花樣流水燈的設(shè)計(jì)3(單片機(jī)-匯編)
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2012年12月20日   【字體:
;This program will show you cycle glitter between 8 led lamps
;     maker:Chen Weiwu
;     date:2012-11-08
;     version:1.0.0
;Define
Ledprt     equ          p0
SegDisplay   equ          p2
Button     equ        p1
;Set the initiation address which the program runing
        org        0
        ajmp       main
Cycle:
        mov        a,#low(Tables)
        add        a,r1
        mov        dpl,a
        clr        a
        addc       a,#high(Tables)
        mov        dph,a
        clr        a
        movc       a,@a+dptr
        mov        dpl,a
        clr        a
        movc       a,@a+dptr           ;Get the count of data in table
        mov        r0,a
        inc        dptr
Loop:
        mov        a,button         ;buttion is unable
        cpl        a
        jz        ExitCycle
        clr        a
        movc       a,@a+dptr
        mov         Ledprt,a
        acall       delay
        inc        dptr
        djnz       r0,Loop
ExitCycle:
        ret
;delay sub
delay:     mov        r5,#50
delay1:     mov        r6,#100
DELAY2:     mov        r7,#10
        djnz       r7,$
        djnz       r6,delay2
        djnz       r5,delay1
        ret
Tables:     dw        Table1,Table2,Table3,Table4,0
Table1:     db        Table2-$-1
        db        11111110b
        db        11111101b
        db        11111011b
        db        11110111b
        db        11101111b
        db        11011111b
        db        10111111b
        db        01111111b
Table2:     db        Table3-$-1
        db        01111110b
        db        10111101b
        db        11011011b
        db        11100111b
        db        11011011b
        db        10111101b
Table3:     db        Table4-$-1
        db        01010101b
        db        00000000b
        db        10101010b
        db        00000000b
Table4:     db        TableEnd-$-1
        db        11111110b
        db        11111100b
        db        11111000b
        db        11110000b
        db        11100000b
        db        11000000b
        db        10000000b
        db        00000000b
        db        00000001b
        db        00000011b
        db        00001111b
        db        00011111b
        db        00111111b
        db        01111111b
        db        11111111b
TableEnd:
main:
        mov        Ledprt,#11111111B
        mov        r2,#0
        mov        r3,#01111111b
        mov        SegDisplay,#00H      ;Initiate the SegDisplay
ToNext:
        cjne       r2,#5,ToNext1
        ajmp       Main
ToNext1:
        inc        r2            ;Button Number
        mov        a,r3
        rl        a
        mov        r3,a
        cjne       a,button,ToNext      ;Check whether the button is enable or not
        mov        SegDisplay,r2       ;button is enable,Show on the SegDisplay
        mov        a,r2
        rl        a
        clr        c
        subb       a,#1           ;Location in the Tables
        mov        r1,a
        mov        a,r3
        cjne       a,button,main
        acall       Cycle
        ajmp       Main
        end
