STC89C52單片機驅(qū)動CC1101無線模塊的發(fā)送C語言程序
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2013年05月05日   【字體:
#include <reg52.h>
#include <intrins.h>
#define INT8U unsigned char
#define INT16 Uunsigned int
#define WRITE_BURST     0x40//連續(xù)寫入
#define READ_SINGLE     0x80//讀
#define READ_BURST      0xC0//連續(xù)讀
#define BYTES_IN_RXFIFO     0x7F  //接收緩沖區(qū)的有效字節(jié)數(shù)
#define CRC_OK              0x80 //CRC校驗通過位標(biāo)志
//**************CC1100接口*********
sbit GDO0=P3^3;
sbit GDO2=P1^4;
sbit MISO=P1^2;
sbit MOSI=P1^1;
sbit SCK=P3^2;
sbit CSN=P1^3;
//***********按鍵****************
sbit    KEY1    =P3^6;
sbit    KEY2    =P3^7;
//***************數(shù)碼管位選****************
sbitled3=P2^0;
sbitled2=P2^1;
sbitled1=P2^2;
sbitled0=P2^3;
//***************蜂鳴器***********************
sbit BELL=P3^4;
//***************溫度傳感器*****************
sbit      DQ=P3^5  ;
INT8U seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};         //0~~9段碼
INT8U seg1[10]={0x40,0x4F,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
INT8U data temp_data[2]={0x00,0x00};
INT8U dispaly[8];
//更多功率參數(shù)設(shè)置可詳細(xì)參考DATACC1100英文文檔中第48-49頁的參數(shù)表
INT8U PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60};  //0dBm
void SpiInit(void);
void CpuInit(void);
void RESET_CC1100(void);
void POWER_UP_RESET_CC1100(void);
void halSpiWriteReg(INT8U addr, INT8U value);
void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count);
void halSpiStrobe(INT8U strobe);
INT8U halSpiReadReg(INT8U addr);
void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count);
INT8U halSpiReadStatus(INT8U addr);
void halRfWriteRfSettings(void);
void halRfSendPacket(INT8U *txBuffer, INT8U size);
INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length);
void delay1(INT16U i);
void ds_reset(void);
void write_byte(INT8U value);
INT8U read_byte(void);
void read_temp();
void work_temp();
// CC1100 STROBE, CONTROL AND STATUS REGSITER
#define CCxxx0_IOCFG2       0x00        // GDO2 output pin configuration
#define CCxxx0_IOCFG1       0x01        // GDO1 output pin configuration
#define CCxxx0_IOCFG0       0x02        // GDO0 output pin configuration
#define CCxxx0_FIFOTHR      0x03        // RX FIFO and TX FIFO thresholds
#define CCxxx0_SYNC1        0x04        // Sync word, high INT8U
#define CCxxx0_SYNC0        0x05        // Sync word, low INT8U
#define CCxxx0_PKTLEN       0x06        // Packet length
#define CCxxx0_PKTCTRL1     0x07        // Packet automation control
#define CCxxx0_PKTCTRL0     0x08        // Packet automation control
#define CCxxx0_ADDR         0x09        // Device address
#define CCxxx0_CHANNR       0x0A        // Channel number
#define CCxxx0_FSCTRL1      0x0B        // Frequency synthesizer control
#define CCxxx0_FSCTRL0      0x0C        // Frequency synthesizer control
#define CCxxx0_FREQ2        0x0D        // Frequency control word, high INT8U
#define CCxxx0_FREQ1        0x0E        // Frequency control word, middle INT8U
#define CCxxx0_FREQ0        0x0F        // Frequency control word, low INT8U
#define CCxxx0_MDMCFG4      0x10        // Modem configuration
#define CCxxx0_MDMCFG3      0x11        // Modem configuration
#define CCxxx0_MDMCFG2      0x12        // Modem configuration
#define CCxxx0_MDMCFG1      0x13        // Modem configuration
#define CCxxx0_MDMCFG0      0x14        // Modem configuration
#define CCxxx0_DEVIATN      0x15        // Modem deviation setting
#define CCxxx0_MCSM2        0x16        // Main Radio Control State Machine configuration
#define CCxxx0_MCSM1        0x17        // Main Radio Control State Machine configuration
#define CCxxx0_MCSM0        0x18        // Main Radio Control State Machine configuration
#define CCxxx0_FOCCFG       0x19        // Frequency Offset Compensation configuration
#define CCxxx0_BSCFG        0x1A        // Bit Synchronization configuration
#define CCxxx0_AGCCTRL2     0x1B        // AGC control
