實現(xiàn)LED分級亮度的簡便算法
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2011年02月22日   【字體:
#include"reg52.h"
unsigned char code table[]={0xfe,0xfc,0xf0,0xe0,0xc0,0x80,0x00};
  unsigned char i;
     i++;
     i&=0x07;
     P1=table;
低電平點亮LED,i=0到7;
while循環(huán)周期*8=PWM的周期
當(dāng)i=0時,D0亮
當(dāng)i=1時,D0,D1亮
當(dāng)i=2時,D0,D1,D2亮
當(dāng)i=7時,D0,D1,D2,D3,D4,D5,D6,D7全亮
也就是說,在while的8個循環(huán)中,D0一直亮,D1則只有7次亮。。。。。。D7則只有1次亮
按照這個算法,只要定義一個一維表格,就可以靜態(tài)現(xiàn)實LED的8個不同亮度,且亮度次序任意
如果定義一個二維表格,則可以動態(tài)現(xiàn)實LED亮度,幾乎可以任意定義次序花樣
下面來看一個完整的二維數(shù)組漸變程序
完整代碼下載地址:http://www.torrancerestoration.com/f/jianb.rar
#include "reg52.h"
unsigned char code table[37][8]=   //定義一個2維數(shù)組
{0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,//off
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,//D0亮度等級1/8
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfc,//D1亮度等級1/8
0xff,0xff,0xff,0xff,0xff,0xff,0xfd,0xfc,//D1亮度等級2/8
0xff,0xff,0xff,0xff,0xff,0xff,0xfd,0xf8,//D2亮度等級1/8
0xff,0xff,0xff,0xff,0xff,0xff,0xf9,0xf8,//D2亮度等級2/8
0xff,0xff,0xff,0xff,0xff,0xfb,0xf9,0xf8,//D2亮度等級3/8
0xff,0xff,0xff,0xff,0xff,0xfb,0xf9,0xf0,//D3
0xff,0xff,0xff,0xff,0xff,0xfb,0xf1,0xf0,
0xff,0xff,0xff,0xff,0xff,0xf3,0xf1,0xf0,
0xff,0xff,0xff,0xff,0xf7,0xf3,0xf1,0xf0,
0xff,0xff,0xff,0xff,0xf7,0xf3,0xf1,0xe0,//D4
0xff,0xff,0xff,0xff,0xf7,0xf3,0xe1,0xe0,
0xff,0xff,0xff,0xff,0xf7,0xe3,0xe1,0xe0,
0xff,0xff,0xff,0xff,0xe7,0xe3,0xe1,0xe0,
0xff,0xff,0xff,0xef,0xe7,0xe3,0xe1,0xe0,
0xff,0xff,0xff,0xef,0xe7,0xe3,0xe1,0xc0,//D5
0xff,0xff,0xff,0xef,0xe7,0xe3,0xc1,0xc0,
0xff,0xff,0xff,0xef,0xe7,0xc3,0xc1,0xc0,
0xff,0xff,0xff,0xef,0xc7,0xc3,0xc1,0xc0,
0xff,0xff,0xff,0xcf,0xc7,0xc3,0xc1,0xc0,
0xff,0xff,0xdf,0xcf,0xc7,0xc3,0xc1,0xc0,
0xff,0xff,0xdf,0xcf,0xe7,0xe3,0xc1,0x80,//D6
0xff,0xff,0xdf,0xcf,0xe7,0xe3,0x81,0x80,
0xff,0xff,0xdf,0xcf,0xe7,0x83,0x81,0x80,
0xff,0xff,0xdf,0xcf,0x87,0x83,0x81,0x80,
0xff,0xff,0xdf,0x8f,0x87,0x83,0x81,0x80,
0xff,0xff,0x9f,0x8f,0x87,0x83,0x81,0x80,
0xff,0xbf,0x9f,0x8f,0x87,0x83,0x81,0x80,
0xff,0xbf,0x9f,0x8f,0x87,0x83,0x81,0x00,//D7
0xff,0xbf,0x9f,0x8f,0x87,0x83,0x01,0x00,
0xff,0xbf,0x9f,0x8f,0x87,0x03,0x01,0x00,
0xff,0xbf,0x9f,0x8f,0x07,0x03,0x01,0x00,
0xff,0xbf,0x9f,0x0f,0x07,0x03,0x01,0x00,
0xff,0xbf,0x1f,0x0f,0x07,0x03,0x01,0x00,
0xff,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00,
0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00,
unsigned char i;
unsigned int j;
unsigned int counter;
bit flag=0;
  i++;
  i&=0x07;       //i=0到7
  counter++;
  if(counter==12000)     //延時對j++
   if(flag==0) j++;
   else j--;
   counter=0;
   if(j==36 || j==0)
    flag=!flag;     //決定正向掃描還是逆向掃描
    i=0;
   P1=table[j];     //掃描第i列,掃描第j行
注意:用2003時,是高電平點亮LED。要對它取反。
