#INCLUDE"P16F877.inc" W_TEMP EQU 20H ; 實(shí)際上20H、A0H、120H和1A0H STATUS_TEMP EQU 21H ;在體0中建立保護(hù)單元 PCLATH_TEMP EQU 22H ;在體0中建立保護(hù)單元 ORG 000H GOTO A1 ORG 004H;定時(shí)中斷入口地址 GOTO ZD01; ORG 0CH Q1 ADDWF PCL,1 RETLW 00C0H ;0 RETLW 00F9H ;1 RETLW 00A4H ;2 RETLW 00B0H ;3 RETLW 0099H ;4 RETLW 0092H ;5 RETLW 0082H ;6 RETLW 00F8H ;7 RETLW 0080H ;8 RETLW 0090H ;9 RETLW 0088H ;A RETLW 0083H ;B RETLW 00C6H ;C RETLW 00A1H ;D RETLW 0086H ;E RETLW 008EH ;F A1 MOVLW 1;位1顯示數(shù) MOVWF 50H; MOVLW 2;位2顯示數(shù) MOVWF 51H; MOVLW 3;位3顯示數(shù) MOVWF 52H; MOVLW 4;位4顯示數(shù) MOVWF 53H; CLRF 60H MOVLW 4;顯示位數(shù) MOVWF 40H; MOVLW B'00000001';位碼 MOVWF 41H; MOVLW 50H; MOVWF FSR ;間接尋址 BSF STATUS,RP0;選擇體1 BCF STATUS,RP1; MOVLW 00H;1:2TMRO比例 MOVWF OPTION_REG;分頻1/2 BCF STATUS,RP0;體0 BCF STATUS,RP1; MOVLW 0FFH; MOVFW TMR0;初值 BCF INTCON,T0IF;清定時(shí)中斷標(biāo)志 BSF INTCON,T0IE;開定時(shí)中斷 BSF INTCON,GIE;開總中斷 ;********************************************************** ; 按鍵修改數(shù)據(jù)程序 ;********************************************************** A2 BSF STATUS,RP0 BCF STATUS,RP1;體1 MOVLW 0FFH MOVWF TRISB;設(shè)置B口為輸入口 BCF STATUS,RP0 BCF STATUS,RP1;體0 BTFSC PORTB,0;判斷B口第0位是否按下 GOTO A3;位0則按下按鍵 MOVLW 1;按下存1到EEPROM MOVWF 61H;數(shù)據(jù)寄存器 CALL WR1;寫數(shù)據(jù)到EEPROM A3 BCF STATUS,RP0 BCF STATUS,RP1;體0 BTFSC PORTB,1;判斷B口第1位是否按下 GOTO A4; MOVLW 2;按下存2到EEPROM MOVWF 61H;數(shù)據(jù)寄存器 CALL WR1;寫數(shù)據(jù)到寄存器 A4 BCF STATUS,RP0; BCF STATUS,RP1;體0 BTFSC PORTB,2;判斷B口第2位是否按下 GOTO A5; MOVLW 3; MOVWF 61H; CALL WR1; A5 BCF STATUS,RP0; BCF STATUS,RP1; BTFSC PORTB,3; GOTO A6; MOVLW 4; MOVWF 61H; CALL WR1; A6 BCF STATUS,RP0; BCF STATUS,RP1; BTFSC PORTB,4; GOTO A7; MOVLW 5; MOVWF 61H; CALL WR1; A7 BCF STATUS,RP0; BCF STATUS,RP1; BTFSC PORTB,5; GOTO A8; MOVLW 6; MOVWF 61H; CALL WR1; A8 BCF STATUS,RP0; BCF STATUS,RP1; BTFSC PORTB,6; GOTO A9; MOVLW 7; MOVWF 61H; CALL WR1; A9 BCF STATUS,RP0; BCF STATUS,RP1; BTFSC PORTB,7; GOTO A10; MOVLW 8; MOVWF 61H; CALL WR1; A10 CALL RD01;調(diào)用讀數(shù)據(jù)程序 GOTO A2; ;*********************************************** ; 寫數(shù)據(jù)子程序 ;*********************************************** WR1 BSF STATUS,RP0; BSF STATUS,RP1;體3 BTFSC EECON1,WR;判斷是否在寫數(shù)據(jù) GOTO $-1; BCF STATUS,RP0; BCF STATUS,RP1;體0 MOVFW 60H;EEPROM目標(biāo)地址 BCF STATUS,RP0 BSF STATUS,RP1;體2 MOVWF EEADR;EEPROM目標(biāo)地址寄存器 BCF STATUS,RP0 BCF STATUS,RP1;體0 MOVFW 61H;需寫入數(shù)據(jù) BCF STATUS,RP0 BSF STATUS,RP1;體2 MOVWF EEDATA;EEPROM數(shù)據(jù)寄存器 