#define CCxxx0_AGCCTRL1     0x1C        // AGC control
#define CCxxx0_AGCCTRL0     0x1D        // AGC control
#define CCxxx0_WOREVT1      0x1E        // High INT8U Event 0 timeout
#define CCxxx0_WOREVT0      0x1F        // Low INT8U Event 0 timeout
#define CCxxx0_WORCTRL      0x20        // Wake On Radio control
#define CCxxx0_FREND1       0x21        // Front end RX configuration
#define CCxxx0_FREND0       0x22        // Front end TX configuration
#define CCxxx0_FSCAL3       0x23        // Frequency synthesizer calibration
#define CCxxx0_FSCAL2       0x24        // Frequency synthesizer calibration
#define CCxxx0_FSCAL1       0x25        // Frequency synthesizer calibration
#define CCxxx0_FSCAL0       0x26        // Frequency synthesizer calibration
#define CCxxx0_RCCTRL1      0x27        // RC oscillator configuration
#define CCxxx0_RCCTRL0      0x28        // RC oscillator configuration
#define CCxxx0_FSTEST       0x29        // Frequency synthesizer calibration control
#define CCxxx0_PTEST        0x2A        // Production test
#define CCxxx0_AGCTEST      0x2B        // AGC test
#define CCxxx0_TEST2        0x2C        // Various test settings
#define CCxxx0_TEST1        0x2D        // Various test settings
#define CCxxx0_TEST0        0x2E        // Various test settings
// Strobe commands
#define CCxxx0_SRES         0x30        // Reset chip.
#define CCxxx0_SFSTXON      0x31        // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
                                       // If in RX/TX: Go to a wait state where only the synthesizer is
                                       // running (for quick RX / TX turnaround).
#define CCxxx0_SXOFF        0x32        // Turn off crystal oscillator.
#define CCxxx0_SCAL         0x33        // Calibrate frequency synthesizer and turn it off
                                       // (enables quick start).
#define CCxxx0_SRX          0x34        // Enable RX. Perform calibration first if coming from IDLE and
                                       // MCSM0.FS_AUTOCAL=1.
#define CCxxx0_STX          0x35        // In IDLE state: Enable TX. Perform calibration first if
                                       // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
                                       // Only go to TX if channel is clear.
#define CCxxx0_SIDLE        0x36        // Exit RX / TX, turn off frequency synthesizer and exit
                                       // Wake-On-Radio mode if applicable.
#define CCxxx0_SAFC         0x37        // Perform AFC adjustment of the frequency synthesizer
#define CCxxx0_SWOR         0x38        // Start automatic RX polling sequence (Wake-on-Radio)
#define CCxxx0_SPWD         0x39        // Enter power down mode when CSn goes high.
#define CCxxx0_SFRX         0x3A        // Flush the RX FIFO buffer.
#define CCxxx0_SFTX         0x3B        // Flush the TX FIFO buffer.
#define CCxxx0_SWORRST      0x3C        // Reset real time clock.
#define CCxxx0_SNOP         0x3D        // No operation. May be used to pad strobe commands to two
                                       // INT8Us for simpler software.
#define CCxxx0_PARTNUM      0x30
#define CCxxx0_VERSION      0x31
#define CCxxx0_FREQEST      0x32
#define CCxxx0_LQI          0x33
#define CCxxx0_RSSI         0x34
#define CCxxx0_MARCSTATE    0x35
#define CCxxx0_WORTIME1     0x36
#define CCxxx0_WORTIME0     0x37
#define CCxxx0_PKTSTATUS    0x38
#define CCxxx0_VCO_VC_DAC   0x39
#define CCxxx0_TXBYTES      0x3A
#define CCxxx0_RXBYTES      0x3B
#define CCxxx0_PATABLE      0x3E
#define CCxxx0_TXFIFO       0x3F
#define CCxxx0_RXFIFO       0x3F
// RF_SETTINGS is a data structure which contains all relevant CCxxx0 registers
typedef struct S_RF_SETTINGS
INT8U FSCTRL2;//
   INT8U FSCTRL1;   // Frequency synthesizer control.
   INT8U FSCTRL0;   // Frequency synthesizer control.
