ATmega16L-EEPROM讀寫操作實(shí)驗(yàn)
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2011年06月22日   【字體:
讀寫AVR單片機(jī)EEPROM實(shí)驗(yàn)。
先向單片機(jī)EEPROM寫入254,然后讀出254,
并在數(shù)碼管上顯示出來(lái)
#include<iom16v.h>
const unsigned char duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                              0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
const unsigned char weima[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char shu[8];
unsigned int num;
               延時(shí)函數(shù)
void delay(unsigned char t)
   unsigned char x,y;
   for(x=t;x>0;x--)
    for(y=100;y>0;y--);
               顯示函數(shù)
void display(void)
 unsigned char i;
 for(i=0;i<4;i++)
  PORTB =0X00;
  PORTA|=0X01;
  PORTA&=0XFE;
  PORTB =weima[i];
  PORTA|=0x02;
  PORTA&=0XFD;
  PORTB=shu[i];
  PORTA|=0X01;
  PORTA&=0XFE;
  delay(4);
            寫EEPROM
void write_eep(unsigned int add,unsigned int data)
{              //data為待寫數(shù)據(jù),add為某單元地址
 while(EECR&(1<<EEWE)); //等待前一次寫操作完成
 EEAR=add;              //設(shè)定單元地址
 EEDR=data;             //將數(shù)據(jù)寫入EEDR
 EECR|=(1<<EEMWE);      //允許EEPROM操作
 EECR|=(1<<EEWE);       //開始EEPROM操作
            讀EEPROM
unsigned char read_eep(unsigned int add)
{                      //add為某單元地址
 while(EECR&(1<<EEWE));//等待前一次寫操作完成
 EECR|=(1<<EERE);      //開始EEPROM寫操作
 return EEDR;          //返回讀出的數(shù)據(jù)
             數(shù)據(jù)轉(zhuǎn)換子函數(shù)
void change(unsigned int i)
 shu[0]=duanma[i/1000];
 shu[1]=duanma[i/100%10];
 shu[2]=duanma[i%100/10];
 shu[3]=duanma[i%10];
             端口初始化
void init_port(void)
 PORTA=0XFF;
 DDRA=0XFF;
 PORTB=0XFF;
 DDRB=0XFF;
                MAIN
void main(void)
 init_port();
 write_eep(488,254);
 delay(20);
 num=read_eep(488);
 delay(20);
 change(num);
   display();
