是仿真軟件的問(wèn)題,需要將段位掃描反調(diào)
 實(shí)際運(yùn)行的結(jié)果是正確的
#include <AT89X51.H>
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
unsigned char dispbitcode[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char dispbuf[8]={0,0,16,0,0,16,0,0};
unsigned char dispbitcnt;
unsigned char second;
unsigned char minite;
unsigned char hour;
unsigned int tcnt;
unsigned char mstcnt;
unsigned char i,j;
void main(void)
       TMOD=0x02;
       TH0=0x06;
       TL0=0x06;
       TR0=1;
       ET0=1;
       EA=1;
              if(P0_0==0)
                     for(i=5;i>0;i--)
                            for(j=248;j>0;j--);
                     if(P0_0==0)
                            second++;
                            if(second==60)
                                   second=0;
                            dispbuf[0]=second%10;
                            dispbuf[1]=second/10;
                            while(P0_0==0);
              if(P0_1==0)
                     for(i=5;i>0;i--)
                            for(j=248;j>0;j--);
                     if(P0_1==0)
                            minite++;
                            if(minite==60)
                                   minite=0;
                            dispbuf[3]=minite%10;
                            dispbuf[4]=minite/10;
                            while(P0_1==0);
              if(P0_2==0)
                     for(i=5;i>0;i--)
                            for(j=248;j>0;j--);
                     if(P0_2==0)
                            hour++;
                            if(hour==24)
                                   hour=0;
                            dispbuf[6]=hour%10;
                            dispbuf[7]=hour/10;
                            while(P0_2==0);
void t0(void) interrupt 1 using 0
       mstcnt++;
       if(mstcnt==8)
              mstcnt=0;
              P1=dispcode[dispbuf[dispbitcnt]];
              P3=dispbitcode[dispbitcnt];
              dispbitcnt++;
              if(dispbitcnt==8)
                     dispbitcnt=0;
       tcnt++;
       if(tcnt==4000)
              tcnt=0;
              second++;
              if(second==60)
                     second=0;
                     minite++;
                     if(minite==60)
                            minite=0;
                            hour++;
                            if(hour==24)
                                   hour=0;
              dispbuf[6]=hour%10;
              dispbuf[7]=hour/10;
功能:
定義:
    P2口位選,P0口段選
時(shí)間:
    2010—11—26
#include<reg52.h>
code unsigned char tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char StrTab[6];
unsigned char minute=30,hour=12,second=0;
void Displaypro(void)
    StrTab[0]=tab[second%10];
    StrTab[1]=tab[second/10];
    StrTab[2]=tab[minute%10];
    StrTab[3]=tab[minute/10];
    StrTab[4]=tab[hour%10];
    StrTab[5]=tab[hour/10];
main()
    TMOD |=0x01;
    TH0=0xd8;
    TL0=0xf0;
    ET0=1;
    TR0=1;
    TMOD |=0x10;
    TH1=0xF8;
    TL1=0xf0;
    ET1=1;
    TR1=1;
    EA =1;
    while(1){;}
void time1_isr(void) interrupt 3
    static unsigned char num;
    TH1=0xf8;
    TL1=0xf0;
    switch (num)
        case 0:P2=0x01;P0=StrTab[num];break;
        case 1:P2=0x02;P0=StrTab[num];break;
        case 2:P2=0x04;P0=StrTab[num];break;
        case 3:P2=0x08;P0=StrTab[num];break;
        case 4:P2=0x10;P0=StrTab[num];break;
        case 5:P2=0x20;P0=StrTab[num];break;
        default:break;
    num++;
    if(num==6)
    num=0;
void tim(void) interrupt 1
    static unsigned char count;
    TH0=0xd8;
    TL0=0xf0;
    count++;
    switch (count)
        case 0:
        case 20:
        case 40:
        case 60:
        case 80:Displaypro();break;
        default:break;
    if (count==100)
        count=0;
        second++;
        if(second==60)
            second=0;
            minute++;
            if(minute==60)
                minute=0;
                hour++;
                if(hour==24)
                    hour=0;
//源代碼下載 :http://www.torrancerestoration.com/f/szc511.rar