   INT8U FREQ2;     // Frequency control word, high INT8U.
   INT8U FREQ1;     // Frequency control word, middle INT8U.
   INT8U FREQ0;     // Frequency control word, low INT8U.
   INT8U MDMCFG4;   // Modem configuration.
   INT8U MDMCFG3;   // Modem configuration.
   INT8U MDMCFG2;   // Modem configuration.
   INT8U MDMCFG1;   // Modem configuration.
   INT8U MDMCFG0;   // Modem configuration.
   INT8U CHANNR;    // Channel number.
   INT8U DEVIATN;   // Modem deviation setting (when FSK modulation is enabled).
   INT8U FREND1;    // Front end RX configuration.
   INT8U FREND0;    // Front end RX configuration.
   INT8U MCSM0;     // Main Radio Control State Machine configuration.
   INT8U FOCCFG;    // Frequency Offset Compensation Configuration.
   INT8U BSCFG;     // Bit synchronization Configuration.
   INT8U AGCCTRL2;  // AGC control.
INT8U AGCCTRL1;  // AGC control.
   INT8U AGCCTRL0;  // AGC control.
   INT8U FSCAL3;    // Frequency synthesizer calibration.
   INT8U FSCAL2;    // Frequency synthesizer calibration.
INT8U FSCAL1;    // Frequency synthesizer calibration.
   INT8U FSCAL0;    // Frequency synthesizer calibration.
   INT8U FSTEST;    // Frequency synthesizer calibration control
   INT8U TEST2;     // Various test settings.
   INT8U TEST1;     // Various test settings.
   INT8U TEST0;     // Various test settings.
   INT8U IOCFG2;    // GDO2 output pin configuration
   INT8U IOCFG0;    // GDO0 output pin configuration
   INT8U PKTCTRL1;  // Packet automation control.
   INT8U PKTCTRL0;  // Packet automation control.
   INT8U ADDR;      // Device address.
   INT8U PKTLEN;    // Packet length.
} RF_SETTINGS;
/************寄存器配置***************/
const RF_SETTINGS rfSettings =
0x00,
   0x08,   // FSCTRL1   Frequency synthesizer control.
   0x00,   // FSCTRL0   Frequency synthesizer control.
   0x10,   // FREQ2     Frequency control word, high byte.
   0xA7,   // FREQ1     Frequency control word, middle byte.
   0x62,   // FREQ0     Frequency control word, low byte.
   0x5B,   // MDMCFG4   Modem configuration.
   0xF8,   // MDMCFG3   Modem configuration.
   0x03,   // MDMCFG2   Modem configuration.
   0x22,   // MDMCFG1   Modem configuration.
   0xF8,   // MDMCFG0   Modem configuration.
   0x00,   // CHANNR    Channel number.
   0x47,   // DEVIATN   Modem deviation setting (when FSK modulation is enabled).
   0xB6,   // FREND1    Front end RX configuration.
   0x10,   // FREND0    Front end RX configuration.
   0x18,   // MCSM0     Main Radio Control State Machine configuration.
   0x1D,   // FOCCFG    Frequency Offset Compensation Configuration.
   0x1C,   // BSCFG     Bit synchronization Configuration.
   0xC7,   // AGCCTRL2  AGC control.
   0x00,   // AGCCTRL1  AGC control.
   0xB2,   // AGCCTRL0  AGC control.
   0xEA,   // FSCAL3    Frequency synthesizer calibration.
   0x2A,   // FSCAL2    Frequency synthesizer calibration.
   0x00,   // FSCAL1    Frequency synthesizer calibration.
   0x11,   // FSCAL0    Frequency synthesizer calibration.
   0x59,   // FSTEST    Frequency synthesizer calibration.
   0x81,   // TEST2     Various test settings.
   0x35,   // TEST1     Various test settings.
   0x09,   // TEST0     Various test settings.
   0x0B,   // IOCFG2    GDO2 output pin configuration.
   0x06,   // IOCFG0D   GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation.
   0x04,   // PKTCTRL1  Packet automation control.
   0x05,   // PKTCTRL0  Packet automation control.
   0x00,   // ADDR      Device address.
   0x0c    // PKTLEN    Packet length.
