用STC15F104E單片機,就是一個定時器,上電開始計時,LED每秒閃一次,9小時后繼電器吸合3秒,然后釋放,計時器重新計時。如此循環(huán)。 #include "reg51.h" typedef unsigned char BYTE; typedef unsigned int WORD; #define SYSclk 6000000L #define MODE1T //Timer clock mode, commendt this line is 12T mode, uncomment is 1T mode #ifdef MODE1T #define T1MS (65536-SYSclk/1000) //1ms timer calculation method in 1T mode, 1000=1000Hz #else #define T1MS (65526-SYSclk/12/1000) //1ms timer calculation method in 12T mode #endif sfr AUXR=0x8e; //Auxiliary register sbit TEST_LED=P3^3; sbit relay = P3^4; WORD count; //1000 times counter BYTE sec; BYTE min; BYTE hour; BYTE S3cnt; BYTE S3cnt_Stat; void clock_cnt(); /*Timer0 interrupt routine */ void tm0_isr() interrupt 1 using 1 { if (count--==0) { count=500; //500ms TEST_LED=!TEST_LED; if (TEST_LED) clock_cnt(); } } void main() { #ifdef MODE1T AUXR=0x80; //timer0 work in 1T mode #endif TMOD=0x00; //set timer0 as mode0 (16-bit auto-reload) TL0=T1MS; //initial timer0 low byte TH0=T1MS>>8; //initial timer0 high byte TR0=1; //timer0 start running ET0=1; //enable timer0 interrupt EA=1; //open global interrupt switch sec = 0; min = 0; hour = 0; S3cnt_Stat = 0; while(1); } void clock_cnt() { if (S3cnt_Stat) { S3cnt--; if (S3cnt==0) { S3cnt_Stat = 0; relay = 0; //繼電器釋放 } } else { sec++; if (sec>=60) { sec=0; min++; if (min>=60); { min=0; hour++; if (hour>=9) //到了9小時 { relay = 1; //繼電器吸合 sec = 0; min = 0; hour = 0; S3cnt_Stat = 1; S3cnt = 3; //計數3秒 } } } } }