BSF STATUS,RP0 BSF STATUS,RP1;體3 BCF EECON1,EEPGD;選擇為EEPROM模式 BSF EECON1,WREN;允許使能 ;*************************************************** ; 寫數(shù)據(jù)5指令序列PIC特定沒(méi)有為什么不允許能改變 MOVLW 55H ; MOVWF EECON2 ;55H送EECON2 MOVLW 0AAH; MOVWF EECON2 ;AAH送EECON2 BSF EECON1,WR ;啟動(dòng)寫操作 ; ;************************************************** BTFSC EECON1,WR;判斷是否學(xué)完成 GOTO $-1; BCF STATUS,RP0;恢復(fù)體0 BCF STATUS,RP1; RETURN; ;************************************************** ; 讀EEPROM數(shù)據(jù)子程序 ;************************************************** RD01 BCF STATUS,RP0; BSF STATUS,RP1;體2 MOVLW 0;目標(biāo)地址 MOVWF EEADR;目標(biāo)地址寄存器 BSF STATUS,RP0; BSF STATUS,RP0;體3 BCF EECON1,EEPGD;選擇EEPROM模式 BSF EECON1,RD;啟動(dòng)讀操作 BTFSC EECON1,RD;判斷是否讀取完 GOTO $-1; BCF STATUS,RP0; BSF STATUS,RP1;體2 MOVFW EEDATA;將數(shù)據(jù)存到W中 BCF STATUS,RP0; BCF STATUS,RP1;體0 MOVWF 53H ;將讀取數(shù)存到55H RETURN ;******************************************************** ; 定時(shí)中斷程序 ;******************************************************** ZD01 BCF INTCON,GIE;關(guān)總中斷 BTFSS INTCON,T0IF;判斷是否產(chǎn)生定時(shí)中斷 GOTO ZD03;否跳出是繼續(xù)執(zhí)行 ;*************************************************** ; 保護(hù)現(xiàn)場(chǎng) MOVWF W_TEMP;W備份到W_TEMP中 SWAPF STATUS,0;STATUS半字交換后送W CLRF STATUS;選擇體0為當(dāng)前體備份 MOVWF STATUS_TEMP;將原來(lái)的STATUS送體0上的 MOVF PCLATH,0;PCLATH送W MOVWF PCLATH_TEMP;W送備份寄存器中 CLRF PCLATH ;設(shè)置為0頁(yè) ;*************************************************** BCF INTCON,T0IF BSF STATUS,RP0;體1 BCF STATUS,RP1; MOVLW 0; MOVWF TRISC;RB口設(shè)為輸出口 MOVWF TRISD;RD口設(shè)為輸出口 BCF STATUS,RP0;體0 BCF STATUS,RP1; MOVLW 0FFH; MOVWF PORTC;RB口輸出高電平 MOVLW 0 MOVWF PORTD;RD口輸出低電平起清屏作用 MOVFW INDF;間接尋址顯示數(shù)據(jù) CALL Q1;查數(shù)據(jù)表 MOVWF PORTC;顯示斷碼輸出到RB口 INCF FSR,1;間接尋址地址加1 MOVFW 41H ;位碼 MOVWF PORTD;位碼輸出到RD口 RLF 41H,0;處理C RLF 41H,1;左移位碼 DECFSZ 40H,1;判斷是否顯示完4位 GOTO ZD02;否則繼續(xù)顯示 MOVLW 4;顯示位數(shù) MOVWF 40H; MOVLW B'00000001';位碼 MOVWF 41H; MOVLW 50H; MOVWF FSR ;間接尋址 ZD02 MOVLW 0FFH; MOVFW TMR0;重裝初值 ;*************************************************** ; 恢復(fù)現(xiàn)場(chǎng) CLRF STATUS;恢復(fù)到體0 MOVF PCLATH_TEMP,0;開始恢復(fù)數(shù)據(jù) MOVWF PCLATH;恢復(fù)PCLATH SWAPF STATUS_TEMP,0 MOVWF STATUS;恢復(fù)STATUS SWAPF W_TEMP,1;半字交換后放回 SWAPF W_TEMP,0;再半字交換后送W ;*************************************************** ZD03 BSF INTCON,GIE;開總中斷 RETFIE ;中斷返回 ;******************************************** ; 數(shù)據(jù)表 ;******************************************** END