//函數(shù)名:delay(unsigned int s)
//輸入:時間
//輸出:無
//功能描述:普通廷時,內(nèi)部用
static void delay(unsigned int s)
unsigned int i;
for(i=0; i<s; i++);
for(i=0; i<s; i++);
void halWait(INT16U timeout)
   do {
       _nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
   } while (--timeout);
void SpiInit(void)
CSN=0;
SCK=0;
CSN=1;
//函數(shù)名:CpuInit()
//輸入:無
//輸出:無
//功能描述:SPI初始化程序
void CpuInit(void)
SpiInit();
delay(5000);
//函數(shù)名:SpisendByte(INT8U dat)
//輸入:發(fā)送的數(shù)據(jù)
//輸出:無
//功能描述:SPI發(fā)送一個字節(jié)
INT8U SpiTxRxByte(INT8U dat)
INT8U i,temp;
temp = 0;
SCK = 0;
for(i=0; i<8; i++)
if(dat & 0x80)
MOSI = 1;
else MOSI = 0;
dat <<= 1;
SCK = 1;
_nop_();
_nop_();
temp <<= 1;
if(MISO)temp++;
SCK = 0;
_nop_();
_nop_();
return temp;
//函數(shù)名:void RESET_CC1100(void)
//輸入:無
//輸出:無
//功能描述:復(fù)位CC1100
CSN = 0;
while (MISO);
   SpiTxRxByte(CCxxx0_SRES); //寫入復(fù)位命令
while (MISO);
   CSN = 1;
//函數(shù)名:void POWER_UP_RESET_CC1100(void)
//輸入:無
//輸出:無
//功能描述:上電復(fù)位CC1100
CSN = 1;
halWait(1);
CSN = 0;
halWait(1);
CSN = 1;
halWait(41);
RESET_CC1100();   //復(fù)位CC1100
//函數(shù)名:void halSpiWriteReg(INT8U addr, INT8U value)
//輸入:地址和配置字
//輸出:無
//功能描述:SPI寫寄存器
   CSN = 0;
   while (MISO);
   SpiTxRxByte(addr);//寫地址
   SpiTxRxByte(value);//寫入配置
   CSN = 1;
//函數(shù)名:void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//輸入:地址,寫入緩沖區(qū),寫入個數(shù)
//輸出:無
//功能描述:SPI連續(xù)寫配置寄存器
   INT8U i, temp;
temp = addr | WRITE_BURST;
   CSN = 0;
   while (MISO);
   SpiTxRxByte(temp);
   for (i = 0; i < count; i++)
       SpiTxRxByte(buffer[i]);
   CSN = 1;
//函數(shù)名:void halSpiStrobe(INT8U strobe)
//輸入:命令
//輸出:無
//功能描述:SPI寫命令
   CSN = 0;
   while (MISO);
   SpiTxRxByte(strobe);//寫入命令
   CSN = 1;
//函數(shù)名:INT8U halSpiReadReg(INT8U addr)
//輸入:地址
//輸出:該寄存器的配置字
//功能描述:SPI讀寄存器
INT8U temp, value;
   temp = addr|READ_SINGLE;//讀寄存器命令
CSN = 0;
while (MISO);
SpiTxRxByte(temp);
value = SpiTxRxByte(0);
CSN = 1;
return value;
//函數(shù)名:void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//輸入:地址,讀出數(shù)據(jù)后暫存的緩沖區(qū),讀出配置個數(shù)
//輸出:無
   INT8U i,temp;
temp = addr | READ_BURST;//寫入要讀的配置寄存器地址和讀命令
   CSN = 0;
   while (MISO);
SpiTxRxByte(temp);
       buffer[i] = SpiTxRxByte(0);
   CSN = 1;
//輸入:地址
//輸出:該狀態(tài)寄存器當(dāng)前值
//功能描述:SPI讀狀態(tài)寄存器
   INT8U value,temp;
temp = addr | READ_BURST;//寫入要讀的狀態(tài)寄存器的地址同時寫入讀命令
   CSN = 0;
   while (MISO);
   SpiTxRxByte(temp);
CSN = 1;
return value;
//函數(shù)名:void halRfWriteRfSettings(RF_SETTINGS *pRfSettings)
//輸入:無
//輸出:無
//功能描述:配置CC1100的寄存器
halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL2);//自已加的
   // Write register settings
   halSpiWriteReg(CCxxx0_FSCTRL1,  rfSettings.FSCTRL1);
   halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL0);
   halSpiWriteReg(CCxxx0_FREQ2,    rfSettings.FREQ2);
   halSpiWriteReg(CCxxx0_FREQ1,    rfSettings.FREQ1);
   halSpiWriteReg(CCxxx0_FREQ0,    rfSettings.FREQ0);
   halSpiWriteReg(CCxxx0_MDMCFG4,  rfSettings.MDMCFG4);
   halSpiWriteReg(CCxxx0_MDMCFG3,  rfSettings.MDMCFG3);
   halSpiWriteReg(CCxxx0_MDMCFG2,  rfSettings.MDMCFG2);
   halSpiWriteReg(CCxxx0_MDMCFG1,  rfSettings.MDMCFG1);
   halSpiWriteReg(CCxxx0_MDMCFG0,  rfSettings.MDMCFG0);
   halSpiWriteReg(CCxxx0_CHANNR,   rfSettings.CHANNR);
   halSpiWriteReg(CCxxx0_DEVIATN,  rfSettings.DEVIATN);
   halSpiWriteReg(CCxxx0_FREND1,   rfSettings.FREND1);
   halSpiWriteReg(CCxxx0_FREND0,   rfSettings.FREND0);
   halSpiWriteReg(CCxxx0_MCSM0 ,   rfSettings.MCSM0 );
   halSpiWriteReg(CCxxx0_FOCCFG,   rfSettings.FOCCFG);
   halSpiWriteReg(CCxxx0_BSCFG,    rfSettings.BSCFG);
   halSpiWriteReg(CCxxx0_AGCCTRL2, rfSettings.AGCCTRL2);
halSpiWriteReg(CCxxx0_AGCCTRL1, rfSettings.AGCCTRL1);
   halSpiWriteReg(CCxxx0_AGCCTRL0, rfSettings.AGCCTRL0);
   halSpiWriteReg(CCxxx0_FSCAL3,   rfSettings.FSCAL3);
halSpiWriteReg(CCxxx0_FSCAL2,   rfSettings.FSCAL2);
halSpiWriteReg(CCxxx0_FSCAL1,   rfSettings.FSCAL1);
   halSpiWriteReg(CCxxx0_FSCAL0,   rfSettings.FSCAL0);
   halSpiWriteReg(CCxxx0_FSTEST,   rfSettings.FSTEST);
   halSpiWriteReg(CCxxx0_TEST2,    rfSettings.TEST2);
   halSpiWriteReg(CCxxx0_TEST1,    rfSettings.TEST1);
   halSpiWriteReg(CCxxx0_TEST0,    rfSettings.TEST0);
   halSpiWriteReg(CCxxx0_IOCFG2,   rfSettings.IOCFG2);
   halSpiWriteReg(CCxxx0_IOCFG0,   rfSettings.IOCFG0);
   halSpiWriteReg(CCxxx0_PKTCTRL1, rfSettings.PKTCTRL1);
   halSpiWriteReg(CCxxx0_PKTCTRL0, rfSettings.PKTCTRL0);
   halSpiWriteReg(CCxxx0_ADDR,     rfSettings.ADDR);
   halSpiWriteReg(CCxxx0_PKTLEN,   rfSettings.PKTLEN);
//函數(shù)名:void halRfSendPacket(INT8U *txBuffer, INT8U size)
//輸入:發(fā)送的緩沖區(qū),發(fā)送數(shù)據(jù)個數(shù)
//輸出:無
//功能描述:CC1100發(fā)送一組數(shù)據(jù)
halSpiWriteReg(CCxxx0_TXFIFO, size);
   halSpiWriteBurstReg(CCxxx0_TXFIFO, txBuffer, size);//寫入要發(fā)送的數(shù)據(jù)
   halSpiStrobe(CCxxx0_STX);//進入發(fā)送模式發(fā)送數(shù)據(jù)
   // Wait for GDO0 to be set -> sync transmitted
   while (!GDO0);
   // Wait for GDO0 to be cleared -> end of packet
   while (GDO0);
halSpiStrobe(CCxxx0_SFTX);
void setRxMode(void)
   halSpiStrobe(CCxxx0_SRX);//進入接收狀態(tài)
   INT8U status[2];
   INT8U packetLength;
INT8U i=(*length)*4;  // 具體多少要根據(jù)datarate和length來決定
delay(2);
while (GDO0)
delay(2);
--i;
if(i<1)
  return 0;
   if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //如果接的字節(jié)數(shù)不為0
       packetLength = halSpiReadReg(CCxxx0_RXFIFO);//讀出第一個字節(jié),此字節(jié)為該幀數(shù)據(jù)長度
       if (packetLength <= *length) //如果所要的有效數(shù)據(jù)長度小于等于接收到的數(shù)據(jù)包的長度
           halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, packetLength); //讀出所有接收到的數(shù)據(jù)
           *length = packetLength;//把接收數(shù)據(jù)長度的修改為當(dāng)前數(shù)據(jù)的長度
           // Read the 2 appended status bytes (status[0] = RSSI, status[1] = LQI)
           halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2); //讀出CRC校驗位
halSpiStrobe(CCxxx0_SFRX);//清洗接收緩沖區(qū)
           return (status[1] & CRC_OK);//如果校驗成功返回接收成功
           return 0;
return 0;
void ds_reset(void)
char temp=1;
while(temp)
while(temp)
   DQ=1;_nop_();_nop_();
DQ=0;
delay1(80);
DQ=1;
delay1(9);
temp=DQ;
 delay1(64);
temp=~DQ;
DQ=1;
for(;i>0;i--);
INT8U i;
for(i=8;i>0;i--)
 DQ=0;_nop_();_nop_();_nop_();_nop_();_nop_();
DQ=value&0x01;
 delay1(9);
   value>>=1;
DQ=1;
delay1(1);
INT8U i;
INT8U value1=0;
for(i=8;i>0;i--)
value1>>=1;
DQ=0;
DQ=1;
if(DQ)
value1|=0x80;
delay1(9);
DQ=1;
return(value1);
void read_temp()
ds_reset();
write_byte(0xcc);
write_byte(0xbe);
temp_data[0]=read_byte();
temp_data[1]=read_byte();
ds_reset();
write_byte(0xcc);
write_byte(0x44);
void work_temp()
INT8U n=0;
if(temp_data[1]>127)
temp_data[1]=(256-temp_data[1]);//負(fù)值
temp_data[0]=(256-temp_data[0]);
n=1;
dispaly[6]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4);
dispaly[5]=dispaly[6]/100;//百位
dispaly[4]=dispaly[6]%100;//
dispaly[2]=dispaly[4]/10;//十位
dispaly[1]=dispaly[4]%10;//個位
switch(temp_data[0]&0x0f)//小數(shù)位
case 0x0f:dispaly[0]=9;break;
case 0x0e:dispaly[0]=9;break;
case 0x0d:dispaly[0]=8;break;
case 0x0c:dispaly[0]=8;break;
case 0x0b:dispaly[0]=7;break;
case 0x0a:dispaly[0]=6;break;
case 0x09:dispaly[0]=6;break;
case 0x08:dispaly[0]=5;break;
case 0x07:dispaly[0]=4;break;
case 0x06:dispaly[0]=4;break;
case 0x05:dispaly[0]=3;break;
case 0x04:dispaly[0]=3;break;
case 0x03:dispaly[0]=2;break;
case 0x02:dispaly[0]=1;break;
case 0x01:dispaly[0]=1;break;
case 0x00:dispaly[0]=1;break;
default:break;
if(n)//負(fù)值時顯示aa,正直顯示dd
dispaly[3]=0x11;//
else dispaly[3]=0x22;
void disdignit()
char i;
//if(temp[0])
for(i=0;i<3;i++)
P0=0xC6;
led0=0;
delay1(40);
led0=1;
P0=seg[dispaly[0]];
led1=0;
delay1(40);
led1=1;
P0=seg1[dispaly[1]];
led2=0;
delay1(40);
led2=1;
P0=seg[dispaly[2]];
led3=0;
delay1(40);
led3=1;
void main(void)
INT8U leng =0;
INT8U tf =0;
INT8U TxBuf[8]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08}; // 8字節(jié), 如果需要更長的數(shù)據(jù)包,請正確設(shè)置
INT8U RxBuf[8]={0};
CpuInit();
POWER_UP_RESET_CC1100();
halRfWriteRfSettings();
halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8);
//halRfSendPacket(TxBuf,8);// Transmit Tx buffer data
delay(6000);
read_temp();
work_temp();
delay1(500);
disdignit();
halRfSendPacket(dispaly,4);// Transmit Tx buffer data
